Old 03-18-2008, 04:09 PM   #1
winston856
Member#: 170133
1997 Legacy 2.5GT
Light Silver Metallic
Default Trying to change spark plugs - can't get socket on plug
Alright so I'm trying to pull a plug to check it out, specifically the number 3 plug on my EJ25D. I have the boot off but when I stick the socket in there there's like a rubber ring or something surrounding the plug and it's not allowing me to get the socket on there to pull the plug out.
It's really frustrating because the plugs are so deep into the heads and I can't see what I'm doing, only feel.
What the heck is it?
winston856 is offline   Reply With Quote
Old 03-18-2008, 04:15 PM   #2
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
Is the piece of rubber still in the plug socket? If it fell out it may have jammed things up a bit.
mikeythejew is offline   Reply With Quote
Old 03-18-2008, 04:21 PM   #3
winston856
Member#: 170133
1997 Legacy 2.5GT
No sir, the sockets I'm using have no rubber.
It's in there after I pulled the boot off the end of the plug, both of my manuals don't mention anything about it that I can find.
Old 03-18-2008, 04:37 PM   #4
winston856
Member#: 170133
1997 Legacy 2.5GT
I pulled the next boot which I believe is number 4 and there's one in there too. It's like a little rubber ring/shield thing around the ceramic ribs near the terminal.
I tried getting some needle-nose pliers in there to pull it off but it wasn't having any of it. I wonder if I'm suppose to force it down by sticking the socket over it and pushing it onto the plug?
Old 03-18-2008, 04:42 PM   #5
winston856
Member#: 170133
1997 Legacy 2.5GT
It's almost like a rubber grommet of some type perhaps.
Old 03-18-2008, 05:42 PM   #6
winston856
Member#: 170133
1997 Legacy 2.5GT
Never mind you guys, I got it off with needle-nose pliers. It's thing rubber grommet insulator thing that fits on the end of the spark plug that insulates the plug from the valve cover and the surrounding metal.
A shop to change spark plugs on a WRX for less than $200 stees South East Region Forum 14 08-24-2006 11:18 AM
ne1 here know how to change spark plugs on wrx? Benjamin Tang Vancouver Impreza Club Forum -- VIC 12 05-30-2004 12:50 AM
When to change spark plugs & what brand to use? Bradus Factory 2.0L Turbo Powertrain 19 05-01-2004 01:53 PM
How to Change spark plugs on a Phase I DOHC? yebokmj Normally Aspirated Powertrain 5 01-21-2001 04:44 PM
At what engine temp to change spark plugs?? Dan00RS Technical Forum Archive 5 05-12-2000 12:52 AM
Message Board Statistics All times are GMT -4. The time now is 04:06 PM.
