Old 10-26-2011, 05:36 PM   #1526
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yes, there's quite a lot you're missing.
Think this one over harder. I'm sure you can figure out what the problem is if the MAF is supposed to be precisely metering the air entering the engine.
Old 10-26-2011, 05:47 PM   #1527
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
So you're pretty much saying there's a hole after the MAF, as in a leak for unmetered air?
chazly413 is offline   Reply With Quote
Old 10-26-2011, 05:50 PM   #1528
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Dude is effectively saying he wants air to move through the MAF (but how will it move it the engine isn't pumping it in?) and then be wasted into the engine bay. Then he wants a different, completely un-metered, amount of air to actually enter the engine.
Utter fail.
Old 10-26-2011, 05:58 PM   #1529
99ForesterVA
Member#: 295752
Default Sooooo...
It has to be an exact amount of air coming into the intake, and no more or no less? So that means that ANY change in that would cause a disruption, no matter how small the disruption? So in theory, even a higher flow air filter would cause more air to get into the maf, causing problems? A crack in the snorkus, a loose clamp, anything would cause my engine to have problems? That kinda seems weird to me, because the hybrid setup you use alters the air flow also. Originally after the maf, there are a few bends, some flexible hose, and a large airbox to deal with. But your system removes all that turbulence, and makes it a smooth transition straight into the intake. So, in essence, your hybrid is all show and no go, but rather window dressing, right? I mean, if yours disrupts the air flow any, then you'll mess up your engine right? Does yours simply do the same thing as the stock, but in a prettier package, thereby taking absolutely no chance in harming your engine? Can you break it down more for this dummy here, because I'm not quite following?
99ForesterVA is offline   Reply With Quote
Old 10-26-2011, 06:05 PM   #1530
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Every molecule that passes the MAF must immediately enter the engine. Every molecule that enters the engine must have passed the MAF.
Air filters don't mess things up because the air that passes the MAF, and only the air that passes the MAF, enters the engine.
Old 10-26-2011, 06:06 PM   #1531
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Old 10-26-2011, 06:12 PM   #1532
99ForesterVA
Member#: 295752
Utter fail.
Ahhhh...that's the unanswered question. Does the engine have its own vacuum? It seems if it did, wouldn't it still suck in the same amount of air as it did with the original setup? Or does the original setup decrease the flow of air on purpose? Thanks for your responses.
Old 10-26-2011, 06:13 PM   #1533
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
what you are proposing is like having an air conditioning unit installed in your house but then you go and open all the windows thinking, "if open windows make it cooler AND the AC makes it cooler, then it should be SUPER cool in my house!"
If you find the above statement completely correct, then please don't touch your car. ever.
If you think, "hey, that's crazy. AC works best with the windows all closed," then you're on the right track.
So pretend the AC unit is your MAF, the house is the engine. If you remove the maf from the flow into the engine you're engine won't know how much air it is receiving. Think if the car was idling at a stop. No airflow would go through the maf but air would still be going into the engine. (back to my metaphor, you'd have all your windows open with the AC unit sitting on the front lawn... doesn't work)
You can move the maf anywhere you want as long as everything AFTER the maf goes right into the engine with no leaks. If you mess around with things (like what a SRI or CAI does) the sensor won't work properly. The hybrid is a nice middle ground where everything still works with a little bit better flow.
Zefy is offline   Reply With Quote
Old 10-26-2011, 06:22 PM   #1534
99ForesterVA
Member#: 295752
Okay, thanks. I see what your saying. My only point is this: if the engine sucks its own air, then I don't understand where it matters where its coming from. The maf does not alter the flow correct? It only measures it, correct? Does the original setup decrease or increase the flow in some way? If not, and its sucking air willy nilly into the engine, what does it matter where it comes from, so long as the maf is reading what's coming through the snorkus?
Old 10-26-2011, 06:49 PM   #1535
99ForesterVA
Member#: 295752
Utter fail.
I very much appreciate your answers. What I'm trying understand is, does the snorkus cause a decrease or increase in the air flow, which is what makes it the perfect amount of air to be the most efficient? Or does the engine take in the amount it needs based on the amount of throttle given?
Old 10-26-2011, 07:57 PM   #1536
renyo
Member#: 93577
98 Impreza
Since you're typing like you've at least seen an English textbook, I'll try to explain.
To burn gas properly and create usable combustion without breaking the engine, there is a specific ratio of air to fuel you have to have (it's more a range of ratios, but not the point). For example, if an engine sucks in 14.7 pounds of air, I have to spray 1 pound of fuel into the engine for a good combustion event.
The engine uses the MAF sensor to determine how much air is going into the engine. The MAF sensor can only measure air that has gone through it.
The problem with your ideas is the engine doesn't give a **** where the air comes from, be it the intake through the MAF sensor, a vacuum leak, or a cone filter stuck to the side of the intake pipe after the MAF sensor.
The problem arises when (with made up numbers) 14.7 pounds of air flows through the MAF sensor, then an additional (once again, made up number) 3 pounds of air flows through the leak/hole in the intake pipe after the MAF sensor. Since this did not come through the MAF sensor, the engine thinks only 14.7 pounds of air is in the engine, so it injects 1 pound of fuel.
Unfortunately, instead of a nice 14.7:1 air to fuel ratio, you now have a 17.7:1 air to fuel ratio and your engine just exploded.
Now, to answer a couple of your questions.
Yes, the MAF sensor affects the air flow. It has to because of how it measures it. That said, it's a negligible amount.
Intakes (ideally) increase the amount of air you can flow to your engine by creating less of a restriction for the incoming air (having a lower pressure drop across them). The accordion pipe that's behind the MAF sensor in stock intakes doesn't help air flow smoothly. Replacing it with a smoother pipe (i.e. Williaty's hybrid intake) lets the air flow, well, smoother. Sort of how single file lines can get more people into a building faster than people mobbing for the door.
renyo is offline   Reply With Quote
Old 10-26-2011, 09:00 PM   #1537
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You must have an unbroken, non-leaky, air-tight pathway directly from the MAF to the engine. Yes, engines pull a near-perfect vacuum.
Old 10-26-2011, 11:07 PM   #1538
99ForesterVA
Member#: 295752
Thanks for that response. That was what I was looking for. My main issue is understanding exactly how the snorkus works, and what the purpose of the MAF is. I know from williaty's responses that the MAF meters the air. What is the main purpose of the snorkus though? Is it to allow a certain amount of air into the intake?
By the way, I will using williaty's hybrid intake template for mine. I was 99.9% sure before, but I wanted to test some other theories too that sounded good. I saw a picture of a short cowl induction on another forum, and thought about trying it.
Just to make sure you understood what I was talking about, let me repeat my idea, adding the info I've learned here.
1. Since the engine sucks it's own vacuum of air, I thought about a cowl induction system where (a) either I would leave the rear airbox in its original place, and run a 90* elbow out of the side and through a hole in the firewall, drawing air through the cowl area, or (b) running a pipe straight from the intake into a hole in the firewall, and deleting the rear airbox and adding a filter inside the area where the windshield wipers are located or in the pipe area between the intake and firewall. As I understand it, there is plenty of air pressure at the base of the windshield to be sufficient for the intake. The only issue would be rain or snow accumulation in that area, and risk of hydrolock if some were to get in the motor.
2. As for the MAF, I was considering leaving the original snorkus and airbox and MAF section as is, and placing an air filter right after the MAF section. Since it has been established that the engine is what draws the air through the MAF, that idea is out the door. I thought that if the air going past the MAF did not have the vacuum from the engine, then my solution to the MAF causing the car to run lean would be brilliant. But it seems like, if anything, if I was going to be hard-headed like some people are, I'd be better off taking the whole shebang out and there'd be less issue than if it was getting a false reading from not enough air with my set up. I have no intention of doing that however.
Old 10-26-2011, 11:17 PM   #1539
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The snorkus, aka the big jug inside the fender, is there to control a resonance in the intake tract that would otherwise cause the MAF to give false readings. That is explained in the first post.
Old 10-26-2011, 11:32 PM   #1540
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
You can do whatever you want with the intake before the MAF, it doesn't make a damned difference (besides having a resonance or not). You cannot cannot cannot change anything after the MAF in the sense that more air enters the engine. Cannot cannot cannot. The MAF tells the engine the current flow rate of air into the engine so the engine can fuel accordingly. As renyo explained earlier, if you have air entering after the MAF, the MAF has not been affected by this airflow, and as such, has no idea this air is entering the engine. This will promote lean conditions, detonation, and possibly engine death.
You can change details of the intake post-MAF, such as piping diameter, but this requires a tune. The MAF is set up to work with the current intake's diameter, as a given pressure N over a given cross-sectional area has a unique mass flow rate. Increase the diameter by 33% and you're flowing almost 50% more air at the previously mentioned pressure N.
Old 10-26-2011, 11:45 PM   #1541
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Not quite true. The helmholtz resonator is before the MAF and it's absolute critical.
Old 10-27-2011, 12:28 AM   #1542
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
I know it's absolutely critical to eliminate the resonance but you don't necessarily need it to run the car.
Old 10-27-2011, 12:29 AM   #1543
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Take it off, put the car in open loop, step on gas, watch car stall.
Yeah, it's kind of necessary.
Old 10-27-2011, 12:30 AM   #1544
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
What about the dingbats who remove their snorkus via SRI or CAI?
Old 10-27-2011, 12:31 AM   #1545
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Their cars usually aren't in open loop in the spots where the problem happens. It turns it from a stall into a bog.
Old 10-27-2011, 12:36 AM   #1546
chazly413
Member#: 151079
2005 2.5RS RBP
s-techs mad tyte yo
Ah, fair enough. Thanks for the clarification.
Old 10-27-2011, 01:16 AM   #1547
renyo
Member#: 93577
98 Impreza
As williaty said, the snorkus is there to control a resonance issue with the MAF. As a byproduct, it reduces air flow slightly.
If I understand you correctly, it's known as a gravelsports intake. You can't do it with a MAF.
If you have any kind of hole or membrane permeable enough for air to flow through it after the MAF, you're going to have problems.
I think the idea you're missing is that if it doesn't go through the MAF, there's an issue. It doesn't matter why it doesn't. If it doesn't, you're going to have a problem.
A MAF is like any other scientific instrument. Aside from the occasional mechanical or electrical problem, it doesn't make the car do anything. Basically, the MAF isn't a problem that needs a solution. The engine expects the MAF to tell it how much air is coming into the engine. If you prevent the MAF from doing it's job, you prevent the ECU from doing its job. When the ECU doesn't do it's job properly, you have engine problems.
  • all the air, and only the air, entering the engine must pass through and be recorded by the MAF
  • all the air, and only the air, passing through, and being recorded by the MAF must enter the engine.
If either of those two rules are violated, you're going to have issues.
The snorkus is there to make sure that all the air recorded by the MAF is actually entering the engine.
It's bedtime, forgive grammar issues.
Old 11-22-2011, 11:02 AM   #1548
jonclarke
Member#: 289159
2007 Impreza 2.5i SE
CGM
So if I do the hybrid on an 07i from stock... Will I have to do some kind of retune? Is it even worth it for the cost?
jonclarke is offline   Reply With Quote
Old 11-28-2011, 01:36 AM   #1549
jonclarke
Member#: 289159
CGM
Anyone?
Old 11-28-2011, 01:41 AM   #1550
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Tuning for the hybrid is desirable but not required.
If you are using the stock tune now, a well-done tune will substantially improve the car.
CAIs, SRIs, and dynos Bluefoton General Community 10 04-09-2008 08:27 PM
problems with 04' sti into an 01' RS help! Imbaru25rs Subaru Conversions 7 02-18-2006 02:40 AM
Any problems with your STI and with SOA? bbbwrx STi Forum Archive 3 08-27-2003 04:32 PM
LOTS of Problems with SOA, Dealer, and MYSUBARU.com saleen90181 Newbies & FAQs 11 11-26-2002 01:37 PM
Anyone with CAI, Unichip and stock turbo? Dougeefresh Factory 2.0L Turbo Powertrain 4 04-27-2002 12:13 PM
Message Board Statistics All times are GMT -4. The time now is 11:58 AM.
