Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 04-04-2008, 06:41 PM   #1
burm
Member#: 153807
2001 Impreza rs
Aspen white
Default any tricks to this
Any tricks to removing the crankshaft sprocket. Everything I've read says wiggle it out, or use a screw driver and a hammer. Well I've been wiggling for around an hour now and ive got nothing.
burm is offline   Reply With Quote
Old 04-04-2008, 08:25 PM   #2
burm
Member#: 153807
2001 Impreza rs
Aspen white
oh well, i wiggled the damn thing for ever and it never budged. Well here is my conclusion. The reason i need to remove the crank sprocket, is to replace the woodruff key, because its all jacked up causing, my crank pulley to go bad also. Well from the looks of it the key, it all worn down but it look like part of the key is catching the crank sprocket to keep if from coming off. Any suggestion on how to fix this mess of mine.
is there a trick to this. how to remove your cam gears to get to you head bolds STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-08-2010 04:50 PM
any tricks to getting main shaft bolt out. Peeblesmx445 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-26-2006 01:12 PM
any trick to remove hub centric wheel etam Tire & Wheel 14 02-23-2004 01:13 PM
Sent this old card trick to this lady and now she's amused. Snoopy Off-Topic 21 01-16-2004 03:01 PM
Any tricks to installing a new exhaust? Shakuwa Newbies & FAQs 1 08-28-2002 04:08 PM
