Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Closed Thread
Old 03-18-2008, 09:45 PM   #1
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
Default NEW rear camber plates in stock at TiC
We've been waiting a very long time for these, and I'm happy happy happy to announce they are here. I mean seriously, really happy.
So here's the details:
  • Compatible with 60 mm Coil-Over springs (perches for 2.5" coming soon).
  • Installs with basic hand tools, no chassis modifications required.
  • Plates are designed specifically for 02-07 Impreza
  • Camber is adjustable at the track from the trunk with simple hand tools.
  • The spherical bearing used in Vorshlag camber plates is the largest used in any Subaru camber plate. The result has much better durability and wear characteristics than the undersized bearings used in some competitors' plates.
  • Designed using alloy steel, not aluminum, for the minimum stack-up height and maximum suspension bump travel. More than an inch more strut travel than some of our competitors!
  • 100% CNC machined, alloy steel construction - Tough as a German Tank!
  • All components plated for maximum corrosion resistance and long life.
And a couple of other things:
  • Camber challenged Wagon guys with sedan coilovers - this is something you really want to think about.
  • Vorshlag also added a nice little bonus - a single row bearing for the upper perch to allow it to turn freely while compressing and decompressing.
  • Stack height is ONLY about 31mm. This beats the heck out of the stack height that uses the stock top hats and upper perch adapter as that comes in at over 60mm.
These will fit WL G4's, ASTs, and KW V3 with 60mm rear spring or RCE T2s. We are looking into the parts to get them to fit the Ohlins sportlines.
These bad boys are $380 shipped, and you can get them by clicking here.
Turn in Concepts is offline
Old 03-19-2008, 01:10 PM   #2
DS1
Vendor
Vendor Sales Rating: (17)
Member#: 111780
ok I want a demonstration of one of you guys adjusting it in the trunk
DS1 is offline
Old 03-19-2008, 05:19 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Do I have to get in the trunk to do it? If so can I at least have a flashlight?
actually, we just use our trunk monkey. he has to thrash around a bit to get them to slide into place, but it works.
Old 03-19-2008, 05:46 PM   #4
nate49509
Member Sales Rating: (4)
Member#: 22452
2016 WRX
Beautiful. Do they make them for the fronts?
nate49509 is offline
Old 03-19-2008, 07:16 PM   #5
DS1
Vendor
Member#: 111780
DS1 is offline
Old 03-19-2008, 07:17 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Do they make them for the fronts you ask?
Why yes they do!!!
Here's the post on them in our vendor for sale area:
Vorshlag front camber plates are back in stock
KW guys - if you're running the stock 60mm ID springs then these are a GREAT camber plate for you. In fact, the stack height is so short that we had one KW user who had to raise his spring perches by 1/2" to get back to his previous ride height.
AST and Whitline G4 guys, these are a GREAT camber plate for you too!!!!
  • Steel plate to resist any bending forces from your suspension.
  • Steel bearing carrier
  • Some of the largest spherical bearings offered on any camber plate built
  • Integrated sealed bearing in the included upper spring perch (sized for 60mm ID springs) to allow for free rotation of the spring to help prevent binding
  • Incredibly short stack height of about 37mm to allow for tons of bump travel
  • Backset of camber slots to add approximately .75* of caster
These go for $425 shipped in the US, and you can get them by clicking here.
Closed Thread
P&L 44mm EWG in stock at TiC!!! Turn in Concepts Engine/Power/Exhaust 9 10-01-2007 04:13 PM
Kartboy 5MT stuff + some others now in stock at TiC Turn in Concepts Drivetrain 31 12-30-2005 12:41 PM
PDE Camber Plates In Stock For A Limited Time AQ Motorsports Suspension/Brakes/Handling 17 07-22-2005 08:59 PM
Any local vendors have Noltec caster/camber plates in stock? Butt Dyno Mid Atlantic Impreza Club -- MAIC 1 08-05-2004 12:43 PM
Question about rear camber plates in 93-01 wagon stentorian Brakes, Steering & Suspension 0 02-23-2004 02:21 PM
