Old 03-18-2008, 02:57 PM   #1
fort
Member#: 137311
Default gear oil
I'm approaching 75K on my 02 WRX and wanted to get some ideas/recommendations on what to go with when I change the transmission and rear dif oils.
lets try to get a response or two before unibomber "moves" this to the nooby section............................no disrespect meant UB.
fort is offline   Reply With Quote
Old 03-18-2008, 03:04 PM   #2
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
I used Redline lightweight shockproof for the Transmission (Manual) and for the rear diff I used Amsoil synthetic 75w90. You can use any GL-5 gearlube in the rear diff....syn may be best for lowering friction and operating temperatures. I have had zero issues with the tranny or diff.
berge56 is offline   Reply With Quote
Old 03-18-2008, 03:10 PM   #3
Chino Bling
Member#: 129743
2009 335i
Jet Black
currently i'm using amsoil severe gear 75w-90 in the rear diff. in the tranny, i'm using regular valvoline.
i was using the severe gear in the tranny, but i broke my tranny after about 1200 miles (not related to the gear lube). now i'm just using cheap valvoline gear lube on the new tranny (since i need to change the lube after 500 miles), and i haven't noticed any difference over the more expensive gear lube. when i change the tranny fluid, i may just stick with the non-synthetic since i didn't notice any difference with the expensive stuff.
Chino Bling is offline   Reply With Quote
Old 03-18-2008, 03:25 PM   #4
litebrite2001
Member#: 41656
2002 WRX Wagon
Mobil 1 75W-90 in both the tranny and diff. I did it at 30,000 and will again at 60,000 when I get there. The rear diff is dead easy, but re-filling the tranny was a PITA. I wound up just removing the intercooler to do it.
litebrite2001 is offline   Reply With Quote
Old 03-18-2008, 03:37 PM   #5
fort
Member#: 137311
thanks for the responses.
now just cause I don't have the info with me at work and i may be ording online.............how much in each?
Old 03-18-2008, 03:47 PM   #6
litebrite2001
Member#: 41656
2002 WRX Wagon
Tranny is 3.5L or 3.7 US Quarts
Diff is .8L or .8 US Quarts
Old 03-18-2008, 04:19 PM   #7
smurfwrx
Member#: 151928
09 Triumph S3
redline 75w90 in my tranny and valvoline synth 75w90 in my rear diff.
have fun re-filling the rear diff took me forever b/c I was squeezing it through a tiny vinyl tube. SLOW process.
smurfwrx is offline   Reply With Quote
Old 03-18-2008, 05:34 PM   #8
enominus
Member#: 130622
1998 2.5RS
ive only done the tranny and that was cakewalk, as long as you have a long funnel. all i had to do literally was unscrew a 21mm(?) bolt at the bottom and take the dipstick out from the tranny to fill, easier then an oil change lol
btw i filled with the uncle scottys mixture,
1 qt redline lightweight shockproof(might have to hunt for it)
1 qt penzoil syncromesh
2 qt castrol hypox 80w 90
enominus is offline   Reply With Quote
Old 03-18-2008, 05:36 PM   #9
Ike83
Member#: 161681
2004 WRX
I also used Uncle Scotty's cocktail for the transmission, along with Redline gear oil in the differential.
Ike83 is offline   Reply With Quote
Old 03-18-2008, 05:44 PM   #10
03WRX_Rich
Member#: 64660
2003 WRX
Silver & Dirt
Dino up front
Synthetic 75w-90 for rear. Duct tape a larger diameter tube to the bottle and SQUEEZE to fill the rear w/o a lift.
cheers
03WRX_Rich is offline   Reply With Quote
Old 03-18-2008, 05:48 PM   #11
Chino Bling
Member#: 129743
2009 335i
Jet Black
you can buy a tool to make filling the rear diff easier at any autoparts store for like $8...
Old 03-18-2008, 05:50 PM   #12
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
^^^^ that tool is crap.....
SUBYDOODIE is offline   Reply With Quote
Old 03-18-2008, 06:07 PM   #13
IIdiceII
Member#: 90438
scottys cocktail
give it a search. did wonders for my trans.
i can downshift into first (not that i do it) at 25mph without double clutching. before i couldnt get the car into first sitting still cars shifts SOOOOOO much easier now.
IIdiceII is offline   Reply With Quote
Old 03-19-2008, 06:06 PM   #14
ajwrxwgn
Member#: 166814
2004 WRX Wagon
got the redline and syncromesh but couldn't find anything other than Castrol Hypoy C 80w 90 will that have the same results?
ajwrxwgn is offline   Reply With Quote
Old 03-19-2008, 06:22 PM   #15
Chino Bling
Member#: 129743
2009 335i
Jet Black
what's wrong with it? it works just fine for me...
Old 03-19-2008, 08:15 PM   #16
enominus
Member#: 130622
1998 2.5RS
huh? thats what i typed, i just miss spelled.. oops.
Old 03-20-2008, 11:13 AM   #17
fort
Member#: 137311
I went through the Scotties cocktail posts and from what I see you need to change it every 20K or so; what is the word if you go 50-50 on the RL Shockproof and Pens-oil Syncromesh?
what was the size for the torx bolt on the rear diff?
Old 03-20-2008, 11:22 AM   #18
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Me too. Scotty's Cocktail is unbelievable! And I felt a difference with the new Redline 75w-90 in the rear diff. Nobody that has ever used Scotty's Cocktail will recommend anything else
Audiosavvy is offline   Reply With Quote
Old 03-20-2008, 11:23 AM   #19
Audiosavvy
Member#: 150794
Qcab dakota 4x4
All you need is a 3/8 ratchet. You don't need to change it any more often than normal tranny fluid, and you need to stay as close to the specs as possible, I know from experience it won't be the same otherwise
Old 03-20-2008, 11:28 AM   #20
smurfwrx
Member#: 151928
09 Triumph S3
man, why do always see "US cocktail is good!" "No, US cocktail is bad!"
It's like, are eggs good or bad for you?
Old 03-20-2008, 11:30 AM   #21
Poekin
Member#: 118827
2006 WRX Limited CGM
can anyone link the original post to scotty's mix
Poekin is offline   Reply With Quote
Old 03-20-2008, 12:22 PM   #22
Audiosavvy
Member#: 150794
Qcab dakota 4x4
yes sir
http://forums.nasioc.com/forums/showthread.php?t=920674
Old 03-20-2008, 12:25 PM   #23
Audiosavvy
Member#: 150794
Qcab dakota 4x4
I've never known anyone to speak badly about it who's actually used it. As for me, I had a grind any time I would up-shift into 4th, and could never put the car into 1st gear unless I was almost completely stopped. With the cocktail, I can go into 1st sometimes over 20mph! and no grind in any gear EVER (except the 3 times a year from neutral into 1st, even that is better). I can shift smoother and faster into every single gear, revmatching/downshifting is smoother, everything about the tranny feel and performance was much improved
Old 12-06-2008, 09:45 PM   #24
eb_rat_7
Member#: 106910
2016 GTI
C6 ZO6 track toy
? no need for the T70 bit?
eb_rat_7 is offline   Reply With Quote
Old 12-06-2008, 10:35 PM   #25
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Not usually. Although I've never seen a 3/8" square, I've only seen the much more standard 1/2" square. Maybe the WRX uses a different, smaller plug than the other Subarus I've had or worked on.
bulwnkl is offline   Reply With Quote
Thumbs up for Motul Gear 300 Synthetic Gear Oil shogunate83 Transmission (AT/MT) & Driveline 60 03-20-2011 02:04 AM
Gear Oil Change??? wickkerr82 Newbies & FAQs 6 06-04-2010 01:35 PM
what gear oil to use for STI RA gear sets bottlediger Transmission (AT/MT) & Driveline 1 11-07-2004 03:22 PM
Thumbs DOWN for Motul Gear 300 Synthetic Gear Oil shogunate83 Transmission (AT/MT) & Driveline 0 11-16-2003 12:16 AM
New Redline Gear oil = 1st gear grinding skoobywrx Transmission (AT/MT) & Driveline 6 10-26-2003 09:13 AM
