Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 03-22-2008, 06:02 PM   #1
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Default CEL constantly flashing
Ok, so I tore down the front of the engine (92 2.2), and replaced the crank sprocket, keyway, pulley, oil pump gasket and crank seal. Timing belt was still decent, as the white marks were still visible, and no visible wear. While doing this, I removed the battery so the computer would reset.
Now, the car fired up perfectly first time, no problems. Runs great, I'd say probably better than before, as the crank sprocket was able to move a bit before. However, the CEL is constantly flashing at me now. What's the deal with this?
Speedwagon is offline   Reply With Quote
Old 03-22-2008, 07:25 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
throwing a code non-stop, meaning it is doing bad things non-stop. Either that or you hooked up the two plugs under the dash that make it do the same thing..
good luck
JS
gtwagon941 is offline   Reply With Quote
Old 03-22-2008, 08:08 PM   #3
Speedwagon
Member#: 19681
Green
Whoops! I undid the wrong black connector! All is better now.
CEL and flashing cruise, help please? aznatama Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-25-2004 04:57 PM
emanage constant flashing red light BoostdBoxer Engine Management & Tuning 1 02-27-2004 09:08 PM
CEL is flashing WrXtremeEJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 11:22 AM
TB throws CEL and flashing cruise wgknestrick STi Forum Archive 7 08-02-2003 06:02 PM
CEL with flashing cruise light help needed Wombat North STi Forum Archive 3 07-05-2003 01:10 PM
