Old 03-19-2008, 03:32 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default How Do I Fix a Seized Tie-Rod?
OK, so I went to align my car and found the driver's side inner and outer tie rods have seized together with rust (friggin ODOT uses too damned much salt). I've tried heating the junction with a propane torch (didn't work and I don't have access to an oxy-acetylene torch) and soaking it repeatedly in PB Blaster. No dice.
So what do I do now?
Old 03-19-2008, 04:26 PM   #2
mikeythejew
Member#: 141672
Replace them. Use a little bit of anti-seize on the threads of the new ones to make it easier for a future alignment.
Gotta love the potholes in and around Columbus.
mikeythejew is offline   Reply With Quote
Old 03-19-2008, 04:31 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, the cost of replacing them is less than the quotes I was getting for knocking it loose, but how big of a deal is it to replace them? I've NEVER done anything with steering before. Any special tools? Any tutorials?
As far as keeping them safe for the future, I was considering putting a bit of bicycle innertube over the connection between the inner and outer and sealing it with zip-ties to make them waterproof.
Old 03-19-2008, 04:42 PM   #4
mikeythejew
Member#: 141672
Easy, but your alignment may be way out making your car drive weird to the alignment shop. http://www.youtube.com/watch?v=f6DSjQ0F6j0
Old 03-19-2008, 04:45 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I do the alignments myself
Old 03-19-2008, 04:50 PM   #6
mikeythejew
Member#: 141672
Get this at the Andersons for around $45.00. http://www.bernzomatic.com/bernzomat...rnzoProd100044
Old 03-19-2008, 05:32 PM   #7
Chino Bling
Member#: 129743
2009 335i
Jet Black
replacing a tie rod is a piece of cake. i replaced my driver side tie rod and it took me more time to jack the car up and pull the wheel off than it did to replace the tie rod.
Chino Bling is offline   Reply With Quote
Old 03-19-2008, 05:35 PM   #8
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The outer tie rod seems tirvial. The inner tie rod needs changed too, and that's the one that worries me.
Old 03-19-2008, 05:39 PM   #9
Chino Bling
Member#: 129743
2009 335i
Jet Black
trust me, it's really easy. you'll see when you get there..
Old 03-21-2008, 11:55 AM   #10
Arctic Penguin
Member#: 119532
2006 WRX
have you tried hitting the affected area with a hammer after heating it?
that is why 'impact' works
Arctic Penguin is offline   Reply With Quote
Old 03-21-2008, 01:07 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yup. I just can't get it hot enough with a propane torch, I think.
I'm trying to decide wither I want to take it to a shop to have them torch it apart, or just replace both inner and outer outright.
Old 03-21-2008, 02:02 PM   #12
rkramer
Member#: 118209
2015 WRX Limitec
MAPP gas... just pick up one of the yellow cylinders instead of the blue propane ones, they work with propane torches and burn about twice as hot as propane.
Old 03-21-2008, 02:14 PM   #13
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well damn, you got me all excited there, but it's not quite that simple:
Code:
					Butane	Propane	MAPP  	Acetylene
Flame Temperature in Oxygen (F)	4,925 	4,579 	5,301 	5,589
Flame Temperature in Air (F)		3,200 	3,450 	3,650 	4,350
So MAPP coming out of a typical propane torch head is only about 200F hotter than propane. However, a small oxy-MAPP rig, which I think I've seen at Lowes, is quite a bit hotter.
What is this, how did I break it, and how do I fix it? XanRules Transmission (AT/MT) & Driveline 12 08-20-2009 08:53 AM
how do i make the trunk torsion rods softer? 949 Interior & Exterior Modification 6 02-24-2009 12:06 PM
HELP! What is this? How did it happen? How do I fix it? MyFirstDeuce Transmission (AT/MT) & Driveline 5 09-24-2006 10:50 PM
How do i replace an inner tie-rod? jefersun Brakes, Steering & Suspension 4 01-14-2005 07:25 PM
How do I fix this? Impreza Rider Mid Atlantic Impreza Club -- MAIC 2 04-10-2001 05:10 AM
