Old 03-21-2008, 02:02 PM   #1
FocusdSound
Member#: 172649
2005 GT30R'd STI
Obsidian Black Pearl
Default Check out this mod list and tell me what you think!!
My budget is $5000.00 to start with to include sway bars, springs, endlinks, and the rest is engine mods. The car will be used for a daily driver and every now and then 1/4 mile fun. I got a local shop to give me an estimate of what they thought the best bang for my buck would be and this what they came up with. Let me know what you think.
Borla Header
Borla Cat Back
HKS Downpipe
Cobb Accessport
Urethane Exhaust Hangers
Cobb Uppipe
Cobb Swaybar Front and Rear
Cobb Springs
Endlinks
Go Fast Bits 3 Piece Pulley Set
Tuning for 3 Hours
It isn't $5000.00 total but its close to it.
FocusdSound is offline   Reply With Quote
Old 03-21-2008, 02:05 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
Borla Header
Borla Cat Back
HKS Downpipe
Cobb Accessport
Cobb Uppipe
Cobb Springs
Endlinks
Tuning for 3 Hours
Hks Downpipe is not bellmouth. Get an invidia or helix around the same price. More flow= more power! you really don't need the pulley set either.
renosubby is offline   Reply With Quote
Old 03-21-2008, 02:14 PM   #3
capnchunk
Member#: 79791
2007 STI
Personally I don't think I'd do the pulley set or the header. That would free up some money to either do an EWG uppipe and keep the HKS down, or I'd save a few more bucks for a 20G, Green, Dom 3.0 or whatever turbo best fits your needs. Looking back over things - I didn't see anything about an upgraded fuel pump or injectors, so you might want to make an investment there as well.
capnchunk is offline   Reply With Quote
Old 03-21-2008, 02:36 PM   #4
Bluethunder505
Member#: 165368
2007 STi
Silverstone
what kind of car and what year?
Bluethunder505 is offline   Reply With Quote
Old 03-21-2008, 02:57 PM   #5
FocusdSound
Member#: 172649
2005 GT30R'd STI
Sorry should of posted that. Its an 05 STI.
Old 03-21-2008, 03:10 PM   #6
AspenWhite_STi
Member#: 97616
2005 AW STi - GONE
2009 Black 135i
Ditch the uppipe, 05 STis have a catless uppipe so its not a necessary mod. Secondly get rid of the HKS downpipe, unless your planning on running an external wastegate. Pickup either a Cobb, Invidia, or Helix unit instead. All three are bellmouth designs which will provide better flow and more power. The pulleys are also waste of money, so knock those off your list as well. For the header, I would go with either a Gruppe-S or GT-Spec unequal length design. I've heard that the Borlas are prone to cracking.
Hope this helps. Good luck with your build.
AspenWhite_STi is offline   Reply With Quote
Old 03-21-2008, 03:24 PM   #7
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
if i were you ill get 20g injectors tgv deletes inlet fuel pump and tune!!!(with ap2) cause i have one^^
EJ20_lee is offline   Reply With Quote
Old 03-21-2008, 04:10 PM   #8
Ranatsu
Member#: 87314
2013 BRZ
Crystal Black Silica
unless you want the springs for looks, you probably can ditch them and keep the stock ones, and just upgrade the sway bars.. This should make a noticeable handling improvement.
I also agree with everyone else.. about the headers and hks downpipe.
If you do some bargain shopping you can save a lot of money buy purchasing things used through out the forum. Which should stretch your budget pretty far.
Ranatsu is offline   Reply With Quote
Old 03-21-2008, 04:28 PM   #9
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
this is not true^^
an upipe is a great way to pick up some extra horses... swapping to an aftermarket upipe on an sti yeilds a a minimum of 5whp... for the price of an uppipe thats not to bad... might as well if your getting headers.
here's a discussion on it...
http://www.iwsti.com/forums/engine-p...ious-look.html
All4bSpinnin is offline   Reply With Quote
Old 03-21-2008, 04:38 PM   #10
Hayduke
Member#: 147392
Ditch the cobb springs, they are too low and will make your car handle worse.
Unless you just care about looks.
The best performance springs are the sti pinks
Hayduke is offline   Reply With Quote
Old 03-21-2008, 04:55 PM   #11
FocusdSound
Member#: 172649
2005 GT30R'd STI
I want the springs for performance not lowering. I do want a slightly lowered stance but not laying on the ground or anything.
Old 03-21-2008, 04:56 PM   #12
subarulz!
Member#: 99061
16 WRX
CWP
If you are not upgrading the turbo than there are a lot of mods you have there that will really not give you a whole lot for the money you spend on them. Your mistake was telling them you have 5000 to spend so they are going to try to get it all from you. Like stated above I would look for an STI up pipe used for really cheap. I would also skip the pulley kit as well. Without changing the turbo I have never seen anyone prove that the HKS down pipe is any less efficient then any other design so those of you who made that claim get to searching to show people proof before posting things. They can be found for under 100 used. I think the Cobb springs are a little low too. I had Espelir GT springs on my old bugeye and loved them. Suspension and catback I would choose after going to the next meet you find locally and ask for rides and hear different setups All in all you have a good start but really have to prioritize. I think if you skip the header and pulley kit you will give up 10-20 hp at the wheels but save a 1000 bucks. That money could be used for some nice shocks to go with your springs or even some cheap coilovers instead of springs. I would choose suspension over 10 hp just because I would use and feel it more an a daily basis. Remember once you start modding you will always be left wanting more power but get the suspension right the first time around and you will enjoy it for the rest of the time you own the car. Anyway good luck.
subarulz! is offline   Reply With Quote
Old 03-22-2008, 11:12 AM   #13
teesutt
Member#: 127940
Evil shenanigans
Why would an STi owner need an STi uppipe?
teesutt is offline   Reply With Quote
Old 03-22-2008, 12:26 PM   #14
FocusdSound
Member#: 172649
2005 GT30R'd STI
I think he meant a aftermarket STi uppipe.
Old 03-22-2008, 12:34 PM   #15
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
<<< fill out your profile
a6n6d6y is offline   Reply With Quote
Old 03-22-2008, 01:42 PM   #16
Expurg8d
Member#: 163430
2010 WRX base
I'm a noob, but from what I've read and tuners i've spoken to the cobb springs are not the best. The STi pinks and HKS springs are better. I would ditch the pulley set as well. I'm not sure what the unequal length headers give you, a turbo likes the equal pulses of equal length headers but you'll lose the boxster rumble and sound like a honda. Kartboy makes good end links. I think a fuel pump and injectors are a must, it's a great point to start from so you never starve your engine of fuel if you decide to get a bigger turbo in the future. Just my two cents, i've learned the hard way.
Expurg8d is offline   Reply With Quote
Old 03-22-2008, 02:19 PM   #17
subarulz!
Member#: 99061
16 WRX
CWP
Thank you. That's why I said what I did. I didn't see it was for an STI.
Old 03-23-2008, 01:24 AM   #18
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Amazing that nobody mentioned tires, or brakes.
Suspension:
- GOOD TIRES (depending on what the car has, and the conditions where you live)
- Front and Rear Sway bars
- Rear endlinks, maybe fronts
- Springs. JDM Pinks, Swifts, search, etc, etc.
- Consider Group-N tophats, depending where you are going with car.
- as many bushings as you can get your hands on. At a minimum, rear diff, outrigger, tranny crossmember, and shifter.
- Stiffer Tranny mount, maybe engine. Might just replace with better ones when they break, which they will eventually.
- A good alignment with lots of negative camber up front.
Power:
- Helix or other good-fitting bellmouth downpipe
- 3" catback that sounds good to you
- AP with a good protune, and maybe a GM BCS
- Boost gauge. Oil Pressure and EGT wouldn't hurt either.
- Walbro Fuel Pump
Stopping:
- Brake fluid flush with some Motul RBF600 or Super Blue
- Some good street pads
- Maybe some good rotors, but I would probably wait until I wore my stock ones out
This really depends whether you will install yourself. There may be room for headers, an Anti-Lift kit, a GOOD intake, a GOOD crank pulley, and a few other things. Just keep in mind, headers WILL crack.
All in all, it really depends what you want to do with the car. If you want lots of power, you have to think about how often you will actually use it. If you want superb handling, you have to consider whether you will drive the car hard enough to justify your mods. Start small, do a little at a time, and improve the weaknesses that you identify in the car.
One last thing: take some professional driving lessons. This will really help you push the car, while in a safe environment, and you will be better able to decide what mods you NEED. You will also be better able to handle the mods you get.
aboothman is offline   Reply With Quote
Old 03-23-2008, 01:50 AM   #19
Stames_wiltz
Member#: 143264
2006 WRX TR
I personally love my Cobb stage 2 suspension package. I like the cobb springs honestly. I have had prodrive and cobb springs and I personally think they are pretty close to the same. cobbs ride a little stiffer and are slightly lower.
If I were to do it all over again with 5k I would
Cobb APv2
Cobb Turbo-back
Cobb stage 2 suspension (springs, front and rear sways, rear tower brace)
that is $2500
and a protune
save for stoptech brake lines, and rotors front and rear, hawk pads.
get used to the power, save up for a turbo path.
THEN Get a GT3076R in either rotated or DOM III, Element52 (rotated will be more efficient and make more power) These turbo's are Extremely streetable with minimal lag and you make gobbs of power. No other turbos have more power under the stock block curve than the GT3076R turbo's.
Stames_wiltz is offline   Reply With Quote
Old 03-23-2008, 12:29 PM   #20
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
With a decent budget like yours i would ditch the hks dp and the borla header for better products and pick up a aftermarket uppipe
Old 03-23-2008, 01:43 PM   #21
Nuke209
Member#: 108089
2003 WRX
NF Performance
Borla Header
Borla Cat Back
Invidia Downpipe
Cobb AP
Grimmspeed Uppipe
RCE Blacks
Endlinks
Tuning for 3 Hours
Fixed
Nuke209 is offline   Reply With Quote
Old 03-23-2008, 02:20 PM   #22
fastlanerex
Member#: 133391
2004 boosted saleen
white
springs and performance dont mix. springs are for looks the ride quality goes down and your struts will hate you. if you want looks and performance get a set of used coilovers in the 4 sale thread. you dont need an uppipe yours already has no cat. As far as header gtspec genII are great i have one. and this comes with an uppipe that you have to use because its 3 bolt. I wouldnt do the pullies bad news there.
fastlanerex is offline   Reply With Quote
Old 03-23-2008, 02:42 PM   #23
Nuke209
Member#: 108089
2003 WRX
NF Performance
A good set of spring/strut will perform pretty damn well.
Old 03-23-2008, 02:47 PM   #24
fastlanerex
Member#: 133391
2004 boosted saleen
white
if you go with aftermarket struts of course....but if you just put springs on your oem struts than no it will ride like ****. if you get ohlins struts expensive or kyb you'd be fine but in the end you might as well get coilovers because it would run you about the same price.
Old 03-23-2008, 06:20 PM   #25
Symmetrical
Member#: 174613
2006 VF34'd WRX TR
[email protected]
I cant believe they suggested HKS downpipe
Symmetrical is offline   Reply With Quote
Kinda stupd question, but take a look and tell me what you think shamrock 05 Interior & Exterior Modification 16 10-10-2008 11:14 PM
take a look at my dle air control valve and tell me what you think skunkfifty Service & Maintenance 0 03-19-2008 02:14 PM
check one for gold on silver tell me what you think pestysti Tire & Wheel 7 03-11-2004 12:55 PM
Look at this ECU Pinout and tell me what you think? BoostdBoxer Electrical & Lighting 2 02-14-2004 05:08 PM
Read this and tell me what you think christoph1371 Bay Area Impreza Club Forum -- BAIC 34 07-13-2002 09:08 PM
