Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 03-17-2008, 12:46 PM   #1
striker525
Member#: 93503
2008 STI
Gray
Question P0325
My 98 Impreza is throwing a code. P0325 - knock sensor 1 circuit malfunction bank 1 or 1 sensor. The check engine light came on 2 days ago and since then has gone off and come back on twice. Anyway I called a Subie Dealer near me and they said usually they just replace the sensor when this code comes up. So my 1st question is, is that true, that code doesn't signify anything but the fact that the sensor needs to be replaced? Question 2, where is this specific sensor located and is there anything special i have to do in order to put a new one in, is it just unplug, replace, replug???
thanks guys, you all rock
Nick
striker525 is offline   Reply With Quote
Old 03-17-2008, 12:54 PM   #2
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Yeah, it's the sensor gone bad. Same thing on the Forester, intermittent until steady CEL, crappy gas mileage also.
Got a new one from SGP for around $75. It's in a slightly tough spot, straight under the throttle body. Just be sure to follow torque specs (11-14 lbs.), sensor damages easily.
edit:http://www.scoobymods.com/forums/showthread.php?t=4039
And it is just like you said, unplug the old one, plug the new in, that's it.
surowrxa is offline   Reply With Quote
Old 03-17-2008, 03:14 PM   #3
striker525
Member#: 93503
2008 STI
Gray
Oh man thanks a bunch, I just have one last question,what's the deal with the angles???
need help! p0325 fosingwo Normally Aspirated Powertrain 12 09-14-2005 02:48 PM
help cel p0325 fosingwo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-19-2005 10:08 AM
P0325 - Knock Sensor Circuit Malfunction joltdudeuc Normally Aspirated Powertrain 4 05-31-2004 08:29 PM
P0325 - Knock Sensor Circuit Malfunction goobie Normally Aspirated Powertrain 3 09-04-2003 09:09 AM
Cel P0325 youthanasia Vancouver Impreza Club Forum -- VIC 8 09-02-2003 09:39 PM
