Old 03-18-2008, 07:16 PM   #1
DreddRS25
Member#: 51642
2008 WRX
Default Cost of repairs: Motor mounts + Rear Main seal
My 01RS is finally starting to show its age. Had a leaky rear main seal for about 6 months and now have a broken motor mount. Car has 130000 and also still needs a timing belt.
1. Anyone have an idea on the cost for the broken mount and or rear main seal?
2. Is it worth repairing? As in, should I just trade it in while its still running?
I really want to buy a new vehicle in the next year. The car is worth between $3800-5700 and I owe about $2700 on the car. Any insight is much appreciated. TIA
DreddRS25 is offline   Reply With Quote
Old 03-18-2008, 07:28 PM   #2
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Rear main seal=6.0 hours of labor+parts(roughly $40-50). Motor mount set should run you around $150 or so, and labor should be around 2.0 hours. Shop rates vary from $60-100/hour, depending on whether you want a dealer to do it or an independent.
Mika
finnRex is offline   Reply With Quote
Old 03-19-2008, 10:02 AM   #3
anechoic
Member#: 28601
2007 Outback
gold opal something
Assuming it's a manual, is the clutch original? You might want to consider having that done while they've got it apart to save some on the labor. I got about 145k out of the clutch in my old Legacy, although I think whoever owned it for the first 50k wasn't exactly gentle on it.
Wouldn't hurt to see what a dealership will give you in trade in its current state, and you can weigh that against the repair costs. The place where I traded in my Legacy didn't even ask about its service history, aside from whether the clutch had been replaced at some point. They either didn't notice or didn't care about the couple of rust spots, worn out suspension, or the fact that it was rollin' on bald snow tires.
anechoic is offline   Reply With Quote
Old 03-19-2008, 10:32 AM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The motor mount is a fairly easy fix you could do yourself if youre inclined.
The rear main as above is a lot more work and youd definitely want to do the clutch package while youre in there.
If it were me Id repair the motor mount myself and then try to live with the oil seepage until I traded it.
ss
subysouth is offline   Reply With Quote
Cause of rear main seal failure DemiSlayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-05-2008 03:24 AM
Installing a clutch? Why not throw in a new rear main seal. Tim Sanderson Transmission (AT/MT) & Driveline 0 07-08-2004 11:02 AM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 07:28 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 11:42 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 01:29 AM
