Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 03-21-2008, 07:25 PM   #1
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Default quick stock cluster issue question?
hey guys i am having some issues with my stock gauge cluster and was wondering if anybody else has also experienced this issue. i was driving for a while and my Speed-O began to bounce around then just peged out at 0mph.... this lasted for a while ive tried to cycle the key multiple times..... i just wanted to know if you guys had seen any shorts in this circuit before or if the vehicle speed sensors are common to go out..... it is an 05 STI 94k on the car thanks any input helps
osirissirhc is offline   Reply With Quote
Old 03-21-2008, 08:35 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Is the CEL on, and have you scanned for any codes? A failure of the vehicle speed sensor should set a code, if there are none and the speedo is dead it's probably in the cluster.
Another clue is whether the odometer works when the speedo doesn't. If the odo continues to work then the problem is definitely in the cluster, if it stops when the speedo stops then it could be either the sensor or cluster.
Old 03-21-2008, 10:54 PM   #3
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Default no cel
nope no MIL.... i stopped at a gas station and put ice on my inter cooler because im doing some traveling ....then thats when it started a few miles after i left the gas station and noticed it pegged at 0mph.... last time this happened i had just cleaned my engine bay so i figured it might be water getting on the connectors. i didn't happen to pay attention to weather or not the odo was counting or not ill check that out here in a few minutes .... i drove it around the parking lot and the speed o was going up to 5 miles an hr without bouncing like it did before.
Old 03-22-2008, 09:01 PM   #4
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Default working..
the speedo is working today..... no problems....... wtf..... is it a possible heat issue?
Quick stock exhaust manifold question dauss Newbies & FAQs 1 11-02-2007 07:40 PM
quick stock stereo swap question krambte79 Electrical & Lighting 0 06-15-2007 12:04 AM
2002 STi Cluster fitment questions, need quick help. DinosaurasWRX Electrical & Lighting 9 09-19-2006 08:26 AM
quick stock camber bolt question waktasz Brakes, Steering & Suspension 2 08-09-2006 10:51 PM
Quick Stock Subaru Subwoofer Question adamsrs Car Audio, Video & Security 1 08-14-2002 01:33 PM
