Old 03-20-2008, 02:06 PM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Will stock rotors and calipers work on a rear 04 sti hubs and knuckle?
I've read the swap threads. But there was no clear answer on this. I want to keep my swap price down as much as possible. I can go to r180 rear end but i need hub and knuckles. If i use the hub and knuckles can I use the stock wrx calipers and rotors?
It sounds like you cant do this because of the Hand brake. But I am not sure.
Thanks,
NITROS is online now   Reply With Quote
Old 03-20-2008, 06:31 PM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
You can't use single pot WRX rear calipers on R180 rear hubs. The caliper mounting bracket mount holes are different and the R180 E-brake is 20mm bigger in diameter. You can use your R160 hubs with adapter axles available from the Drive Shaft Shop, but they will probably run you more than a rear Brembo setup.
Ryan
FourOnTheFloor65 is offline   Reply With Quote
Old 03-21-2008, 10:47 AM   #3
javastiwagon24
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
I measured the 04 sti rear axles where they meet in the Knuckles. And are the same size and spline count. as My rex. So i dont see why you couldn't use your knuckles from the rex and the axles from an 04 sti. Any other years i can not vouch for.BUT. I am very interested, me and a buddy are both doing this as we speak. As far as the brakes go i believe 4on4loor is right.
javastiwagon24 is offline   Reply With Quote
Old 03-21-2008, 01:17 PM   #4
NITROS
Member#: 41561
04 GT3076 2.1
So the sti rear axles will mate with wrx hubs with no problem? why does the swap thread say they wont?
*For those wanting to use the R180 but not switch out the hubs, Apparently driveshaftshop.com offers custom axles (pricey) that allow you to retain the wrx hubs while using the R180 rear end.
Old 02-06-2010, 05:10 PM   #5
MRF582
Member#: 48219
. Always drive
the race line .
Can anyone else confirm this?
MRF582 is offline   Reply With Quote
WTB: Rear 04 STI Hubs and Axles Rokkit Private 'Wanted' Classifieds 2 10-22-2009 01:50 PM
WTB: 04 STi Hubs and knuckles gotawd Private 'Wanted' Classifieds 3 04-08-2009 08:49 PM
WTB WA: 04 STI Hubs and Knuckles Front and Rear wrxwagon253 Private 'Wanted' Classifieds 5 11-16-2008 07:52 AM
WTB: 04 STI Hubs and knuckles front and rear wrxwagon253 NWIC Private Classifieds 4 10-23-2008 01:14 AM
Wtb Asap Rear 04 Sti Hubs Bobby321 Private 'Wanted' Classifieds 6 07-16-2005 02:50 PM
