03-17-2008, 12:19 PM | #1 |
Member#: 166392
Vehicle:1996 240sx White |
Check engine codes on a JDM w/OBDII ??
Is it possible to use a obd2 scanner on a jdm ecu? It has the obd2 plug with 7 wires coming out of it but i cant seem to get my obd software to scan it. I might have the wiring wrong but there is only 7 wires so it cant be hard to fix if that is the case...
Has anyone done this? Is it possible?
03-17-2008, 01:37 PM | #2 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
what jdm ecu
ver 5+ have some of the obd-2 the older ones have obd-1 like protocol that an old SSM can be hooked up to |
03-17-2008, 03:32 PM | #3 |
Member#: 166392
i have a ver 5 i think it is a late 98 or early 99 year.
it has an obd2 plug in the factory harness but 3 wires were cut and i am not sure if i hooked em up correct when doing a merge with the 95 harness. |
Check engine light on.... car throws two codes. Why!!!! | subie_nation | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 02-18-2009 03:11 AM |
Quick question on check engine code? | 04subyrex | Newbies & FAQs | 12 | 11-21-2007 03:25 PM |
Check engine codes | Wildman | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-21-2001 07:04 PM |
Check Engine Code P0302, "#2 Misfire" | hillman | Legacy Forum | 5 | 06-26-2001 03:14 PM |
Check engine codes | Kruf | General Forum Archive | 1 | 12-17-2000 05:46 AM |
