Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 03-17-2008, 12:49 PM   #1
Destroy
Member#: 22997
Default What should I gap 07 STI NGK 1 heat range colder plugs to??
Thanks for the help.
Destroy is offline   Reply With Quote
Old 03-17-2008, 01:35 PM   #2
camshaft06
Member#: 149694
2005 Stage 2 Sti
CGM
I believe it is 0.030". But some one please correct me if I am wrong. You can always call the dealer too, they should be able to tell you for sure.
camshaft06 is offline   Reply With Quote
Old 03-17-2008, 02:00 PM   #3
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
If you're talking about the 1-step colder IRIDIUM tipped plugs (the stock NGK plugs are iridium), then you SHOULD NOT GAP THEM. If you try and gap iridium plugs, you'll break the tip off. They should already be gapped appropriatley out of the box. If I recall correctly, you're really not supposed to even MEASURE the gap (definitely not with the cheap-O autozone measure wheels- feeler gauges are probably OK, if done VERY gently), the tips are that fragile...
phlegmon is offline   Reply With Quote
Old 03-17-2008, 03:11 PM   #4
Destroy
Member#: 22997
The part number on the plugs is LFR7AIX NGK Iridium
Old 03-17-2008, 03:36 PM   #5
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
fwiw, you can gap them, just don't touch the electrode.
Mine came gapped to around .028-.029 (feeler gauges) which was exactly what I was going to gap them to.
fujiillin is offline   Reply With Quote
Which of these NGK Iridium one-step colder plugs should I buy? lotarg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-01-2010 12:54 PM
what should I gap my plugs at for a built motor and 35r? scutzi128 Built Motor Discussion 10 11-08-2008 05:20 PM
FS: NGK STI Stock Heat Range Spark Plugs LFR6AIX-11 6619 awdtoy SWIC Private Classifieds 0 10-21-2007 04:30 AM
NGK 1 heat range colder Iridium plugs for 04' STi? JDM addict Service & Maintenance 5 03-18-2005 06:31 PM
Set of NGK #7 Heat Range BKR7EIX-11 Iridium Spark Plugs Si2WRX Private 'For Sale' Classifieds 0 10-31-2004 10:22 AM
