Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 03-22-2008, 08:34 PM   #1
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
Default Oil Filter Question
I need to change my oil tomorrow, but I was unable to get a oil filter/crush ring from my local Suby dealer(closed). I checked in my owners manual for the part number, but was unable to find it. So my question is.
1. Anyone know what the oil filter part # is?
2. Has anyone used a FRAM oil filter before, is it alright (thats what Murrays carries)
3. If by chance I cant get a crush ring, will it be ok?
Thanks guys
Ryan
shamrock 05 is online now   Reply With Quote
Old 03-22-2008, 08:43 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
That crush washer is for the drain bolt not the oil filter...Just in case you didn't know. And you can re-use the old one if you have to, tho a new one would be better.
wrxdrvr is offline   Reply With Quote
Old 03-22-2008, 09:11 PM   #3
mikeythejew
Member#: 141672
07' wrx
Mothballed until winter
You would be better off using a supertech oil filter bought at Walmart, if they have one.
mikeythejew is offline   Reply With Quote
Old 03-22-2008, 09:37 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
subaru part number for the items
filter 15208AA100
crush ring 11126AA000
Jamie
Old 03-23-2008, 12:59 AM   #5
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Best oil filter available for us is an Amsoil. Nowhere near the price point of Fram or Supertech, though.
bulwnkl is offline   Reply With Quote
Old 03-23-2008, 01:42 AM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I have never been a fan of the Fram glue and cardboard approach - Purolator would be a better choice (unless you can get OEM)
Old 03-23-2008, 11:48 AM   #7
mostasz
Member#: 170512
2012 WRX
Ice Silver
Just changed oil two days ago. If U go for for best oil (I got Castrol Syntec 10W30), go for best filter too!! I used Mobil 1 filter, got it in AutoZone. Price is around $10. Tell them what car U drive, they will give U choice of filters.
I used Fram on my 2000 focus, with mineral oil, but focus is not high performance turbo car....
I reused crush washer.
mostasz is offline   Reply With Quote
Old 03-23-2008, 12:34 PM   #8
Fetteichhornchen
Member#: 105689
2009 STI Hatch
Oil Filter part numbers:
AC DELCO: PF2192
AMSOIL: EAO12
BECK/ARNLEY: 041-8074
BOSCH: 3310
DENSO: 150-1006
FRAM: PH3593A
FRAM TOUGH GUARD: TG3593A
FRAM DOUBLEGAURD: DG3593A
FRAM X2: XG3593A
K&N: HP1015 (STi)
HP1008 (WRX)
MOBIL1: M1-108
M1-112 (old #)
PUROLATOR: L14460
PUROLATOR PURE ONE: PL14460
SUBARU OEM: 15208AA100
WIX: 51365
I would recommend OEM, Mobil 1, or Purolator Pure one. Depending on price and what you have avaliable to you.
The crush washer should be easy to find at any auto parts store. Just tell them what vehicle you have and they should be able to find you one.
Fetteichhornchen is offline   Reply With Quote
Old 03-23-2008, 02:27 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Here's a site with cross sections of a bunch of the filters for a WRX/STi
http://www.bescaredracing.com/sti/oil/filters/
If you can't get the OEM filter, I'd go with Purolator Pure1 or PremiumPlus, Proline, Totalgrip - the M1, Wix, etc. have seemingly a much lower filter media surface area (around 50-60% as much as the OEM filter) along with other shortcomings.
Old 03-23-2008, 03:22 PM   #10
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
I'll elaborate just in case: Amsoil is the best filter based on UOAs for its combination if superior filtration and outstanding flow (especially cold or for all of you that use a thicker-than-recommended oil). Second is K&N/Mobil 1.
Old 03-23-2008, 03:32 PM   #11
mxpop
Member#: 103776
2006 STI
FWIW,
Cosworth recomends the OEM filter on all their SUby motors.
mxpop is offline   Reply With Quote
Old 03-25-2008, 09:19 AM   #12
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
From now on I will always use a OEM (dealer closed), but I stopprd at Napa and got a Wix. Wix makes a lot of filters and just puts other company names on it, from what I have heard
Old 03-26-2008, 03:41 PM   #13
Haelan
Member#: 151045
2013 Subaru STI
CBP
OEM filters seem to do a good job. I bought a box of 6 from: https://www.subarugenuineparts.com/p...roducts_id=790 for around $40
Look into getting a Fumoto Quick Oil Drain Valve too. No more mess or crush washers.
Haelan is offline   Reply With Quote
Old 03-26-2008, 04:18 PM   #14
cobbler
Member#: 70947
i've been thinking about investing in one of those to. now to just find an easier way to switch filters and i wont have to worry about washing oil off my hands
cobbler is offline   Reply With Quote
Old 03-26-2008, 04:23 PM   #15
Haelan
Member#: 151045
2013 Subaru STI
CBP
I wrap a plastic grocery bag around the filter when taking it off. Between that and the Fumoto my hands are pretty clean when I'm done.
Old 03-26-2008, 04:45 PM   #16
cobbler
Member#: 70947
not a bad idea
Old 04-10-2008, 06:09 PM   #17
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
Where can you get this????
Is it cool to just tighten the oil filter by hand????
Old 04-10-2008, 07:13 PM   #18
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Yes. Do not use a wrench to install the oil filter unless you have weak hand strength. The filter or its box will tell you how much to tighten it, but they're basically all in the range of 1/2 - 1 turn after the gasket makes contact. If you can't get it quite that tight by hand, just get it as close as you can by hand.
Old 04-12-2008, 01:37 PM   #19
prometheum
Member#: 92003
04 bicycle!
yes hand tight only, 3/4 turns after the gasket makes contact with the motor
prometheum is offline   Reply With Quote
Oil filter question. how to open a wix oil filter... Keith Off-Topic 33 12-18-2007 06:39 PM
Oil filter question Big_Hitter Texas Impreza Club Forum -- TXIC 14 07-05-2002 08:17 PM
oil filter question (paranoia) IggDawg Normally Aspirated Powertrain 17 03-15-2002 03:24 PM
Amsoil oil filter question kastle Technical Forum Archive 7 05-31-2000 01:53 AM
