Old 02-17-2012, 01:09 PM   #1576
Abill10
Member#: 247862
2010 Impreza Hatch
Thanks, I re-did the install and now the lights are all off.
Abill10 is offline   Reply With Quote
Old 02-17-2012, 06:11 PM   #1577
ScubyPhilly
Member#: 213303
2009 Impreza 2.5i
I've seen similar issues with those lights coming on, for me it has been that I didn't correctly reconnect the MAF sensor. I just unplug and plug back in, problem solved.
Just a tidbit so you don't have to take the whole thing off in the future.
ScubyPhilly is offline   Reply With Quote
Old 02-20-2012, 07:55 PM   #1578
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
any word on where i can pick up a cheap SRI besides autozone, cus i wanted a legit one like the Injen Sri's (for the hybrid)
Thesystem3 is offline   Reply With Quote
Old 03-18-2012, 11:54 PM   #1579
theluckyone
Member#: 90540
06 Baja
Phew. I read through all 64 pages. Don't I get a medal or something?
Since the world revolves around me (not really; just ask my wife), I thought I'd post a quick synopsis of what I've taken from this informative thread. I apologize if this is an obvious rehash, but typing it out makes it make sense in my head. Besides, if it's incorrect, I bet somebody will correct me :
1. My 2006 Baja has a MAF, since it has an '05 or later EJ25. Therefore, it's intake suffers from the same resonance as every other MAF based 2.5L engine (and maybe MAF-based EJ22s, depending on reports).
2. I cannot replicate the symptoms with a purely stock system, since the snorkus is defeating the intake resonance, as the Subaru engineers designed it to. I mash the throttle at low RPMs while the engine's in a low RPM range, the resonance is cancelled, the MAF does it's job without getting all wonky, and my engine/cat is happy.
3. Should I decide I need a few extra HP on the top end (which I most likely won't directly notice, but since I've put a few bucks into the modification, I'll tell everyone that I can tell the difference), I can go with the hybrid intake. It provides better air flow while retaining the effects of the snorkus, thereby maintaining a happy engine & cat.
theluckyone is offline   Reply With Quote
Old 03-19-2012, 12:22 AM   #1580
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yup, that's pretty much the summation from the first post. The middle 1,577 posts basically were just people going "I CAN HAZ SPECIAL PHYZICS BECAUSE RACECAR!".
Old 03-31-2012, 06:48 PM   #1581
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
Hello all, I'm new to NASIOC. Anyways, thank you williaty for your tests and insight, but I have a question. The pictures for the cosmo cai installed on a 2007 2.5i seems like it will fit with either just one cut or no cuts and it also looks like it comes with a hump coupler too. Will I be able to just use this and a hacksaw to make my hybrid intake? (Note: I ordered the intake before I read this sticky )
Zvbosch is offline   Reply With Quote
Old 03-31-2012, 08:36 PM   #1582
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
I think several people on here have turned the Cosmo CAI into the hybrid intake, so you should be good there. Not sure about the couplers but you'll soon work out if you need another when you get it.
NH8991 is online now   Reply With Quote
Old 04-01-2012, 03:22 PM   #1583
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
Old 04-02-2012, 10:22 AM   #1584
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
That's cheap. So all I do is make it fit, attach the tubing to the throttle body and maf sensor and then attach the other connectors? What are those other connectors for anyways? Sorry, I'm new to cars.
Old 04-02-2012, 11:56 AM   #1585
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
your gonna have to cut it and the fitment wont be perfect, im not sure of the other tubes and connections involved
Old 04-02-2012, 01:27 PM   #1586
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
Do you think I'll only need one cut? http://www.cosmoracing.com/productin...d=150&pid=1499 The picture on this page makes it look like ill only need one.
Old 04-02-2012, 11:08 PM   #1587
Thesystem3
Member#: 233014
2008 Impreza Hatch
Satin White Pearl
Not sure how it would line up, but its pretty expensive to experiment with
Old 04-03-2012, 09:44 AM   #1588
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
Yeah I wish I hadn't bought it.
Old 04-03-2012, 09:51 AM   #1589
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
So I bought that $14 intake and I'm going to return the other. Thanks for posting that.
Old 04-06-2012, 10:46 PM   #1590
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Originally Posted by Thesystem3
Got it. It's on sounds great. No problems.
krzywhtboi82 is offline   Reply With Quote
Old 04-13-2012, 08:34 PM   #1591
jonclarke
Member#: 289159
2007 Impreza 2.5i SE
CGM
Could the hybrid be the reason my head gasket just blew on an 07 with 87500kms?
jonclarke is offline   Reply With Quote
Old 04-13-2012, 08:39 PM   #1592
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The fact that you own a Subaru is why your headgasket let go with so little mileage on it.
Old 04-14-2012, 12:12 AM   #1593
jonclarke
Member#: 289159
CGM
Warrantee job if the cars under 100k? And the tech told me theres some kind of metal ring in the 07's so it shouldn't have blown...
Old 04-14-2012, 01:47 PM   #1594
Zvbosch
Member#: 315047
2007 Impreza 2.5i
Newport BLue
Just installed the hybrid intake yesterday. Took a while to make it fit but its well worth it. I definitely feel better acceleration. There is no noise difference.
Old 04-14-2012, 02:47 PM   #1595
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Tech's a ****ing idiot. The gaskets in an 07 aren't ringed. The 06 and 07 years are actually having the earliest HG failures I've ever seen out of any Subaru.
Old 04-14-2012, 03:19 PM   #1596
jonclarke
Member#: 289159
CGM
Aww man. I thought he was cool. I used to apprentice so I know when someone's trying to bull**** me. I just don't know anything about subie gaskets.
So. I'm reverting my intake back ( will be interesting to compare again) and hopefully the oil change I did a little while ago should t affect my ability to have it fixed user warrantee
So if the intake makes it lean out at higher rpm and im not seeing any changes in engine temp, doesn't that mean the hybrid didn't cause the failure?
Old 04-14-2012, 03:21 PM   #1597
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You'll never see any changes in engine temperature because the stock water temp gauge basically does nothing.
The hybrid didn't cause the failure because an intake CAN'T cause the failure.
Old 05-02-2012, 10:09 AM   #1598
SnowWolfJones
Member#: 318732
1997 Impreza
green
Question intakes
I'm a bit confused (ADHD, sorry =p ). I only made it though about 3 pages or so before the thread got so far beyond topic into other details that I just couldnt stand to read it anymore(64 pages? 0_0 ). so if somebody could make straight-to-the-point sense out of this I'd really appreciate it.
My first Impreza was a 1993 1.8 auto. I took out the stock airbox & pipe but left the snorkus box in the fender well because i couldnt get it out anyway. I installed an AEM knockoff intake from eBay (typical setup - pipe, double cone (W) filter, silicone lines & couplers, MAF adapter plate). I LOVED that loud intake sound, especially since it was controllable - it was only loud when I really wanted it to be. I'm no sunday driver, I know how to really enjoy a subaru. And I wasn't worried about gas mileage, because a 4 cylinder car is only going to burn so much - I was getting about 18-20mpg whether I was haulin @$$ or sippin gas, didnt matter either way. It eventuallly got old & slow (just shy of 200kmi). That car rotted out real bad from northeast PA road salt & I got rid of it.
NOW I've got a 97 impreza wagon 2.2 5 speed. I haven't changed anything on it yet besides a new water pump & timing belt, & dropping a fram air filter in the box. It needs a new exhaust, the mid pipe is just resting in the hollow muffler can & i slid the tail pipe right out leaving just the hole. Sounds like a diesel truck lol It seems it's not worth doing anything for performance because it has single port heads & i cant find hardly anything for it outside of generic bolt-ons (not that I know where to look for old car goodies, besides eBay & Andy's Auto Sport). Sure, I'd like it to be a quick car. I'd love to be able to raise hell on the back roads & powerslide etc, but I'm not prepared to spend $1500 on another motor etc right now. I'm no tuner & I don't race - I just love nice Imprezas. Im thinking my best bet with this car is to focus on sound & style while saving up towards another car with some 2.5 power.
But back on topic... in my case, having a 97 ej22, is it really going to hurt anything besides gas mileage by having a full cold air intake instead of a hybrid setup? and does it make a difference whether I use a solid aluminum pipe vs a flex pipe like Spectre's memory position air ducting? Any other suggestions about easy ways to squeeze the good stuff out of a 2.2?
Thanks in advance for the (appropriate) replies, I do appreciate it.
-Snow-
SnowWolfJones is offline   Reply With Quote
Old 05-03-2012, 12:12 PM   #1599
ScubyPhilly
Member#: 213303
2009 Impreza 2.5i
Default A/F Ratios
Originally Posted by SnowWolfJones View Post
I'm a bit confused (ADHD, sorry =p ). I only made it though about 3 pages...
...But back on topic... in my case, having a 97 ej22, is it really going to hurt anything besides gas mileage...
-Snow-
I used to run the delete and thought, "whatevs I don't care about fuel mileage," I still don't really care about mileage, but recently I've learned myself a lot about EFI and how A/F ratios should be taken seriously. With my recent, noobish, knowledge of EFI I decided that it's just not acceptable to have my MAF that far from reality so I threw everything back in my car and will be looking into getting a hybrid in the near future.
Long story short, no. It does not just hurt fuel mileage. I'm not versed enough in engine management to tell you what all will be hurt, but when the MAF spikes it dumps fuel or cuts fuel, leading to extreme rich or lean conditions.
I'm sure Williaty will be back in here soon.
Old 07-02-2012, 10:32 PM   #1600
jhigs1220
Member#: 323170
06 impreza 2.5i
nice i would stick with my cosmo racing short ram
jhigs1220 is offline   Reply With Quote
CAIs, SRIs, and dynos Bluefoton General Community 10 04-09-2008 08:27 PM
problems with 04' sti into an 01' RS help! Imbaru25rs Subaru Conversions 7 02-18-2006 02:40 AM
Any problems with your STI and with SOA? bbbwrx STi Forum Archive 3 08-27-2003 04:32 PM
LOTS of Problems with SOA, Dealer, and MYSUBARU.com saleen90181 Newbies & FAQs 11 11-26-2002 01:37 PM
Anyone with CAI, Unichip and stock turbo? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2002 12:13 PM
