Old 03-20-2008, 03:55 PM   #1
poison
Member#: 37678
Default Quick: how the F do you get the gas linesoff the fuel filter on an Impreza?
Gawd, what a PITA! There's Gotta be a better way! Help!
poison is online now   Reply With Quote
Old 03-20-2008, 03:55 PM   #2
WRX02WRB
Member#: 36240
09 WRX
Hammer?
Fire?
I have no real information.....
WRX02WRB is offline   Reply With Quote
Old 03-20-2008, 03:55 PM   #3
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
pliers?
Georgethefierce is offline   Reply With Quote
Old 03-20-2008, 03:55 PM   #4
ToddZ199
Member#: 71637
2002 Silverado
Green
OMGHi2U
Pull hard.
ToddZ199 is offline   Reply With Quote
Old 03-20-2008, 03:56 PM   #5
poison
Member#: 37678
That's it? Pull hard?
Old 03-20-2008, 03:56 PM   #6
boxered
Member#: 61884
boxered is offline   Reply With Quote
Old 03-20-2008, 03:57 PM   #7
poison
Member#: 37678
Cut? I need the effin lines!
Old 03-20-2008, 03:57 PM   #8
Qcanfixit
Member#: 135762
4002 Corrida
transparent
Qcanfixit is offline   Reply With Quote
Old 03-20-2008, 03:57 PM   #9
jasonallenross
Member#: 125978
2002 WRX Wagon
At 30K they came off easily.
At 60K it took a utility knife and phone call to the wife to pick up some fuel line on the way home.
For the upcoming 90K service I'm making sure I have a few feet of fuel line on hand.
jasonallenross is offline   Reply With Quote
Old 03-20-2008, 03:57 PM   #10
mannac
Member#: 161038
2002 WRX swapped TS
'72 Datsun 240Z
unscrew clamps/squeeze clamps, use pliers to pull off, done.
mannac is offline   Reply With Quote
Old 03-20-2008, 03:57 PM   #11
Stanley
Member#: 7374
2007 MazdaCopMagnet
dusty
Dude. It's a bitch. I paid the guy at the corner gas station $20 to do mine and was happy to do so!
Stanley is offline   Reply With Quote
Old 03-20-2008, 03:58 PM   #12
poison
Member#: 37678
Pliers eat the lines.
Old 03-20-2008, 03:58 PM   #13
Wagon Joe
Member#: 34436
OT's Custom Penmaker
www.silverlakepens.com
A little squirt of WD-40, and a small set of vice grips, cushioned by a rag works well for me. Squeeze the vice grips down (not too tight) and rotate back and forth to break the hose loose. Then just yank 'em off with your hands.
Wagon Joe is offline   Reply With Quote
Old 03-20-2008, 03:58 PM   #14
burnera
Member#: 56232
89 325I
i don't know
yeah, just pull, comon your crazy killer jew IDF hands cant pull fuel lines off a nipple?
burnera is offline   Reply With Quote
Old 03-20-2008, 03:59 PM   #15
kaisersouse
Member#: 85900
2001 Forester S
rofl at 150k mine came off easy because i didn't treat them like they were made of glass and were attached to a ferarri
kaisersouse is offline   Reply With Quote
Old 03-20-2008, 03:59 PM   #16
Grap
Member#: 6590
This ='s true....it's a bitch, but it'll come off....be gentle or get some new hose.
Grap is offline   Reply With Quote
Old 03-20-2008, 04:00 PM   #17
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
heat it up with a lighter..
the rubber will soften and be easier to remove..
Fish is online now   Reply With Quote
Old 03-20-2008, 04:00 PM   #18
gusto
Member#: 58323
twist lines with pliers, then pull off.
put some sort of white lith/lube on new filter tubes.
then buy these.
http://www.lislecorp.com/tool_detail.cfm?detail=945
gusto is offline   Reply With Quote
Old 03-20-2008, 04:01 PM   #19
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
put a rag between the pliers and lines.....and grab an empty beer can
Old 03-20-2008, 04:01 PM   #20
fliz
Member#: 30342
There's enough extra to be able to cut it off at least once.
I use pliers to twist & break it loose then pull off.
fliz is offline   Reply With Quote
Old 03-20-2008, 04:02 PM   #21
Grap
Member#: 6590
Which is what I did.
Old 03-20-2008, 04:02 PM   #22
gusto
Member#: 58323
or point lines into vent ducts
Old 03-20-2008, 04:02 PM   #23
jasonallenross
Member#: 125978
2002 WRX Wagon
Yep. A new length of hose is what, 30 cents?
I didn't want to find out what bending the crap it attached to was going to set me back -- and the fuel filter was being replaced, anyway.
Oh yeah, and don't cheap out and try and blow gas out of the filter.
Old 03-20-2008, 04:06 PM   #24
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
TheRipler is offline   Reply With Quote
Old 03-20-2008, 04:07 PM   #25
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
make sure you wear safety glasses - the first time i did this, i forgot the system was under pressure
gas in the eyes wasnt a fun event at all
MrMcCrackin is offline   Reply With Quote
How the heck do you get an ebay TMIC to fit? Mr Nice Guy Factory 2.5L Turbo Powertrain 17 07-14-2007 10:19 AM
How to change an fuel filter on an '02 wrx wagon d4ygl0 Service & Maintenance 19 12-28-2005 02:31 PM
How in the Heck do you get the perrin BOV hose on? waitandbleed92 Factory 2.0L Turbo Powertrain 7 02-16-2004 07:53 PM
How often do you get bad gas (not that kind) jmaiken Factory 2.0L Turbo Powertrain 6 10-19-2003 04:16 AM
Once struts are off how the hell do you get them back on? spshultz Brakes, Steering & Suspension 10 07-03-2002 12:39 AM
Message Board Statistics All times are GMT -4. The time now is 08:03 PM.
