Vancouver Impreza Club
Old 03-15-2008, 10:29 PM   #1
hoofenshnoz
Member#: 119586
2003 WRX
Platinum Silver Metallic
Default So ugh I have no power in my car, it wont start.
So im bringin my car back to stock today, was sailing through it. Took my utec out and my aftermarket deck, plugged in my stock CD deck, turned the car on...everything worked fine, yes! time to take out my turbo timer so I unplug everything on the TT, cut the 3 wires going to the ignition, and go to turn the car on and its totally dead...so i brought my friend over and we went crazy with the multimeter, and i cant get power ANYWHERE, there are no constansts wat so ever in my car right now and all the main fuses are perfectly fine. Any suggestions? cause i need to drive home tomorrow!
Thanks
hoofenshnoz is offline   Reply With Quote
Old 03-15-2008, 10:42 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
check the main fuse under the hood its the one held in with two nuts.
novacivic is offline   Reply With Quote
Old 03-15-2008, 11:08 PM   #3
hoofenshnoz
Member#: 119586
2003 WRX
yeah we did, its fine.
Old 03-15-2008, 11:18 PM   #4
Linkseal
Member#: 102329
05 AW Piggy Gone
11 SP TOM'S IS-F
Did you try to connect the Turbo timer back to see if you can start the car? If yes, and troubleshoot with Turbo timer
Linkseal is offline   Reply With Quote
Old 03-16-2008, 02:35 AM   #5
hoofenshnoz
Member#: 119586
2003 WRX
yep we did, no dice, car is a rock right now.
Old 03-16-2008, 02:41 AM   #6
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Put the turbo timer back together and see if it starts. If it does, then you know its the turbo timer. If not, it can be other problems.
Troubleshooting FTL.
fukamoto is offline   Reply With Quote
Old 03-16-2008, 03:14 AM   #7
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
most likely cutting the turbo timer wires shorted something out... check and recheck the wires u cutted...
RX Renesis is offline   Reply With Quote
Old 03-16-2008, 06:40 AM   #8
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
you have no power anywhere but the main fuse is fine...? check all the fuses in both panels? find a known constant power (such as power window relay) and see if it has power?
off off chance, did you disconnect the battery while doing all this delicate electronic work and forget about it?
Zefy is offline   Reply With Quote
Old 03-16-2008, 11:51 AM   #9
hoofenshnoz
Member#: 119586
2003 WRX
yeah all the dumb things have been looked at my buddy is a honda technician, i was hoping maybe there was a subaru weird thing i didnt know about that would cause this to happen, doesnt sound like it ha.
Old 03-16-2008, 12:53 PM   #10
hoofenshnoz
Member#: 119586
2003 WRX
so the only thing I can think of is something computer wise tripped, could my ECU or anything like this do this to my car? if so how can I reset it
Old 03-16-2008, 03:13 PM   #11
bender
Member#: 1839
even if your ecu if fried, you should be getting power. factory alarm maybe?
are you getting no power at all? no lights, radio, etc
did you check to see if your battery is charged up, at least 12 volts?
the only thing I could think of without looking at the car is that you might have burnt out your ignition switch
bender is offline   Reply With Quote
Old 03-16-2008, 03:22 PM   #12
hoofenshnoz
Member#: 119586
2003 WRX
yeah man its a new battery, no power at all no nothing, its a coffin, and even if my ignition switch was burnt out I should still have a constant from somewhere no? cause i dont have one!
Old 03-16-2008, 03:26 PM   #13
Yannerd
Member#: 111637
you should still be getting power to the factory security system if the ignition was fried.
BTW have you checked the battery? Maybe it's defective.
Yannerd is offline   Reply With Quote
Old 03-16-2008, 04:16 PM   #14
hoofenshnoz
Member#: 119586
2003 WRX
yeah ive tried my jumper packs, nothing still
Old 03-16-2008, 05:33 PM   #15
bender
Member#: 1839
the wiring should be pretty straight forward.
battery > main fuse panel > ignition system
if you're getting power at the battery, are you getting power anywhere at the main fuse panel (under hood) ?
Old 03-16-2008, 06:33 PM   #16
hoofenshnoz
Member#: 119586
2003 WRX
no man im not even getting power on the 80amp main fuse or any of the 50amps, and we checked the battery grounds, both sides, they are fine...its as if i had no battery in my car.
Old 03-16-2008, 06:56 PM   #17
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
check the wire that goes from battery to the main fuse... check both ends and see if it's loose...
ps... check polarity of the battery and the wires u've hooked up... maybe they're reversed...
Old 03-16-2008, 08:15 PM   #18
hoofenshnoz
Member#: 119586
2003 WRX
FIXED! so the problem was the harness that went to the fusebox was put on the negative teminal of the battery somehow oops <:-)
Old 03-16-2008, 08:57 PM   #19
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
so i was right...
Old 03-17-2008, 12:38 AM   #20
Yannerd
Member#: 111637
Hmmm this sounds familiar
Some People Have No Taste in Modifying Cars.... teamjordan23 Off-Topic 23 04-02-2008 12:20 PM
So I keep having this issue with my car... tcs007 Mid West Subaru Owners Club Forum -- MWSOC 4 12-22-2005 02:21 PM
Bleh....I have no power at my home. Styoopid storm! Snoopy Off-Topic 5 07-28-2005 08:29 AM
No oil in my car? twizhimself Service & Maintenance 23 03-16-2005 10:30 PM
Photos: I still have no faith in my monitor calibration. (56k not-so-much) gongzero Off-Topic 21 05-26-2004 09:35 AM
