Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 03-18-2008, 09:16 PM   #1
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
Default boosting proplems
ok so i got front mounted i replaced the bov with my aps but the higher rpm i go i lose boost i was low on oil so i put some in havent drove it yet im hoping it fixed that problem i was also wondering if it could be that i need to get reflashed or something along thoughs lines
blackout801 is offline   Reply With Quote
Old 03-18-2008, 09:18 PM   #2
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Fueling more then likely and your boost tuning may need to be altered due to teh front mount - log it and see
Kastley85891 is offline   Reply With Quote
Old 03-18-2008, 09:20 PM   #3
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
what would i do for the fueling?
Old 03-18-2008, 09:24 PM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Do you have a WB? best to get soem one to log your car --- take a look at AF corrections and all the boost set points and actual boost reached, see if they can corrolate something from teh data that is pulled etc, you have dramatically increased the air capacity of the turbo by chcuking the FMIC on there, I would assume that teh map may need tweaking... Im no expert but Id get it logged,
You may also try to check all your connections for leaks...
just my 2
Old 03-18-2008, 09:36 PM   #5
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
alright thanks ill ask hetsaq
Old 03-18-2008, 09:56 PM   #6
hetsaq
Member#: 63572
Having him check for leaks first.
hetsaq is offline   Reply With Quote
Old 03-18-2008, 10:27 PM   #7
nlod
Member#: 170066
HI! My name is
ALEXXX! RAWR!~
He's pro at checking for leaks. He owned a DSM.
nlod is offline   Reply With Quote
Old 03-19-2008, 02:12 AM   #8
subystone
Member#: 138598
wrx impretza saloon
ralle de mundo azul
^^^hahahahahahahahahaha
subystone is offline   Reply With Quote
Old 03-19-2008, 02:34 AM   #9
nme187
Member#: 117763
DSM leaks FTL, that brings me back....
nme187 is offline   Reply With Quote
Old 03-19-2008, 06:29 AM   #10
blackout801
Member#: 170059
04 STi Stg 3ish?
BUNANA KING!
haha yeah dsms oh man
Old 03-19-2008, 10:43 AM   #11
KineKilla
Member#: 127369
1997 Infiniti I30t
Rosewood ?
Adding parts that alter how much air can be pushed or ingested by the motor without a re-tune...FTL.
I would recommend that you finish putting all your new parts on, then get one tune rather than doing it several times.
KineKilla is offline   Reply With Quote
fmic owners road debris proplems drkramm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-10-2009 02:36 PM
proplem?? Akrexak Service & Maintenance 0 04-11-2008 05:00 AM
automatic transaxel proplems for a 90 lagecy brandon303 Transmission (AT/MT) & Driveline 2 11-19-2006 01:12 PM
Need some help I have some Proplems!! jacket03WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-27-2005 11:11 PM
Manual Boost Proplems doster82 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 06-14-2004 09:04 PM
