Old 03-21-2008, 08:28 PM   #1
scooby did !!
Member#: 174651
03 gonna be
different next year
Default when (if at all) to use cooler plugs
so its recently come to me that im gonna change my spark plugs on my 03 wrx (ive got 65k miles on the engine and previous owner beat the car up badly) im gonna change the turbo to possibly a vf 39 or 34 and ive just aquired the "blue" 06 wrx injectors i have a perrin up pipe, and aps tbe and a perrin intake. at what time if ever is it appropriate to use cooler spark plugs, and would it be noticable or is it just a waste of money ?
scooby did !! is offline   Reply With Quote
Old 03-21-2008, 10:07 PM   #2
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
The time to change them is when they (the actual plugs you're using) tell you to. Take them out and look at them; they'll tell you if they're overheating.
bulwnkl is offline   Reply With Quote
Old 03-21-2008, 10:24 PM   #3
jarvis210
Member#: 129547
2004 WRX Sti
Platinum Silver Metallic
They time to put colder plugs in is when you are producing more heat inside the combustion chamber. The colder plugs will dissapate the heat from the plug alittle faster than what the factory plugs would. This helps prevent detonations and sometimes may lower your EGT's. If you go with the vf 39 or vf34 you could go ahead and do the plugs. In either case you would be fine. The stock heat range would be fine but when your hp level increases the colder plugs provide alittle insurance to prevent detonation.
jarvis210 is offline   Reply With Quote
Old 03-22-2008, 12:13 AM   #4
scooby did !!
Member#: 174651
03 gonna be
different next year
thats true, i guess i will have to use the check and see method. probally gonna need them after all the extra vroom im gonna add.
When to use 2 stg colder plugs Porkchop-WRX Service & Maintenance 5 03-05-2007 09:25 AM
okay to use AT tranny cooler on 6 speed? petawabit Transmission (AT/MT) & Driveline 6 12-24-2005 10:53 PM
When to change spark plugs & what brand to use? Bradus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-01-2004 02:53 PM
if I wanted to use an EGT gauge to--> Matt K New England Impreza Club Forum -- NESIC 3 03-11-2004 11:52 PM
When is it safe to use Mobil 1 on new WRX. kovalov Engine Management & Tuning 2 12-12-2002 03:36 PM
