Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 03-16-2008, 11:42 PM   #1
WhiteFox
Member#: 117606
2005 FXT
Default How bad is it really, to have 2 different sets of tires on an AWD car?
I have a pair of like new tires that would fit my summer wheels, but I need another pair for the other 2 wheels. Is it really a big deal to not buy a set of 4 tires? Do the diameter of the tires have to be EXACTLY the same, or can the center diff deal with it?
WhiteFox is offline   Reply With Quote
Old 03-17-2008, 01:17 AM   #2
Arctic Penguin
Member#: 119532
2006 WRX
the rollout MUST be within 1/4" for all tires when mounted
the center diff isnt happy otherwise
Arctic Penguin is offline   Reply With Quote
Old 03-17-2008, 03:00 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
how much of a factor does 'grip' play?
Old 03-17-2008, 09:52 AM   #4
krzyss
Member#: 8365
2013 Ford Focus SE
Different pairs but size within limit?
I suspect that you would need to remeasure the tires from time to time to verify that they are still within limit. What if smaller diameter wears faster?
Krzys
krzyss is offline   Reply With Quote
Old 03-17-2008, 12:48 PM   #5
WhiteFox
Member#: 117606
2005 FXT
I've run with 2 different sets of tires without any problems for a while, but it's time for new tires, but I already have a pair of slightly used tires, I just need a matching pair. I'll have to measure the tires to make sure the circumferences are the same, or at least close.
Old 03-17-2008, 12:58 PM   #6
shatteringstar
Member#: 149604
2006 Limited WRX
are u talking about like running a 215/45 up front and a 225/45 in the rear?
b/c im not sure if thats allowed or not and im curious for an answer on that myself.
shatteringstar is offline   Reply With Quote
Old 03-17-2008, 03:38 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
For the short term, you should be ok, but I wouldn't use that setup as a long term solution.
I ran mismatched snow tires (same size, but one was about .5" wider diameter than the other set) for one winter, it did fine, but I went to a matched set the next winter...
rougeben83 is offline   Reply With Quote
Old 03-17-2008, 06:20 PM   #8
Arctic Penguin
Member#: 119532
2006 WRX
THAT would kill the center diff
fo sho
Old 03-17-2008, 07:32 PM   #9
WhiteFox
Member#: 117606
2005 FXT
No all the same size tires, like 245/45/18 but different brands/mileage on the front vs rear.
Old 03-18-2008, 06:06 PM   #10
Sportbiker40
Member#: 143041
2004 WRX Wagon
The Brand doesnt matter.. Its like they said in the above.. All tires have to be within 1/4 inch..
Example.. One Summer I used 215/45's in the front and 245/40's in the rear.. It looked really cool. It wouldnt pass inspection like that though..
Even though the tires were diff sizes the overall Circum. was about 1/8 of an inch diff between the front and the rear.
This year Im gonna run 245/40's all round
Sportbiker40 is offline   Reply With Quote
Old 03-19-2008, 12:35 PM   #11
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
If the circumferences are close enough, then the diffs will be OK. However you may run into problems when you push the tires to the llimit or use them in reduced traction. Mismatched tires front/rear can be perfectly fine when it's dry, but give you extreme over/understeer in rain.
bluescoobywagon is offline   Reply With Quote
Old 03-19-2008, 03:09 PM   #12
DapRex
Member#: 53308
2004 Impreza Wrx
the bestest colour
A month after I bought my 04 I ran over a self tapping sheet metal screw. I took it to a tire place, told them i wanted a patch since it was practically brand new.
Well he took the tire off and said oh my, I cant put a patch thar! and tried to sell me 4 tires. I just bought one but it wasnt the same brand, and I ran that set up for oh 60k or something.
Not that it helps, just thought id share
DapRex is offline   Reply With Quote
Old 03-19-2008, 04:22 PM   #13
internet ankle-biter
Member#: 150179
what the manual says is:
"All four tires must be the same in
terms of manufacturer, brand
(tread pattern), construction, degree
of wear, speed symbol, load
index and size. Mixing tires of different
types, sizes or degrees of
wear can result in damage to vehicle’s
power train. Use of different
types or sizes of tires can also
dangerously reduce controllability
and braking performance and
can lead to an accident."
internet ankle-biter is offline   Reply With Quote
How hard is it really to do a clutch? tabrad Rocky Mountains Impreza Club Forum -- RMIC 20 07-18-2009 08:46 AM
So how bad is it really to have 2 different types of tires on the front and rear? 0260B4U Tire & Wheel 4 10-01-2008 01:09 AM
2 different sets of tires on a gc jakeachy Newbies & FAQs 6 11-26-2007 10:08 PM
2 Different Sets of Tires slayers_x Tire & Wheel 6 04-19-2007 11:48 PM
Rotating tires on an AWD car... Paraskass Tire & Wheel 7 09-21-2006 07:13 PM
