Old 03-16-2008, 12:44 AM   #1
boostedsti06
Member#: 128677
2006 Subaru WRX STI
obsidian black pearl
Default Why is my a/c not blowing ice cold ???
i have an 06 sti with 41,000 miles and my a/c blows cold but not ice cold ??? What do you guys think is wrong with it ??? does it just need recharged or what ????? btw i live in az
boostedsti06 is offline   Reply With Quote
Old 03-16-2008, 01:13 AM   #2
STIBungy
Member#: 51684
You could have it evacuated to see how much is left. Then they can refill it and charge you accordingly.
STIBungy is online now   Reply With Quote
Old 03-16-2008, 03:10 AM   #3
bushiwarrior
Member#: 169536
re-gas or head gasket
bushiwarrior is offline   Reply With Quote
Old 03-16-2008, 04:28 AM   #4
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Just refill it or do like i did and pull the whole system out and say the hell with it!
rek888v2 is offline   Reply With Quote
Old 03-16-2008, 09:09 AM   #5
WRXLTD
Member#: 136314
2014 Grand Cherokee
If all it just needs is a refill...you're lucky. Get it refilled right away.
Remember, if it needed a refill...you have a leak somewhere. Not only does the Freon keep the seals moist, it also has lubricate in it to keep the compressor from seizing.
WRXLTD is offline   Reply With Quote
Old 03-16-2008, 09:19 AM   #6
DuckStu
Member#: 124060
2004 WRX STI
You can buy a refill can of H134a at the autoparts store or WalMart that has a hose and a guage on it. $25 I think. You add in gas until the arrow is in the green. Simple.
I found a problem on my 2004 STI though. The acumulator (or reciever dryer) on the passanger side of the condenser and the condenser (A/C rad in front of the engine radiator) were rubbing each other. There is a leak there now I believe.
I'll have to pull the nose soon and inspect.
DuckStu is offline   Reply With Quote
Old 03-16-2008, 10:33 AM   #7
Fred Fredburger
Member#: 2539
2005 STi WRB/Gold
Now w/Íhlins... Yessss!!!
The FIRST thing to check is the condenser! I went thru this last summer with my '05. It wasn't blowing cold at all so I figured it was low, put in a can of juice and it seized up my compressor (since it wasn't really low).
What you can do is have a buddy hold a garden hose near the top of your condenser (the A/C "radiator" in front of your regular radiator) and see if it blows cold. If it does blow cold that means that the condenser is plugged up with bugs or bent fins. I could see the condenser was full of bugs in the bumper holes below/next to the license plate. I went to an A/C place and they had fab'd some sort of power nozzle that they were able to fit between the condenser and the radiator to blow the bugs back out the front.
So, I wasted money on 1) the can of juice I bought, 2) having to get the system refilled after I had to bleed out all (since I overfilled it) and 3) having the A/C place clean out the condenser. Also, the compressor started worked again after bleeding out all the juice and having it professionally filled so I consider myself lucky notdamaging the compressor.
Fred Fredburger is offline   Reply With Quote
Old 03-16-2008, 01:06 PM   #8
STIred05
Member#: 115223
2005 Subaru STI
What has the temp been there in AZ? If it is cool enough the A/C will only turn on for a short time then kick off i.e. it wont get cold, it will get cool though. You could also check your condenser. Look at it for any oil on it. Other then that just get it refilled.
STIred05 is offline   Reply With Quote
Old 03-16-2008, 07:38 PM   #9
boostedsti06
Member#: 128677
2006 Subaru WRX STI
it was about 80 deg here when i had it on
Old 03-16-2008, 07:43 PM   #10
mugenXP
Member#: 155272
2006 WRX
Panda AE86
try it another time, some days it doesnt feel as cold because you may feel more hot from the weather and the sun and etc.
mugenXP is offline   Reply With Quote
Old 03-16-2008, 09:38 PM   #11
vwsti05
Member#: 144399
2005 WRX STi stage 2
white Romraider tuned
Default ac
what do you mean "ice cold", you do know it is just a "air conditioner" right? its only meant to cool the air not freeze and have ice cube shoot out at you!! you may just need a evacuate and recharge, and have some dye put into the system to see if you have a leak.
vwsti05 is offline   Reply With Quote
Old 03-17-2008, 11:34 AM   #12
Fred Fredburger
Member#: 2539
2005 STi WRB/Gold
Have you tried to have a buddy hose down your condenser (A/C radiator in front of your coolant radiator) while you sit in the car to see if it gets any cooler?
Old 03-17-2008, 11:59 AM   #13
Roamrex
Member#: 171487
06 WRX Wagon
SGM
its climate control, dont expect the a/c to blow ice cold air when you turn it up to the coldest temp. try turning it to 65 F when its 40F outside and its going to blow warm slightly cold air.
Roamrex is offline   Reply With Quote
Old 03-17-2008, 05:39 PM   #14
MonkeyKarma
Member#: 147206
02 WRX
Blue of course
Also how fast were you going? Remember the harder you are on the gas pedal the less the AC will work.
MonkeyKarma is offline   Reply With Quote
Why is my car blowing smoke? cooter1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-08-2008 07:23 PM
why is my blow off valve squirting oil ??????? TurboCharged97L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-04-2006 04:31 PM
Why is my utec not speaking to my computer? romanelli Engine Management & Tuning 1 01-28-2006 02:40 PM
why is my bov louder when my car is cold sam caldwell Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-28-2005 09:02 PM
('93-'01) why is my signiture not working?? Rubasu Impreza Forum 1 07-27-2001 07:07 AM
