Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 03-20-2008, 01:35 AM   #1
awd-box-turbo
Member#: 64057
08 Forester XT
33J
Default another pcv valve ? on an 04 WRX
ok... so ive been up and down every wrx forum looking for the answer and i cant seem to spot my pcv valve... ive taken my intercooler piping off and ive taken off what i think is the pcv valve but i need some reassurance...
i got the autozone pcv valve...the threads are the right size but the hose fitting is completely too big... the valve i took out was completely hollow with no valve stopper???? check it out
could ANYONE HELP ME OUT
awd-box-turbo is offline   Reply With Quote
Old 04-03-2008, 01:30 AM   #2
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
DOOD, you bought the wrong part, the PCV valve is encased in the plastic piece and has to be purchased together, because it's impossible to remove the valve without damaging the plastic.
also searched and found...
http://forums.nasioc.com/forums/show...=pcv+valve+wrx
murrdogg24 is offline   Reply With Quote
Old 04-03-2008, 11:08 AM   #3
boosted lude
Member#: 110501
2004 subaru wrx
yea just changed mine yesterday.. i pulled the hollow valve out from under the TB like subaru said but its actually the whole assembly near the turbo like murrdogg stated in the picture... go to subaru and buy the whole assembly because u will never get it out of the plastic piece.
boosted lude is offline   Reply With Quote
Replacing Valves on a 04 WRX after timing belt woes Skiracer8148 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-25-2009 08:01 PM
Where's the PCV Valve on the 04 NA? BrysImpreza Normally Aspirated Powertrain 2 08-11-2006 12:54 PM
what is the correct offset for an 18x8 wheel on an 04 WRX??? VajraTLR Tire & Wheel 4 01-24-2006 03:55 PM
need help on location of pcv valve on my 04 subaru awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-10-2005 04:46 PM
04 ts wagon steelies fit on an 04 wrx? subzero_Legacy_Gt General Community 2 08-21-2005 07:33 PM
