View Poll Results: oil weight
5w-30 85 42.93%
10w-30 46 23.23%
non of the above 67 33.84%
Voters: 198. You may not vote on this poll
Old 03-17-2008, 04:32 PM   #1
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Default oil weight
I just want to see what the majority of Nasioc'ers are using. So vote and tell what kind of oil you are using.
And do you use the same weight all year??
Thanks
Ryan
shamrock 05 is offline   Reply With Quote
Old 03-17-2008, 04:33 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Royal Purple synthetic 10w-40 year-round (temp range here 30-115 f)
Audiosavvy is offline   Reply With Quote
Old 03-17-2008, 04:35 PM   #3
STIGuy115
Member#: 145503
06' Impreza WRX
SGM Rally Warrior
Royal Purple synthetic 5w-30, cause of the occasional frigid temps in the winter. I'll probably go to 10w-30.
STIGuy115 is offline   Reply With Quote
Old 03-17-2008, 04:37 PM   #4
Murdoc2112
Member#: 155307
WR Blue Pearl
Valvoline Syn Power 5w-30
Murdoc2112 is offline   Reply With Quote
Old 03-17-2008, 04:51 PM   #5
Ralliart4
Member#: 135927
2002 Impreza WRX RA
Castrol racing syn. 10-30 Amsoil 10-40
Ralliart4 is offline   Reply With Quote
Old 03-17-2008, 04:53 PM   #6
Chino Bling
Member#: 129743
2009 335i
Jet Black
amsoil 5w-40 euro blend.
Chino Bling is offline   Reply With Quote
Old 03-17-2008, 04:54 PM   #7
shamrock 05
Member#: 120057
Well we get about the same temps 0-100F and I have been running 5w-30 of Castrol and I dont have a modded car yet. Is it safe to run 5w-30 and do you think it would be a good idea for me to get a oil cooler???
Old 03-17-2008, 04:54 PM   #8
r1xliquid
Member#: 98877
2004 WRX
Platinum Silver
i run castrol gtx 10w-40 down in south florida.
With the spun bearing reports, what is the disadvantage of running the heavier weight?
Because of the added friction i know it can effect MPGs slightly lower, and i suppose power could be slightly lower for the same reason. But this downside is welcome compared to a possible failure.
r1xliquid is offline   Reply With Quote
Old 03-17-2008, 04:54 PM   #9
Ike83
Member#: 161681
2004 WRX
Valvoline Syn Power 5W-30 with K&N oil flter.......probably the best choice without using Mobil 1.
Ike83 is offline   Reply With Quote
Old 03-17-2008, 04:56 PM   #10
fastlanerex
Member#: 133391
2004 boosted saleen
white
castrol gtx high milage 5w30 for me 85k miles on her now
fastlanerex is offline   Reply With Quote
Old 03-17-2008, 05:00 PM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
No your setup should be fine. It doesn't get NEARLY as hot where you are. We have 4 months at 100+ every day, and somewhat mild winters, and your 10w-30 will work fine, and without an oil cooler
Old 03-17-2008, 05:08 PM   #12
94'325is
Member#: 122315
2003 WRX
Rotella 5w-40 in Florida.
94'325is is offline   Reply With Quote
Old 03-17-2008, 05:25 PM   #13
shamrock 05
Member#: 120057
So being in Michigan, should I switch to 10w-30 or and run that year round OR stay with 5w-30 (what I have been using) and just keep running that year round?????????????????????????????????????
I dont know who moved this, but I wish it would have stayed in the 2.0L section!!!!!!
Old 03-17-2008, 05:41 PM   #14
Arctic Penguin
Member#: 119532
2006 WRX
i predict lots of spun bearings this summer
Arctic Penguin is offline   Reply With Quote
Old 03-17-2008, 06:06 PM   #15
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
Care to elaborate? Most oils quoted were a xw40? A 40 weight is good for most Scoobies in high temp..hell in most temps...
It is not so much the weight of the oil, but other factors such as shearing etc...
F'in noob!
steeter is offline   Reply With Quote
Old 03-17-2008, 06:24 PM   #16
gtfaded
Member#: 142322
2002 wrx
wrb
10 40, been using royal purple going to switchto castrol syn.
gtfaded is offline   Reply With Quote
Old 03-17-2008, 07:01 PM   #17
gi2005
Member#: 150531
2002 VF39 WRX
MPB
mobil 1 10 40
gi2005 is offline   Reply With Quote
Old 03-17-2008, 08:00 PM   #18
02KyRex
Member#: 174265
02 Wrx
MBP
man you guys are starting to make me nervous.....ive jsut got a 02 rex with 45k on the ticker and all this talk about spun bearing makes me nervous. Im getting ready to change the oil and wonderin what i need i say weather here is about 20-maybe 100 degrees in summer. Help is much appreciated since i don't want to spin a bearing im already working on the tranny swap for it
02KyRex is offline   Reply With Quote
Old 03-17-2008, 08:29 PM   #19
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
any reason for the switch?
</~~~ jus switched over from the dreadful mobil 1 to 5w30 royal purple
SUBYDOODIE is offline   Reply With Quote
Old 03-17-2008, 08:35 PM   #20
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
Old 03-17-2008, 08:50 PM   #21
nardvark
Member#: 145108
2002 Impreza TS
Pennzoil Platinum 5W-30
(But no one cares what I think, because I have no turbo)
nardvark is offline   Reply With Quote
Old 03-17-2008, 09:34 PM   #22
Subydoo420
Member#: 173361
2003 Wrx
Suby blue
Definately royal purple 5w-30. Car seems to love it to.
Subydoo420 is offline   Reply With Quote
Old 03-17-2008, 09:44 PM   #23
bluesubie
Member#: 767
04 FXT
Search this forum for GC or German Castrol. It's Syntec 0W30 and is a much better, shear resistant oil than Syntec 5W30. It is a Group IV oil unlike the Group III N. American Syntec 5W30.
It's kind of meaningless to ask what viscosity other people use. You should have a used oil analysis performed that will tell you what works best for you. People have run thin oils with excellent results.
Others have had problems. These guys can help you: http://www.blackstone-labs.com. Also try doing a search with uoa or used oil analysis in this forum.
Skip the weight on the bottle. If you favor bearing protection over fuel economy, run an ACEA A3 rated oil (or Motul, Redline or Amsoil) and not an energy conserving oil. Royal Purple xW30's are famous for shearing to 20 weights with very few miles on the oil.
-Dennis
Old 03-17-2008, 10:03 PM   #24
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
castrol syn 10-30 i use that now mobile 1 sucks
03WRX-WRB is offline   Reply With Quote
Old 03-17-2008, 11:29 PM   #25
Brest Phan
Member#: 29052
08 Evo X
03 WRX sold not forgotten
Just put in Rotella T Synth 5-40 based on info at Bitog.
Couldnt get Redline in my area.
Was going to put in Eneos but based on unremarkable performance reports on Bitog decided against it.
Until now Ive run M1 5-30 for 1120,000 miles-
Brest Phan is offline   Reply With Quote
2001 RS 2.5 Wagon what oil weight oldvetter Newbies & FAQs 4 10-16-2002 11:55 AM
Oil Weight 10w30? or 15w50 ? Clegg Mid West Subaru Owners Club Forum -- MWSOC 2 06-24-2002 12:27 PM
Oil weight and filter for '02 WRX WRXforME Service & Maintenance 1 02-18-2002 03:31 PM
Proper oil weights? Chubler Transmission (AT/MT) & Driveline 1 10-11-2001 02:57 PM
Oil weight for high performance cars Jon Bogert Normally Aspirated Powertrain 22 02-26-2001 12:36 AM
