Old 11-29-2011, 05:04 PM   #1551
jonclarke
Member#: 289159
2007 Impreza 2.5i SE
CGM
What kind of tune are we talking about? Where would I go for one? How much might it cost?
jonclarke is offline   Reply With Quote
Old 12-08-2011, 11:15 PM   #1552
cdwahl
Member#: 144605
2007 2.5i Wagon
Satin White Pearl
Angry CARB=bs
CARB is such bs, do they even test the cars??? How can the injen CAI be CARB approved for the 05-07 impreza NAs???
http://www.injen.com/docs/typeofvehicle/carb.asp
SP-1222
cdwahl is offline   Reply With Quote
Old 12-08-2011, 11:55 PM   #1553
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
SP-1222
Short translation of CARB's requirements for aftermarket parts:
Cannot harm the car or cause more emissions or reduced fuel economy.
So long as it was on the stock tune and they deliberately never let the engine speed drop, a bad intake will pass CARB requirements with flying colors.
Old 12-20-2011, 04:27 AM   #1554
akballow
Member#: 288597
I looked through most of this thread but could not find the info. Is the airsensor on my 2011 2.5i going to have problems with my cosmo cai or not? it seems like this is only a problem for older 2.5i's.
Thanks
akballow is offline   Reply With Quote
Old 12-20-2011, 04:31 AM   #1555
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your 2011 has the same parts that cause the problem with the 2005 and newer cars. However, to my knowledge, no one has yet tested a 2011 to confirm that the same parts are causing the same problem. Log it for yourself and find out.
Old 12-20-2011, 10:05 AM   #1556
akballow
Member#: 288597
I do not know how to log such values mentions in the OP. I was under the impression that reseting the ecu fixed it. Is there nothing i can do to fix this problem?
Old 12-20-2011, 03:07 PM   #1557
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Fixes:
1) Run a damned hybrid intake. It's not that hard, it's just as good as a CAI/SRI, and it's the cheapest option.
2) Run a CAI/SRI just because you're stubborn and pay for a professional custom tune from a tuner that knows the trick for how to make it work. This is definitely a hack. It doesn't make the problem go away, it just slaps a band-aid on it. Also, as far as I've ever heard, only one person in the US has figured out the trick.
Old 01-02-2012, 09:04 PM   #1558
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
And that's you..
awdorgtfo is offline   Reply With Quote
Old 01-02-2012, 09:04 PM   #1559
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
Double post...that's a first.
Old 01-02-2012, 09:08 PM   #1560
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by awdorgtfo View Post
And that's you..
And TiC, though I think no one there is actually tuning. I have no idea what they'd say if you called them up and asked for a tune.
Old 01-02-2012, 09:12 PM   #1561
awdorgtfo
Member#: 252252
2007 WRX Wagon
UGM
They would probably give me your number.
Old 02-03-2012, 12:02 PM   #1562
AutoXRex
Member#: 21650
2015 STI
Default Questions
I am searching for more usable power across the full rpm range and am concerned that adding a hybrid intake provides more peak power and moves torque up in the rpm range.
1. Does installing a hybrid intake which eliminates the “torque box” reduce torque or move it upward in the rpm range?
2. What kind of gains would installing smooth tubing between the MAF and Torque box provide? Comparable to a full hybrid?
Thanks
Marc
AutoXRex is offline   Reply With Quote
Old 02-03-2012, 12:51 PM   #1563
Soul Shinobi
Member#: 130759
2002 Forester S
This must be the first reasonable question since page 10!
Soul Shinobi is offline   Reply With Quote
Old 02-03-2012, 05:16 PM   #1564
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
1) There is no evidence that the so-called Torque Box actually has anything to do with torque. In fact, the one and only test that's ever been done specifically about this question showed absolutely no change in torque with or without it. Additionally, if you look at the first post, you'll see there are no regions where the hybrid load trace is substantially below the stock load trace.
2) That configuration wasn't tested because there was no point in light of #1
More like post 10...
Old 02-03-2012, 07:59 PM   #1565
AutoXRex
Member#: 21650
2015 STI
williaty,
Thank you for the quick response.
I suspected that this was going to be the answer but wanted to be sure.
Now to find an inexpensive pipe.
Old 02-15-2012, 09:04 PM   #1566
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
i didnt see anything for a 2008 2.5i, i am really interested in getting a sri, but do i need a tune?
fmars62 is offline   Reply With Quote
Old 02-15-2012, 09:44 PM   #1567
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
2008+ still seem to have the same problem as the older cars. Haven't tested it personally but people I trust have.
Old 02-16-2012, 09:53 AM   #1568
fmars62
Member#: 290517
2008 Impreza 2.5i
Dark Grey Metallic
And what was their outcome?
Old 02-16-2012, 02:13 PM   #1569
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Same problem as on the 05-07 cars.
Old 02-16-2012, 07:52 PM   #1570
Boxerscoopy90
Member#: 309974
I am having a cai on my 2007 its like the cobb one and mine uses a map sensor not maf .. I doubt if u guys know that 2007 subaru uses a map sensor .. But its definitelty not the 2.5i .. Its 1.6 (lol) it takes like a full day to reach 60 haha however gains are very good
Boxerscoopy90 is offline   Reply With Quote
Old 02-16-2012, 09:19 PM   #1571
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I have no idea about the 1.6L engines as they aren't even available in the US. From 2005 on, ALL the non-turbo engines sold in the US use a MAF sensor and have this problem.
Old 02-16-2012, 09:39 PM   #1572
Boxerscoopy90
Member#: 309974
Yes i know u are having the 2.5i only beside the wrx and sti ofcourse and trust me u're better without these 1.6 .. However for ur info its soch and uses a map sensor having only 95 hp and 143 nm trq and its 4wd ofcourse .. There is another na versions like the 2.0R but not available in my country too but its very good using a dohc 160 hp and its engine is too revy till 7.5 rpm but i've heared that dohc na subarus are very hard to tune and u cant just throw ebay uel headers and these stuff u would have to customize one .. Btw i'm from Egypt
Old 02-17-2012, 12:45 PM   #1573
Abill10
Member#: 247862
2010 Impreza Hatch
double post
Abill10 is offline   Reply With Quote
Old 02-17-2012, 12:46 PM   #1574
Abill10
Member#: 247862
2010 Impreza Hatch
Hey guys,
So I just did the hybrid intake using the autozone piping and keeping the stock airbox. I have done this before but took it off for a period of time because i had to do a lot of long distance driving. Well i put it back on today and now the cruise control light is flashing, traction control light is on, and the CEL is on. thoughts? if anyone has any ideas on what happened could you help me out?
Old 02-17-2012, 12:56 PM   #1575
Soul Shinobi
Member#: 130759
2002 Forester S
You likely have an air leak, check everything again. Be sure you didn't tweak any electrical connectors anywhere too.
CAIs, SRIs, and dynos Bluefoton General Community 10 04-09-2008 08:27 PM
problems with 04' sti into an 01' RS help! Imbaru25rs Subaru Conversions 7 02-18-2006 02:40 AM
Any problems with your STI and with SOA? bbbwrx STi Forum Archive 3 08-27-2003 04:32 PM
LOTS of Problems with SOA, Dealer, and MYSUBARU.com saleen90181 Newbies & FAQs 11 11-26-2002 01:37 PM
Anyone with CAI, Unichip and stock turbo? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2002 12:13 PM
