Old 02-14-2002, 08:55 AM   #1
onikageka
Member#: 9447
2000 Subaru Impreza
Ridge Blue Pearl
Default Twin Turbo WRX from B4?
I saw a pic of the exhaust manifold for the twin turbo Legacy B4 the other day and I was thinking that it could be adapted to a WRX fairly easily. I mean it's the same EJ20 engine. All you'd have to do it change the plumbing and relocate the battery for more room under the hood. But could this setup be make to run as a sequencial twin turbo like a Supra?
onikageka is offline   Reply With Quote
Old 02-14-2002, 09:28 AM   #2
Dori Dori
Member#: 6780
1993 Nissan
If it were easy, it would have been done before.
Dori Dori is offline   Reply With Quote
Old 02-14-2002, 10:56 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
and i've never heard of it being done so i'm guessing it really not easy at all!
I suppose with a lot of custom work you could pull it off. But then you'd be begging the question of "why bother?"
If you want more power, use a bigger turbo. If you want a smoother acceleration like the B4, use a different car to begin with. I'm afraid by the time you get the twin-turbo shoehorned into a WRX you'd have spent $10,000. For the price of a WRX and $10,000 to make it drive smoother, i think i'd rather have a car more like my goal to begin with (such as an audi or bmw).
nhluhr is offline   Reply With Quote
Old 02-14-2002, 01:46 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
something like the S4 or RS4 rings inside my head AND it has a warranty
jeremy
cool concept, way too much money to be wasted though.
Old 02-14-2002, 06:59 PM   #5
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
From what I understand, and bear in mind I have no real experience here, two cylinders on this engine just don't produce enough exhaust energy to really make a potent twin turbo package.
I think that type setup would be better off reserved for a higher compression four or six cylinder.
Just what I've heard...
bobgrice is offline   Reply With Quote
Old 02-14-2002, 09:29 PM   #6
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
The B4 is basically just an EJ20 with 2 smaller turbo's so that is just not the case!
It has been done. The infamous Ozmond Bros in Australia took a US coupe shell that had been imported to rally (coupe was never sold in Oz) and put the twin turbo engine from the earlier liberty into it. It was a 280hp engine just like the current b4 (basically same car/engine Subaru used on the salt flats to set that production car record back in the mid 90's)
It was the only 2 door WRX in Australia at the time as that was before the first batch of STi's was released. It was bright canary yellow
I have the article at home somewhere (on the other side of the country right now) but from memory they had a real hard time getting it to fit (one of the turbos was REAL close to the side) as the impreza frontend is just that little bit smaller than the liberty
tt_ttf is offline   Reply With Quote
Old 02-14-2002, 10:16 PM   #7
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The problem that I've always heard (and has been brought up plenty of times) is that it just won't fit in a LHD car, without a bunch of work (=$$$). And if you are somewhere you can get a RHD WRX, why wouldn't you just buy an STi? I saw one other TT WRX on the net, but it was some frankenstein thing that put out like 600hp. Definitely not a stock B4 engine in there.
Old 02-15-2002, 01:24 AM   #8
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
The key word here is potent. It can be done, of course. But here in Japan, the Japanese tuners working with B4's and Legacies with the twin-turbo setup have been hard-pressed to get much power past 310. Single turbo setups are the ones they get to the 350hp range.
If you are looking to make something with a bit more low-end power, then a twin-turbo setup may work. It won't make quite as much mid-range power as a single turbo setup, and it won't be able to make as much peak power as a tuned single turbo setup.
And as it is, Subaru has changed the configuration of the twin turbo. While before it would make power from as little as 1000rpm, now it's dead below 1500rpm - but makes a lot more after that point. It's better than a single turbo for the low end, but in the end even they are conceding that a strong mid-range is worth more than a little better low-end.
Paul Hansen
shirokuma is offline   Reply With Quote
Old 02-15-2002, 05:34 AM   #9
spurner
Member#: 7289
1993 Impreza WRX RA
It has been done before.
Check out this article.
It sounds like a WOFTAM to me.
spurner is offline   Reply With Quote
Twin turbo setup from JDM ej22tt lotus2843 Private 'Wanted' Classifieds 19 02-22-2005 09:21 PM
Twin Turbo WRX kyllc2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 04-14-2002 07:46 AM
Twin Turbo WRX GregUnd Texas Impreza Club Forum -- TXIC 36 02-27-2002 07:34 PM
Twin turbo WRX Greenracer6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-17-2001 03:38 PM
Audi can do a Twin Turbo, so the B4 is do-able here...right? Mike2000GT Legacy Forum 27 04-03-2001 03:41 AM
