Old 03-18-2008, 10:47 AM   #1
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Default 40-45mph noise
I have had this noise for the longest time now and I really want to get it fixed/diagnosed.
2002 WRX Sedan w/ 49k miles
When cruising in 4th gear at 40-45mph, as soon as I let off the throttle I get this loud humming noise coming from the middle/rear section of the car somewhere. As soon as the speedo dips below 38-40mph or so the sound just goes away. It's usually only in 4th I notice it since that's what gear I'm in when I drove at that speed. I think I've noticed it in 3rd before but I never just cruise in 3rd at that speed.
Only thing I can think of is the rear shocks are bad and are having bad NVH(normal vibrating harmonics?) at that speed. They probably need replaced.
I don't think it's the wheel bearings, as the car has fairly low miles still.
Any ideas or anyone with similar problem find a solution to this?
akira02rex is offline   Reply With Quote
Old 03-18-2008, 11:38 AM   #2
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Is the sound only in one gear? Does the sound go away when you put the clutch in or are at the same speed in a different gear? It doesn't sound like it is suspension related, only because it doesn't make the noise while you are on the gas. Usually suspension issues will always make the noise regardless of speeding up/down/what gear you are in.
Doc Holiday is offline   Reply With Quote
Old 03-18-2008, 01:40 PM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
seems when there is a load on the driveline it makes the noise.
Like I said, in 3rd or 4th when decelerating between 40-45mph.
Old 03-20-2008, 10:30 AM   #4
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Anymore suggestions?
Weird Moaning noise coming from my front right axle area...? Flyin_Hayn Transmission (AT/MT) & Driveline 2 06-05-2010 03:50 PM
WTB: 245/40/18 tires stg2wgn NWIC Private Classifieds 4 06-05-2010 01:52 AM
Whinning noise starting around 45mph -scoobyblue- Transmission (AT/MT) & Driveline 25 02-17-2010 08:24 PM
Font/Center Diff whine @40-45mph... Anyone? Obsessive Transmission (AT/MT) & Driveline 2 01-14-2007 01:33 PM
news flash........" 'the kidd' gets citation for 84mph in a 45mph zone." AliBenn Texas Impreza Club Forum -- TXIC 18 03-09-2001 07:36 AM
