Old 03-18-2008, 10:56 PM   #1
patsy630
Member#: 164420
2004 STi
WRB stage 2
Default IC spray not working?
tonight i was just curious to see if my IC spryer was working so i poped the hood and had someone hit the button, it did nto work? any help on what is wrong would be great
patsy630 is offline   Reply With Quote
Old 03-18-2008, 11:00 PM   #2
04works
Member#: 91493
2006 STi
P&L Tuned
is there water in the tank in the trunk? or maybe a blown fuse?
04works is offline   Reply With Quote
Old 03-18-2008, 11:00 PM   #3
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Did you hear the pump start when the button was pressed?
RP31 is offline   Reply With Quote
Old 03-18-2008, 11:02 PM   #4
MattD87
Member#: 126930
2015 Legacy
CGM
Frozen?
MattD87 is offline   Reply With Quote
Old 03-18-2008, 11:10 PM   #5
RP31
Member#: 123574
CGM STi
Empty tank or frozen water would be hilarious.
Old 03-18-2008, 11:30 PM   #6
patsy630
Member#: 164420
2004 STi
WRB stage 2
to everyone, no i did not hear the motor turn on when i push the button. also for the winter i took the water out almost empty i left 1/4 in the tank now its all unfrozen and filled but will not work.
where are the fuzes that i should check?
Old 03-18-2008, 11:32 PM   #7
04works
Member#: 91493
2006 STi
P&L Tuned
check your fuse's
Old 03-18-2008, 11:39 PM   #8
jdp526
Member#: 171913
2006 WRX STi
Gun metal
I added almost a quart of 70% rubbing alcohol into tank to prevent water from freezing.
jdp526 is offline   Reply With Quote
Old 03-18-2008, 11:41 PM   #9
RP31
Member#: 123574
CGM STi
It gets that cold in Texas? And you're using the IC spray in the winter?
Old 03-18-2008, 11:48 PM   #10
Prevent
Member#: 149114
YOu're in texas?
dude i just drained mine to like 1/8 or w/e, a lil over so the light wouldnt come on
Prevent is offline   Reply With Quote
Old 03-19-2008, 12:14 AM   #11
93 type RA
Member#: 173508
2001 WRX sti v7
its either a blown fuse or a burnt out pump. they are cheap and easy to replace
93 type RA is offline   Reply With Quote
Old 03-19-2008, 12:20 AM   #12
subeerex
Member#: 87430
02/5 BugEye-Peanut
Sedona Red Silver
Dirty nozzles?
subeerex is offline   Reply With Quote
Windshield wiper spray not working DJS1 Service & Maintenance 6 12-24-2009 07:15 PM
Wipers and fluid spray not working SSLegacyGT Electrical & Lighting 4 12-12-2007 10:36 AM
Help I/C water spray not working!? 0BlueSTi4 Electrical & Lighting 8 12-22-2005 05:17 PM
washer fluid spray, not working Rally1 Newbies & FAQs 14 07-05-2002 01:20 AM
JC Sports turbo kit is burning oil and IC is not working (its cold!) Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-08-2001 10:55 PM
