Old 03-16-2008, 01:19 PM   #1
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
Default oil change ? jack or flat
when i go to take out the drain plug and fliter, i will have to jack the car up to get under there, but should i put it back down while the oil is draining?
also, in the subymods how-to, they said to take of the oil filter first, let the oil drain and then do the drain plug. would it be a problem if i did the drain plug first and then the filter? it seems doing the filter first would make much more of a mess.
I Love Boobies is offline   Reply With Quote
Old 03-16-2008, 01:54 PM   #2
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I drive up on rhino ramps, take out the drain plug first, wait, than take the oil filter off. Been doing that way for 7 years, and almost 50 oil changes.
rexman2002 is offline   Reply With Quote
Old 03-16-2008, 02:32 PM   #3
Arctic Penguin
Member#: 119532
2006 WRX
I run my car up on some 2x6 pieces and it is high enough to get under
my driveway also has a slight slope to it so i park with the nose downhill and it is just fine
Arctic Penguin is offline   Reply With Quote
Old 03-16-2008, 04:34 PM   #4
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
so i guess it really does not matter, flat or lifted on an angle. i have the option to do either so which would u recommended?
Old 03-16-2008, 07:02 PM   #5
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
It really doesn't matter. I recommend doing whatever works out easier for you.
bulwnkl is offline   Reply With Quote
Old 03-16-2008, 11:42 PM   #6
subySerb
Member#: 155411
07 Impreza
I jack up the car to get the plug off, then lower the car after a while to increase the flow. If the flow doesn't change i just leave it up.
subySerb is offline   Reply With Quote
Old 03-17-2008, 08:45 AM   #7
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
I'm able to get under there with a pan without taking the car off the ground. I love it. Easy oil changes ftw!
Doc Holiday is offline   Reply With Quote
Old 03-17-2008, 09:54 AM   #8
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Just make sure that if you don't use ramps and use a jack that you use jack stands also. Just had a friend lose his son last week when the jack he used gave way and crushed him. He just got under it quick to check his oil filter to see if it was lose. RP
drivin blind is offline   Reply With Quote
Old 03-17-2008, 12:17 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
Thats horrible, sorry to hear that.
If you are not sure if your car is supported well enough, then it isn't. Jack stands are the best assurance you can have (on a solid surface). I've used ramps for years and have never had a doubt about their safety tho.
On the '02 wrx, the pan plug is towards the rear, so raising the front IMHO is better.
In reality, flat or front raised, not much of a difference.
strohausii is offline   Reply With Quote
Old 03-17-2008, 08:53 PM   #10
nardvark
Member#: 145108
2002 Impreza TS
I can reach the drain plug just fine without ramps, but I have monkey arms. The filter, on the other hand, is in the absolute worst possible place, and getting to it without ramps (or jacking it) is a gigantic pain.
Just leave the car up while it drains, don't bother moving it until you're done. Check the level when it's flat, not on the ramps, of course.
nardvark is offline   Reply With Quote
Old 03-17-2008, 09:58 PM   #11
subySerb
Member#: 155411
07 Impreza
while we're on topic of rasing cars, where should i put the jack when raising it?
Old 03-18-2008, 07:52 AM   #12
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Check your service manual when in doubt.
If you want to do one wheel at a time the jack points are just behind the front wheels and just infront of the rear wheels. You can also use the rear diff if you want to raise the back of the car, or the front cross member if you want to jack up the front.
ALWAYS USE JACKSTANDS
scroll down through this thread to see a good diagram of the jackpoints for your scooby:
http://forums.nasioc.com/forums/show...ght=jack+point
Old 03-18-2008, 08:15 AM   #13
subySerb
Member#: 155411
07 Impreza
thanks, i know about the jackpoints next to the wheels, but i was thankinging that it would be better to jack it up somewhere in the middle and a front cross member would be perfect for that. yes i always use jackstands.
Old 03-18-2008, 10:30 AM   #14
jays05
Member#: 78165
05 STI 35r + e85
I left the undertray off and can change my oil/filter with the car on the ground, no problems.
jays05 is offline   Reply With Quote
Old 03-18-2008, 12:33 PM   #15
Chino Bling
Member#: 129743
2004 WRX
i have a fumoto drain valve, so not i only change the oil on flat ground, but i dont need any tools either.
Chino Bling is offline   Reply With Quote
Old 03-18-2008, 12:34 PM   #16
SubieRon
Member#: 64485
2004 GGA
i go up some 2"x6", then i jack it up, place ramps underneath, move the jack to the drivers side and have it up as back up...then i remove the splash guard and do the oil change.
be safe
SubieRon is offline   Reply With Quote
Gear Oil Change??? wickkerr82 Newbies & FAQs 6 06-04-2010 01:35 PM
Jack or Ramp for oil change? FreytheViking Newbies & FAQs 33 07-09-2009 08:42 PM
05 STI, First Oil Change 1k or 3k? ixusracing Service & Maintenance 20 02-04-2005 09:55 PM
Oil Change (FUD or not)? Arcanum5 General Community 13 07-22-2004 07:14 PM
1st oil change - 1K or 3K wuckers Forester Forum 6 07-24-2003 01:10 PM
Message Board Statistics All times are GMT -4. The time now is 09:52 AM.
