Old 03-20-2008, 08:40 PM   #1
Mikey52
Member#: 69019
1995 Legacy Wagon
Default P0115 code
I was finally able to get my CEL read (dont let anyone tell you a '95 Legacy is OBD1!) and this was code. It comes up as a bad coolant temp sensor. I see the part is only about 40 bucks, what's the install like with this? My car has been iffy a couple times on start up and actually refused to start once until i put some oil in it. I'm not sure if this is related at all but it started around the time the CEL tripped.
Mikey52 is offline   Reply With Quote
Old 03-23-2008, 03:05 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Should be pretty easy. Call a friendly dealer's parts dept. and they should be able to tell you exactly where it's at. IIRC it should be on the passenger's side of the throttle body, somewhere down in that area.
DLC is offline   Reply With Quote
Old 03-23-2008, 03:28 PM   #3
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Post up in either the Service/Maintenance forum or the N/A forum and I'm sure you'll have an answer in no time.
Or better yet, search those forums first and you might have an answer even sooner
JS
gtwagon941 is offline   Reply With Quote
Old 05-10-2011, 04:20 PM   #4
NickLegacy22
Member#: 261953
1995 Legacy L
red
old ass thread, what were your symptoms for this issue???
NickLegacy22 is offline   Reply With Quote
OBD-II P, B, C codes, and Subaru OEM codes Julian Normally Aspirated Powertrain 1 11-05-2013 11:03 PM
codes,codes and more codes grinch77 Newbies & FAQs 8 01-07-2009 05:27 PM
P0115 - new sensor, still malfunctioning mxpunk Normally Aspirated Powertrain 8 08-29-2008 08:48 AM
cel ,dtc codes -p0115,p0505, and occasional hard starting impreza subaru6 Engine Management & Tuning 1 03-10-2004 11:16 PM
Code Red and Code Red II worm Luftyone Bay Area Impreza Club Forum -- BAIC 4 08-07-2001 11:14 PM
