Old 03-23-2008, 07:05 PM   #1
RoadTrippin
Member#: 161175
Default Possible to over-tighten a hose clamp?
This may sound a bit stupid but I have to ask anyways. I noticed a little bit of coolant leaking from the upper radiator hose where it meets the engine block. So, I took a screw driver and tightened the hose clamp to the point where I wasnt able to turn the screw anymore. Nothing snapped, the hose didnt crack or anything but what I am wondering is over time could this possibly be bad for the hose?
TIA
Dave
RoadTrippin is offline   Reply With Quote
Old 03-23-2008, 07:28 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The clamp "could" work it's way into the hose and fray/mangle it if it's realy over tight but usually it should be OK...
wrxdrvr is offline   Reply With Quote
Old 03-23-2008, 07:35 PM   #3
RoadTrippin
Member#: 161175
Excellent, just what I was hoping to hear.
Old 03-23-2008, 10:22 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
generally speaking, the hose clamp won't snap - usually the worm gear damages (bends) the band, or the worm gear can pull itself through the housing. If the clamp is too tight, it can "extrude" the hose through the holes in the band, but this is generally more of an issue with silicone hoses, and can be avoided altogether if you use a lined hose clamp.
Old 03-23-2008, 10:26 PM   #5
Mechie3
Member#: 120152
Cut worm gear clamps can cut the hose as noted above
The worm gear clamps where the screw drive is pressed in (ie, not cut out) are a little better as they are smooth and won't cut tubes. Overtightening these can make the drive skip (loosen)
T-clamps are the best, overtightening these can cause the screw to break (I did it once) but mostly only on cheap clamps.
Mechie3 is offline   Reply With Quote
Old 03-24-2008, 07:46 PM   #6
DFv2
Member#: 173774
2008 STi
Lightning Red
If you were using a screw driver, no worries. You can't really impart enough torque to deform the worm gear with a screw driver. Put a bit on the end of your 1/4" ratchet and its a different story. When it does become damaged, you will find that its *easier* to torque than it was before. If it got more difficult and then impossible to turn, you're most likely fine.
DFv2 is offline   Reply With Quote
tmic to TB T-bolt hose clamp size subynation Newbies & FAQs 6 02-28-2010 12:30 AM
Where to get rubber Radiator Hose + Clamps? Superorb Private 'Wanted' Classifieds 4 04-21-2009 11:25 AM
Is it possible to tighten top of strul/coil while its on the car? sepulcherx Brakes, Steering & Suspension 2 09-30-2005 06:32 PM
samco i/c hose install. do i need to use hose clamps?? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-12-2002 12:27 PM
Is it possible to over cool your water and coolant? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-25-2002 03:09 PM
