Old 03-18-2008, 09:51 PM   #1
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
Default Got a page with the prices of the dealership maintenance charges and got a question
Ok before reading all the junk below, here's the question. I should be able to do some of these things myself and drop the price some shouldn't I? Or is this like some kind of special 'combo deal' like getting a number 6 at Wendy's instead of ordering the Spicy Chicken sandwich, fries, and drink separately and paying 40 cents more? Or I suppose this is a question to just ask them then isn't it? Whatever, I'm gonna call them next week and get it figured out.
Looks like they do a lot of stuff that doesn't need to be done.
At the 15/45/75k maintenance they charge $187 before tax and do the following:
Replace engine oil & filter, add BG oil additive. Rotate tires. Check and adjust tire inflation. Inspect brake pads and rotors. Replace air filter. Replace fuel filter, add BF fuel conditioner. Inspect clutch and adjust as needed. Inspect exhaust system. Inspect all chassis components. Check and top off all fluids. Service battery. Road test. Wash and vacuum.
You don't need the fuel filter or air filter replaced except for every 30k miles.
For just the oil change and filter change, and tire rotation every 7,500 miles they charge $60. So that means they charge an extra $127 for the air and fuel filter replacement, and BG additives. Don't they usually inspect stuff for free?
And for the 30/90k maintenance they charge $488 for a 4cyl and $588 for the 6cyl. Must be for the spark plug job. They do this:
Replace engine oil and filter, add BF oil additive. Rotate and balance tires. Check and adjust tire inflation. Check and top off all fluids. Inspect brakes and adjust as needed. Replace front and rear differential fluid. Replace transmission fluid. Replace engine coolant. replace air filter, fuel filter, add BG fuel conditioner, and replace PCV valve. Replace spark plugs. Flush brake system. Inspect exhaust system and all chassis and drive train components. Service battery. Road test. Wash and vacuum. Includes a rental car for the day.
Everything seems right with this one except with the WRX you only need a spark plug change every 60k miles because it's got those fancy platnium plugs. Also, couldn't they just not give you a rental car and you save $50 for this job?
The last job they do is the 60k maintenance job. Comes in at $788. Same exact thing as the 30 and 90k maintenance but they do 1 more thing. They change the timing belt.
bomber991 is offline   Reply With Quote
Old 03-18-2008, 10:04 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Forget about the "additives" and "conditioners". You don't need them and Subaru specifically tells you so in the owners manual. You can bring that to the dealer, along with your service schedule (either from the manual or from the Subaru website) and insist on having ONLY the recommended services performed. If they refuse and give you some BS about why it's all necessary, and/or the price is still too high, walk out and find a good independent Subaru shop or do it yourself.
Also when you check the maintenance schedule you'll see that the timing belt is not called for until 105K.
Old 03-18-2008, 10:10 PM   #3
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
Yeah but I was in a head on collision way back 3 years ago, so I don't know. It's possible something in there could be wobbley enough to require replacement every 60k for me.
It does just say Dealer Recommended Maintenance on this page so I'm pretty sure they wouldn't hassle me.
Old 03-18-2008, 10:18 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If something is "wobbly" it needs to be fixed. A different maintenance schedule isn't the answer. Was the engine damaged in the accident? Even if it was, a proper repair should have taken care of it.
Old 03-18-2008, 10:58 PM   #5
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
It was damaged but all was fixed. Mainly my dad's just freakin out and telling me I should go ahead and get it replaced. Cause we all know bad stuff happens when the timing belt breaks.
All I was gonna have them do was just the brakes, top off tranny fluid, and inspecting things. All the other stuff I should be able to do myself.
What affect are all the new cheapo scooters having on the price of the older ones? Cjchaps Off-Topic 0 07-20-2007 10:00 AM
If I was Microsoft I'd drop the price of the XBOX by $100 before PS3 launches... nate.the.great Off-Topic 21 11-01-2006 02:23 PM
What is the price of the STI Limited? tee_rexx News & Rumors 2 07-02-2006 08:43 PM
I think there is some confusion about the pricing of the meet Bankheist Texas Impreza Club Forum -- TXIC 55 09-04-2002 07:31 PM
What is the price of the WRX? myko011 General Forum Archive 2 01-10-2001 02:40 AM
