#1 |
Member#: 144772
Vehicle:2002 WRX Wagon Silver |
Hi guys,
Just wanted to get your opinions on my problem before i take the car to the shop. four days ago I installed a haltech E11 standalone ECU for my 02 WRX. Two days later Im getting a cloud of white smoke from the tailpipe. This has happened twice now and both time it happened uring hard acceleration when im at full boost running at about 5,500 rpm. The first thing that happens is a thump sound, (doesn't sound like somithing has been hit, more like if suddenly something blocked the tailpipe... thump.) Immediately after this i loose all power, the engine literally turns off. So, both these times im in the car, smoke coming out the tail pipe, the engine turned off (switch is still open) and im rolling to the curb. The car won't start until I've let it sit fot about one or two minutes. When it runs againa there is no smoke. Exhaust just smells like exhaust, no gas smell. Coolant level seems fine. I wonder if it puffs out white smoke, shouldn't it be doing it all the time? Im running a VF 34, upipipe and turboback, short ram intake (not using the MAF on the haltech).
#2 |
Member#: 158055
Vehicle:2002 wrx wagon black |
dude how many pounds of boost where you running and when you start the car back up did it smoke again/ i had the same problem and i found i only have 3 psi of compression in cylinder 4 so my motor is blown.
#3 |
Member#: 133391
Vehicle:2004 boosted saleen white |
when you hear thumps from the tailpipe 9-10 times its a missfire. as for white smoke thats normally coolant.
MY best guess is a blown head gasket |
#4 |
Member#: 144772
I was running 14 psi. I did a compression test about a year ago and its was just above passable. Maybe its time to check again. I also think it may be a headgasket. I'm having the engine opened and have then check the gaskets, bearings, and rings.
But my question still remains.. if its coolant, should it be smoking all the time? Or does it just happen under stress, like from a 14 psi boost run? |
#5 |
Member#: 133391
it all depends id have to see it to diagnose this problem
#6 |
Member#: 118566
Vehicle:2005 WRX OBP |
You could be pushing coolant past the head gasket when the pump builds enough pressure in the system, not something I've experienced just a theory from the data you've provided.
| Thread Tools | |
| Display Modes | |
| Complete Power Loss Under Load | luka | Pre-2002 Factory Turbo Powertrain | 68 | 03-20-2009 01:25 AM |
| Ea82T with white smoke and Loss of Power | RoboTakeover | 'Old School' Subaru Forum | 9 | 08-10-2008 08:11 PM |
| 2.5 RS Borla Headers and Turbo... Power Loss? | tallicaguitar88 | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 07-25-2005 02:07 PM |
| CEL and sudden power loss on 02 WRX | cinder | General Community | 8 | 04-07-2005 07:14 PM |
| I have been noticing small amount of white smoke, and an apparant coolent loss... | PaulRex | Factory 2.0L Turbo Powertrain | 1 | 07-09-2003 10:12 PM |
