Old 04-30-2008, 04:48 PM   #26
KENT56
Member#: 163129
Midnite
get tactrix cable and disable it thru open port (chek disable sensor) i think the code is P0430
ecuflash does the job
KENT56 is offline   Reply With Quote
Old 04-30-2008, 05:54 PM   #27
Arctic Penguin
Member#: 119532
2006 WRX
Originally Posted by unclben7 View Post
I wish I would have known about that before I bought the cel fix online which is exactly what you did, but it included the resistor as well...I would have saved a bunch of money. Good job!
that wont pass emissions check
the anti fouler fix WILL
Arctic Penguin is offline   Reply With Quote
Old 05-01-2008, 03:10 PM   #28
impreza97
Member#: 105661
wrb
ok, i have a catless perrin uppipe and a catless helix downpipe, will this CEL fix get me passed inspection?
amazing write up btw! thank you!
impreza97 is offline   Reply With Quote
Old 05-02-2008, 10:01 AM   #29
KENT56
Member#: 163129
Midnite
no it wont cause u still poluting ... cel fix is only for ecu and chek engine lite it wont change ur monoxide de carbon in ur exhaust
Old 05-02-2008, 11:51 AM   #30
Jus Blaze
Member#: 129428
2002 Wrx
I think you will still pass, since your car is an 02. They use ob2 tests on cars that are 95 and newer.
Jus Blaze is offline   Reply With Quote
Old 05-02-2008, 07:00 PM   #31
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Default ny smog
Originally Posted by Jus Blaze View Post
Do you think that I would be able to pass NY inspections if I did this to all my sensors? I have a complete catless turboback.
Sorry, but I honestly have no idea what emission restrictions are like in NY... do a search, i bet you will find numerous threads about passing smog inspections.
WorldRallyX05 is offline   Reply With Quote
Old 05-06-2008, 02:39 PM   #32
impreza97
Member#: 105661
wrb
just want to say thank you, took my car to get inspected today and passed!
Old 05-06-2008, 04:03 PM   #33
CincyWRX
Member#: 175201
11 WRX Limited 4dr
08 Triumph Speed Triple
Looks like a good write-up. Just a quick question...is this overkill? I am new to Subie's, but on my VW with catless DP, we would just neatly zip-tie the 2nd (post-cat) o2 outside of the exhaust track. The OBD2 scan would read the sensor as there, and it would just read outside (clean) air. I think this would be the easiest and cheapest way to avoid a CEL. So is the issue that this would get caught in inspection? Haven't had those in a while but I don't remember them getting under the car.
CincyWRX is offline   Reply With Quote
Old 05-07-2008, 02:07 AM   #34
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Not sure, i'd have to do a little more research, but i remember reading some things when i was originally researching this topic for use in my WRX and i found that a couple of times i saw that articles said not to completely pull the sensor out of the downpipe.
The reasons were as follows:
1. To keep from being exposed to the elements
2. To keep it in a very secured position (screwed into the downpipe itself is a little more secure than strapped to the crossmember with zipties... not that there is anything wrong with that)
3. To pass visual inspection in certain states/counties for passing smog. I remember reading that certain states/counties will make you pass visual inspection of catalytic converters and o2 sensors.
Bottom line, there are many ways of doing this fix, including the one you suggested, and i'm not going to say that mine is better, just that it works perfectly for my (as well as many others) purposes.
If anyone comes across this and has any other reasons why this fix might be more beneficial than another route... please post it!
Thanks!
Old 05-09-2008, 01:38 AM   #35
iraj
Member#: 164256
awesome thread muchos gracias!!
iraj is offline   Reply With Quote
Old 05-09-2008, 01:52 AM   #36
Z3RO
Member#: 87542
2002 Bugeye
saved for later
Z3RO is offline   Reply With Quote
Old 12-19-2008, 01:34 AM   #37
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Wow did this in 3 min and cost me $4.80
Thanks a lot.
BlackFighter is offline   Reply With Quote
Old 04-12-2009, 10:12 PM   #38
WRX Loki
Member#: 208332
06 Hawkeye Wagon
Red
Originally Posted by Z3RO View Post
saved for later
+100
WRX Loki is offline   Reply With Quote
Old 06-16-2009, 06:01 PM   #39
GLD247
Member#: 207789
2003 WRX EJ257 Swap
im still getting a CEL with this.
GLD247 is offline   Reply With Quote
Old 06-29-2009, 07:47 AM   #40
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
Installed the anti fouler on my rear O2 sensor on 6/25 and cleared the code and drove it for 2 days (103 miles) and got it inspected on 6/27 and it PASSED! Its still off (knock on wood) However when I did put it on be VERY careful of the wires attached to the O2 Sensor since they become stretched when it is in.
WRXSteye20008 is offline   Reply With Quote
Old 07-18-2009, 01:53 PM   #41
outlwstr
Member#: 102201
where in ur thread does it explain anything about how to do this with a catless downpipe?
outlwstr is offline   Reply With Quote
Old 07-20-2009, 01:36 PM   #42
Sunkist
Member#: 26387
2002 2.5 Hybrid WRX
Platinum
I still get a CEL with this but it only pops up every once in a while and then goes away again a few days later.
Sunkist is offline   Reply With Quote
Old 07-20-2009, 02:10 PM   #43
BlackFighter
Member#: 193940
2004 WRX STI Black
Same here. Worked great for some time but now i get a cel,
Old 10-15-2009, 09:54 PM   #44
Turbospool72505
Member#: 221822
BLACK
Great Write Up The H*ll With The Other Guy Knocking The Write Up
Turbospool72505 is offline   Reply With Quote
Old 10-24-2009, 11:50 AM   #45
BlueRanger55
Member#: 225579
thanks this is exactly what I was looking for. Cleared it all up for me.
BlueRanger55 is offline   Reply With Quote
Old 10-30-2009, 10:21 PM   #46
ScoobyJD
Member#: 185910
2007 WRX TR
yup I had it on my car and it didn't work
ScoobyJD is offline   Reply With Quote
Old 11-15-2009, 06:16 PM   #47
WorldRallyX05
Member#: 173029
2005 WRX Sedan
Hey all,
I haven't revisited my thread in quite a while! Well, it would appear that there are some mixed results here. Not sure why that is. All I can say is follow the directions exactly as they are written. Don't cut corners, each step is there for a reason (not to imply that any of you who have been unsuccessful have cut corners, just a general suggestion to all). At first when I did this i had a lot of trouble getting the resistor to stick/stay in contact in the socket. Try fiddling with that and it might resolve your problem.
I've actually gone back to complete stock exhaust. I couldn't really justify throwing so many more emissions into our atmosphere for an increase in power. With everything stock it's a really fun car, and that's good enough for me
Good luck to everyone.
Old 01-28-2010, 04:53 PM   #48
Doug02wrx
Member#: 226670
2002 Wrx
oh man thank you so much
Doug02wrx is offline   Reply With Quote
Old 04-13-2010, 06:52 PM   #49
LOUROK
Member#: 243245
2010 SH FXT
VF52 301whp 294tq
good thread!
hehe my first post on here.
LOUROK is offline   Reply With Quote
Old 04-13-2010, 08:30 PM   #50
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
anybody with an 04+ car shouldnt use this 'trick' as the rear o2 sensor is used by the ecu on these cars to adjust fuel trims and if you **** with that...it is bad juju
it is far easier to use a tactrix cable or have a tuner turn that code off and retain the o2 sensor function
How To: DIY TGV Deletes Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 125 01-18-2016 08:00 AM
How to: DIY 3.3Ohm resistors jas0nn Interior & Exterior Modification 20 08-07-2009 11:26 AM
How To: DIY Radiator Cooling Panel StretchSTI Interior & Exterior Modification 28 10-29-2007 04:06 PM
How To: DIY Angled Licence Plate StretchSTI Interior & Exterior Modification 29 10-18-2007 04:41 PM
Scoobysport downpipe CEL fix - status? rwroth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-27-2001 11:32 AM
