Old 03-18-2008, 05:47 PM   #1
1998Impreza
Member#: 174919
1998 Impreza
Default My car hiccups... not a good sign? not so bad?
I have a 1998 Impreza wagon... when I let the car idle, every once in a while it will sort of bog up a little bit, the rpms dip a little bit and then come right back up to normal. It did this for months, and never changed. It didn't get any worse, so I figured there was no serious problem... It used to happen just a little bit, but I just had some work done on it yesterday (fixed a little exhaust leak and got a new catalytic converter) and after that was finished it was hiccupping a lot more frequently, and I could feel it while I was driving the car. It has slowed down a bit in the last day, but still a little more often than it was.
I put some fuel injector cleaner stuff in it, and i'm waiting to work through this tank of gas, I'm hoping that will do it, but I'm nervous it might be something else...
any ideas?
1998Impreza is offline   Reply With Quote
Old 03-23-2008, 11:23 PM   #2
1998Impreza
Member#: 174919
1998 Impreza
anyone??
Old 03-24-2008, 04:31 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
Try cleaning the MAF sensor. Check your air filter too and make sure it's not dirty.
Haelan is offline   Reply With Quote
Old 03-24-2008, 05:01 PM   #4
Ging
Member#: 3258
2000 Impreza TS
I dunno if it might be the same, our 95 Impreza wagon was in the shop and we had some similar symptoms except sometimes it would actually stall when coming to a stop and hard to start some times. It seems it was a sticky EGR valve. Any one know if the '98s had egr valves?
Ging is offline   Reply With Quote
Old 04-03-2008, 07:59 PM   #5
1998Impreza
Member#: 174919
1998 Impreza
Just though I'd update. It turned out to only be a little bit of water in the gas tank. Some Thermo-aid did the trick, and its as smooth as ever.
Happy ending.
WTB: 17" rims.. not bent good shape not looking to spend alot turbobird14 Private 'Wanted' Classifieds 8 03-19-2008 05:37 PM
Why is it that some mornings my car is moist and some mornings not? MikeBuzzsaw Off-Topic 4 10-14-2005 04:24 AM
Why does Good Charlotte suck so bad? Nicklbrso Off-Topic 44 10-01-2004 01:07 AM
Message Board Statistics All times are GMT -4. The time now is 12:35 AM.
