Old 03-20-2008, 04:34 AM   #1
kh15
Member#: 132400
2006 WRX
Default sparkplug replacment on 06
how the hell am i supposed to get the the sparkplugs on the drivers side with that air pump and all that other stuff in the way on my 06 wrx?
kh15 is offline   Reply With Quote
Old 03-20-2008, 10:00 AM   #2
David L.
Member#: 130632
2002 Z28 35th Ann.
Pewter
You have to remove the battery at the least to get in there and believe it or not you go in from the top. The best way to do it is,
1.)find the proper size socket and put a short extension(one that has a flex joint) put that over the bolt holding the coil pack on the spark plug.
2.) then feed the socket wrench in to the tight space between the wheel well and the cylinder head (working it into the short extension and socket you just set on the bolt) so the socket wrench locks in, loosen it enough to be able to turn it by hand because you will run out of room quick. Romove the rest of the bolt by hand, pull the coil pack off the spark plug. Do that for both driver side cylinders.
3.)The spark plug sits deep in the head and again you will not be able to make the angle with the wrench attatched, so again find the proper size spark plug socket, feed that in to the tight space and work it in to the cylinder head and over the spark plug, then work the socket wrench in and lock it in to the socket. Remove the plugs.
Just be patient and take your time, it is not a 2min job like the passangers side, even though it looks impossible there is a way...
David L. is offline   Reply With Quote
Old 03-20-2008, 11:36 AM   #3
FaisalT
Member#: 107097
09 Etnies
Gray/Black
just pull the airpump out (with bracket) and replace it after you're done. It's a few screws, a hose clamp and a plug and it pulls right out.
FaisalT is offline   Reply With Quote
Fuel Filter Replacement on 06 WRX bdon22 Newbies & FAQs 2 05-24-2009 06:23 PM
Ideas on strut replacements for 06 WRX Scowboy Brakes, Steering & Suspension 6 04-01-2008 11:11 PM
Replacing Cluster on 06 bdon22 Interior & Exterior Modification 8 06-08-2006 01:25 PM
Turbo replaced on my 06 with only 189 miles! SilverSubaab Warranty Issues & SOA Problems 12 01-12-2006 10:26 AM
sparkplug replacement cost? blukestrel Service & Maintenance 1 12-09-2003 11:42 AM
