Old 03-17-2008, 12:54 AM   #1
John Smith
Member#: 115251
2006 WRX- VF39'd
Default New RA gear set- 3, 4, 5 gone?
MODS that could have contributed:
TBE
APv2
Wed 17x 7.5
So I upgrade my tanny to RA 1-4. Wanted something a little better then stock, didnít want a 6 speed and PPG was too much coin for me. I wanted to get a tranny that could hold a 20g with a little nicer ratio's.
So today I was driving around and I went from a stop sign 1 to about 4k then second to about 37xx. (This wasnít balls to the all 4k rev, but a long slow long rev to about 4k)
Then while I was setting the gear into 3rd I had a POP or some kind of noise. (This was before I engaged the tranny)
Now I have no 3,4 or 5th gear
Any ideas?
Shifter fork?
I had it taken to the shop that did the work to try and figure out wtf is going on.
John Smith is offline   Reply With Quote
Old 03-17-2008, 01:04 AM   #2
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
sounds like a bad install job
subaruNV is offline   Reply With Quote
Old 03-17-2008, 02:35 AM   #3
SpADeZ_WRX
Member#: 160871
Wow deff curious to hear what happened
SpADeZ_WRX is offline   Reply With Quote
Old 03-17-2008, 10:00 PM   #4
John Smith
Member#: 115251
2006 WRX- VF39'd
bump anyone?
Old 03-18-2008, 09:05 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sounds like shifter fork..bad install..
got reverse?
Old 03-18-2008, 12:55 PM   #6
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
Install issues... I don't see how you would tear up 3 gears at one time off power. Sounds like some shift fork issues or something along those lines.
jhargis is offline   Reply With Quote
Old 03-18-2008, 01:33 PM   #7
DS1
Vendor
Member#: 111780
Can you not put it in the gears or if you do does it just not move?
If you can't get the shifter to go into thos gears it sounds like you may have lost one gear and the pieces are lodged in the internal shifter linkage.
-Dylan
DS1 is offline   Reply With Quote
Old 03-18-2008, 03:26 PM   #8
John Smith
Member#: 115251
2006 WRX- VF39'd
So we opened her up today. Mainshaft looks like it was cut after second gear.
I am asking the mfg to replace the shaft and to reimburse for the labor again/oil.
Anyone have this problem? Any hints or suggestions on having them reimburse for labor and materials?
(pictures of wrx tranny)
http://images.google.com/imgres?imgu...%3D1%26hl%3Den
Old 03-18-2008, 03:51 PM   #9
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
This sounds exactly like something that happen to me 2 weeks ago. I havent removed the transmission out of the car yet. But i also lost 3,4,5. Shifts into them fine but the car doesnt movie anywhere. and tehre is no noise.
There is considerably more whine in 1st and 2nd. Do you have pictures of the failure?
NITROS is offline   Reply With Quote
Old 03-18-2008, 03:59 PM   #10
John Smith
Member#: 115251
2006 WRX- VF39'd
NO I do not.
PM where you got your gear set from. Maybe just a bad patch of material or something.
Also PM your email address I will send pics when I get them
Old 03-18-2008, 04:04 PM   #11
NITROS
Member#: 41561
04 GT3076 2.1
NO I do not.
I do not have an RA gearset. I had a stock 04 wrx gearset. I blew 3 last year and had it replaced. re-used the same input shaft, and what not.
Old 03-18-2008, 09:31 PM   #12
John Smith
Member#: 115251
2006 WRX- VF39'd
will keep you posted!
Old 03-19-2008, 12:46 PM   #13
DS1
Vendor
Member#: 111780
No offense but Subaru isn't going to cover the defective shaft.
There probably was a defect in the shaft but since you used it in a trans in which it wasn't designed for they are simply going to tell you you're out of luck
-Dylan @ DS1
Old 03-19-2008, 01:53 PM   #14
John Smith
Member#: 115251
2006 WRX- VF39'd
Not Subaru!
MFG of the gears~
I got RA GEAR SET from IA performance.
http://www.iaperformance.com/product...roducts_id=780
Comes with everything. Should be a new RA mainshaft
Old 03-19-2008, 02:18 PM   #15
DS1
Vendor
Member#: 111780
^^ right but IA doesn't manufacture them they only resell them.
Old 03-19-2008, 03:14 PM   #16
John Smith
Member#: 115251
2006 WRX- VF39'd
I am trying to go for the mfg of the gear set. Not subaru. Is what I am trying to get at!
Old 03-19-2008, 03:28 PM   #17
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Good luck........i hope it works out for you.
JMK508 is offline   Reply With Quote
Old 03-19-2008, 05:04 PM   #18
DS1
Vendor
Member#: 111780
The mfg of the gear set is Subaru of Japan
Old 03-19-2008, 05:05 PM   #19
John Smith
Member#: 115251
2006 WRX- VF39'd
wow. didnt know that!
Old 03-19-2008, 06:10 PM   #20
foolio
Member#: 9351
2006 trailblazer SS
black
Post those pics. I'd like to see it. That would be something I have never seen before.
foolio is offline   Reply With Quote
Old 03-19-2008, 06:22 PM   #21
2ndGearFling
Member#: 64466
05, STI on green
Ahh....the wonders of the 5 speed.
2ndGearFling is offline   Reply With Quote
Old 03-19-2008, 06:23 PM   #22
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
John Smith - a new input shaft will be on its way to your shortly. I should have tracking before the end of today. As I mentioned on the phone, we try to go above and beyond to help Granted we are not the manufacturer, Subaru of Japan is. We're merely a reseller that tries to put in a little extra effort
Stephen
IA Performance is offline   Reply With Quote
Old 03-19-2008, 06:42 PM   #23
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Originally Posted by 2ndGearFling View Post
Ahh....the wonders of RA garbage gears.
All better now.
Props to IA.
fujiillin is offline   Reply With Quote
Old 03-19-2008, 07:01 PM   #24
DS1
Vendor
Member#: 111780
Stephen @ IA to the rescue
Now that's customer sevice!
-Dylan @ DS1
Old 03-19-2008, 07:57 PM   #25
John Smith
Member#: 115251
2006 WRX- VF39'd
Stephen
Stephen and IA performance have really be amazing to work with on this. I am still going to get some pic for everyone.
P.S. Stephen I use that license plate bracket! Because of your amazing customer service and killer deals!( You will see it when I take a pic)
Brand New RA Gear Set W/syncros silversubiedude Drivetrain 11 08-27-2008 04:08 PM
Stock 03 wrx gears 1,3,4,5 & OEM clutch/flywheel drewwrxrogers Drivetrain 14 05-11-2007 09:05 AM
Gimmie gears 1-2, RA 3, 4, 5 possible? Hondaslayer Transmission (AT/MT) & Driveline 2 04-20-2004 11:41 PM
Anybody running the v5/6 RA gear set w/ a 4.444 final drive? BIGSKYWRX Transmission (AT/MT) & Driveline 8 10-11-2003 10:33 PM
Close ratio STi type RA gear set and 4.44 superg Transmission (AT/MT) & Driveline 6 06-19-2003 01:49 AM
