Old 03-17-2008, 03:20 PM   #26
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by ej20ajk View Post
thats why Hondas never have this issues!
Old 03-17-2008, 03:44 PM   #27
subyduby
Member#: 107889
04 wrx 16g'd
Default 1st gear
Originally Posted by sexycat View Post
i heard people saying first gear is the weakest one.
1st gear is pretty big compared to the other gears in the box. It has to take alot of abuse, just to get the car moving...and therefor launching. I would not recommend launching on the stock box too often, otherwise, YES, something will break.
subyduby is offline   Reply With Quote
Old 03-17-2008, 07:13 PM   #28
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
I am on my 2nd trans. I had a lightly modified 2.0 wrx, no problems at all. probably 230 whp. When to 2.5 with td04 (talk about torque) for 6 months, no problems. Went to vf22 and 2.5. Blew up tranny 4 months later. Rebuilt trans. Continued to run vf22 for 5 months, went back to td04, upgrade to a 20g 1 month later. Tranny lasted 2 months.
I dont slam my gears but they are constantly being pounded with over 300 whp.
I lost 3, 4, and 5, 2 weekends ago.
NITROS is offline   Reply With Quote
Old 03-17-2008, 09:01 PM   #29
kloo413
Member#: 156840
2006 STi
Do not drop the clutch, do not launch your car, perform smooth engagements w/ the clutch when performing spirited driving. Treat your car like how you want to be treated. You don't want someone breathing down your neck and telling you to run a marathon while kicking you in the ass (ie. Ripping thru the gears and launching car)
kloo413 is offline   Reply With Quote
Old 03-18-2008, 10:07 AM   #30
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
over 145k on stock tranny.
second stock clutch at 132k.
over 300whp on high boost..
autox monthly..spirited driving..
and daily driver..
learn how to slip the clutch..way cheaper than tranny..
Old 03-18-2008, 10:53 AM   #31
David L.
Member#: 130632
2002 Z28 35th Ann.
Pewter
I have been running 310whp/330wtq on an 18g'd 06 WRX for over 20k now and have had no issues. I am getting ready to start running alky and will be pushing higher numbers.
As most people have said, it is all in how you drive it, and how hard you are willing to push it...
David L. is offline   Reply With Quote
Old 03-18-2008, 11:01 AM   #32
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
You should be fine under 300whp, when you start getting over 300 is when the risk factor rises signifgantly.
When you break 350wtq/whp is when it becomes more of a when and not a IF.
My tranny lasted ~3 months on a clipped td06H-20g running a tial 44mm external, never 1 launch, no racing, no hard shifts, absolutely no abuse and original clutch was holding strong. Broke 3rd casually passing someone on the way to work.
I previously ran a VF making over 350wtq for the previous year.
Mine broke at 35,000. Breaking in my 6spd now and never looking back.
sluflyer06 is offline   Reply With Quote
Old 03-18-2008, 11:56 AM   #33
shakur45
Member#: 165106
2017 WRX
Gray
Originally Posted by Ryan314 View Post
Fail.
Yea man, no street racing
shakur45 is offline   Reply With Quote
Old 03-18-2008, 12:37 PM   #34
smurfwrx
Member#: 151928
09 Triumph S3
unless you're in a school zone or racing a school bus. Then it's ok.
smurfwrx is offline   Reply With Quote
Old 03-18-2008, 09:34 PM   #35
02RexWI
Member#: 165141
Dont go the route my buddy went- Bought car @stage 2 on it's 2nd. trans, blew one after ~10k. mi, had it re-built w/ no warranty, and that one lasted 3k miles.
02RexWI is offline   Reply With Quote
Old 03-19-2008, 01:47 AM   #36
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
rexman2002 is offline   Reply With Quote
Old 03-19-2008, 09:25 AM   #37
CSCSATCWRX
Member#: 140032
06 vf43 wrx R.I.P.
09 forester 2.5x
I will be heading for 300awhp soon but first I'm throwin in a set of micropolished RA's while my stock set is still worth something. You should be fine as long as you don't abuse it. I'm just being proactive, and would rather have RA ratios. good luck
CSCSATCWRX is offline   Reply With Quote
Old 03-19-2008, 12:09 PM   #38
bzbuzz
Member#: 116052
2011 STI ( Sold )
<--- my power... and my clutch is getting bad...no slipping yet but i can feel its getting weaker... no tranny issues yet...
bzbuzz is offline   Reply With Quote
Old 03-19-2008, 06:16 PM   #39
Chino Bling
Member#: 129743
2009 335i
Jet Black
my stock tranny lasted about six hours after i got tuned on a vf34 and all other supporting mods.
Chino Bling is offline   Reply With Quote
Old 03-19-2008, 07:23 PM   #40
2ndGearFling
Member#: 64466
05, STI on green
I lasted about 35k being extremly careful going into 2nd.....it will blow, just a matter of time.
2ndGearFling is offline   Reply With Quote
Old 03-22-2008, 12:34 AM   #41
POPOFF
Member#: 107266
2006 20g-366/401
Whitey/Blackie
Tranny is fine after an evening of abuse down the 1/4 mile. Clutch started to let go on the 23 psi map.
POPOFF is offline   Reply With Quote
Old 03-22-2008, 01:15 AM   #42
sidewayz
Member#: 5810
2001 S366 2.5RS
popped a trans on a stage2. 1-2 **** did it in. Lost a second trans merging into traffic just laying into 2nd gear..
PPG's now with a ton of 6k clutch dumps.
sidewayz is offline   Reply With Quote
Old 03-24-2008, 01:44 PM   #43
dwike
Member#: 103209
02 STI'd Wagon
Default Its torque
Below you will see what happens when you try to send 350wtq through an 02 tranny! When I pulled the plug to drain the fluid there as quite a "gritty" bunch of sludge.I NEVER bang gears and I mean it, never. This was a second gear rolling of the throttle not a shift, but the vf34 makes 350wtq at $4k and when that kicks in on a cold winters day, it's more than an 02 tranny can take. Oh, only 280whp btw.
I finally got the tranny out and got to take a look at the second gear gone!
and if you look closely at this picture you'll see all the gears that were stripped and laying in the pan of the tranny case
dwike is offline   Reply With Quote
Old 03-24-2008, 04:30 PM   #44
POPOFF
Member#: 107266
2006 20g-366/401
Whitey/Blackie
^^^ouch!!!
Old 03-24-2008, 10:02 PM   #45
xreign
Member#: 123859
06 STI 330hp/357lb
hm... i miss my nissan days 240sx FTW bangin gears all day every day couldn't break the thing to save my life. Was launching it in 2n'd gear while boosting 17psi haha fast as hell!!! My subie remains stock at stock hp and is babied when you find a cheaper solution to good gears hit me up
xreign is offline   Reply With Quote
Old 03-24-2008, 11:06 PM   #46
GlobalWaste
Member#: 74792
<pics>
Is that scotty's cocktail I see in there?
GlobalWaste is offline   Reply With Quote
Old 03-25-2008, 05:19 AM   #47
MindzeyeWRX02
Member#: 145138
2002 Impreza WRX
WR Blue
i have a 2.5 shorty in my car using the td04, torque is crazy fun!! still on my stock tranny, but i already feel the new block killing it. hahaha. i drive like my grandma now so it will last me long enough to save up for a 6mt, after that i'll never have to worry about the tranny again. oh and dccd will be nice, especially with the 04-05 transmissions.
MindzeyeWRX02 is offline   Reply With Quote
Old 03-25-2008, 10:44 AM   #48
dwike
Member#: 103209
02 STI'd Wagon
No its redline lightweight shockproof, shockproof, now thats funny...
Old 03-25-2008, 02:09 PM   #49
gling
Member#: 122654
2002 v8 STI w/ GT30R
2013 GTR & M-Sport 335xi
300+ whp but more importantly, 300+ wtq for over 35k mi. on a stock 02 tranny. Like most others have said, drive without banging gears and launch properly if you want to launch, and your tranny should last you a while.
gling is offline   Reply With Quote
Old 03-26-2008, 03:18 AM   #50
GlobalWaste
Member#: 74792
Ah, that's part of the combo anyway, the signature colour heh
The only people who get 5spd trannies surviving at A TRUE 300whp (usually more like 350 nasioc whp ) are the ones who don't do much more then commute around town and do highway pulls
Whose 06 WRX stock tranny is surviving 300+ whp? eggeegg Transmission (AT/MT) & Driveline 1 05-08-2007 07:46 PM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket SCIC Private Classifieds 31 02-07-2007 02:01 AM
2002 WRX 2.5 Liter 300 WHP 300 WTQ Wrocket Private Vehicle 'For Sale' Classifieds 32 02-07-2007 02:00 AM
2006 WRX w/ VF39 owners- how's your tranny? deblas66 Transmission (AT/MT) & Driveline 17 01-07-2007 01:59 PM
Selling 02 WRX silver over 300 whp in So Cal TitanWRX Private Vehicle 'For Sale' Classifieds 3 05-24-2005 02:41 PM
