Old 03-22-2008, 11:19 AM   #1
Padge
Member#: 74412
'05 Impreza WRX STi
Obsidian Black Pearl
Default Can you top off transmission fluid or do you need to completely flush it?
My fluid is low and I dont have time today to flush and refill before traveling home. Im sure itll be fine, but now that I know its low ill be nervous.
Can it be topped off or do I have to do a complete flush? I have no idea what fluid is in there now.
Thanks.
Padge is offline   Reply With Quote
Old 03-22-2008, 11:56 AM   #2
daveyboy
Member#: 35419
Topping it off with a quality 75w/90 would be a good idea if you are going to be travelling.
daveyboy is offline   Reply With Quote
Old 03-24-2008, 08:02 AM   #3
Padge
Member#: 74412
'05 Impreza WRX STi
do i just get a long funnel and enter it in where the dipstick is?
Old 03-24-2008, 08:57 AM   #4
smurfwrx
Member#: 151928
09 Triumph S3
yes. You don't have to remove the intercooler if, like you said, use a long funnel. Just fill slowly so you don't overfill and have to drain it all out.
smurfwrx is offline   Reply With Quote
Old 03-24-2008, 09:37 AM   #5
Padge
Member#: 74412
'05 Impreza WRX STi
right now im at "L" or low... so any idea how much I could need?
1 qt?
Old 03-24-2008, 01:00 PM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Probably 1 qt. but you could always buy 2 qts. and have some extra for a rainy day.
~Josh~
Old 03-24-2008, 01:50 PM   #7
Daggah
Member#: 152077
2002 Integra Type R
Championship White
And it would probably be a good idea to go slow, add some, check dipstick, add some more, etc.
Daggah is offline   Reply With Quote
Old 03-28-2008, 04:37 PM   #8
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
You're worried about the wrong thing. No harm can come of adding additional gear oil to keep your level in spec (especially if you're adding the exact same oil as is in there already). At least, no more harm that running low.
What you should be worried about is: why am I losing gear oil???
Asinine is offline   Reply With Quote
Old 03-28-2008, 07:10 PM   #9
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
so its ok to mix any brand of oil?
EJ20_lee is offline   Reply With Quote
Old 03-29-2008, 12:54 AM   #10
magnum2066
Member#: 158586
2009 WRX
Pearl White
My personal opinion is that flushing transmissions, although now cleaner after the surface, will cause transmissions to bomb within the next few thousand miles.
magnum2066 is offline   Reply With Quote
Old 03-29-2008, 01:36 AM   #11
Engmus
Member#: 115645
Depends on the flush, and thats simply not true for manual transmissions.
Engmus is offline   Reply With Quote
Old 03-29-2008, 09:14 AM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
That's what I was thinking, too!
If this is a manual, you don't "flush" the transmission - just drain and fill (and topping off is just fine)
If it's an automatic, and the fluid is in good shape (not burnt), I would not do a flush. They can cause more problems than they cure (some manufacturers, such as Honda, strongly recommend against them - the procedure Honda specifies is repeated drain/fill cycles (5 of them - for our Odyssey, that gets a bit over 90% replaced)
Old 03-29-2008, 07:08 PM   #13
Asinine
Member#: 55173
with paddles.
Subaru discourages it, but not as much as they'd discourage running below the "L" line There are a lot of cocktails in use, but those aren't just randomly selected oils.
Old 05-02-2008, 07:20 PM   #14
isaias
Member#: 159822
2003 Subaru WRX
Thanks for this info. I was just searching for this as my car is running low on tranny oil.
isaias is offline   Reply With Quote
What do I need to complete a shortblock? oldpreza Normally Aspirated Powertrain 3 11-18-2009 10:21 PM
topping off transmission fluid. misfitracer25 Service & Maintenance 16 09-15-2009 12:33 AM
Pizza: Do you eat the end crust or do you leave it behind and go for the next? brucelee Off-Topic 28 05-17-2008 04:47 PM
Are you a creature of habit or do you mix it up? Hamsterstyle Off-Topic 14 10-03-2005 05:37 PM
Can I use just a turbo or do I need more? WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-01-2003 03:09 PM
