Old 03-19-2008, 03:01 AM   #1
RS2580401
Member#: 149568
2001 Turboed OBS
Default A/C bearing
So I am pretty sure my AC bearing is shot. Is it better to replace the whole AC compressor or just the bearing. I would like to just replace the bearing but I can find the part number for it or a DIY.
RS2580401 is offline   Reply With Quote
Old 03-19-2008, 09:09 AM   #2
SubeTek
Member#: 1714
1999 RS-T COUPE
subaru ac compressors are not serviceable. if the noise is your compressor, you'll need to replace it as a unit.
SubeTek is offline   Reply With Quote
Old 03-19-2008, 11:13 AM   #3
RS2580401
Member#: 149568
2001 Turboed OBS
Ok thanks. I am guess that is something I can do rather than taking it to a shop
Old 03-19-2008, 11:29 AM   #4
RS2580401
Member#: 149568
2001 Turboed OBS
What about the Idler pulley in front of the compressor. Can that be replaced
Driveshaft/carrier bearing worn out? (car bounces) Speedwagon Transmission (AT/MT) & Driveline 0 06-04-2010 05:24 AM
are front wheel bearing on Impreza'a press in bearings? Homemade WRX Transmission (AT/MT) & Driveline 7 10-22-2004 09:33 AM
T/O Bearing + Wear on input shaft collar (T/O bearing surface)? nils Service & Maintenance 0 07-22-2004 07:07 PM
Ball bearing vs plain bearing thng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-21-2003 12:45 AM
Noise! throwout bearing? pilot bearing? Wellhung Transmission (AT/MT) & Driveline 16 11-03-2002 01:42 AM
