Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 03-24-2008, 01:23 PM   #1
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
Default Question about PCV change for 2004 WRX
Anyone replace their PCV valve, if so at what mileage? I also read somewhere that for the 2004 and on wrx, subaru changed the location of the pcv valve and made it so you had to buy the whole elbow and pcv assembly in order to replace it. Anyone know the correct part number for it? I also remember reading that some subaru dealerships said the pcv was an unserviceable part and did not need regular replacement. Is there any founding to this?
QwikRex is offline   Reply With Quote
Old 03-24-2008, 01:44 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
i changed mine (2002 wrx ) and i also read that the location changed but there are a few install FAQs and directions on the forum if you search for a few minutes. I used a $5 valve i bought at NAPA and the install was very very easy, even if they moved it around it shouldnt be much harder to install.
As for not servicing the valve.. well.. when i removed my original one i was able to get it to stick closed if i shook it. sure i could have cleaned it, but they are cheap and should be serviced every 50k or so in my opinion.
PaulRex is offline   Reply With Quote
Old 03-24-2008, 02:12 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
The part is available at NAPA for probably 3 or 4 bucks. Take off the intercooler and it's really easy to get to. I replaced mine when I bought the car (28,000 miles).
Haelan is offline   Reply With Quote
Old 03-24-2008, 07:53 PM   #4
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
This link shows the 2004 and up wrx pcv to have an attached elbow/t-fitting: http://www.clubwrx.net/forums/showth...t=98574&page=5
I called all the subaru dealerships in my area for this, which is part#: 11819AA001 but none had it in stock. Anyone else have experience changing their pcv valve?
Old 03-26-2008, 11:00 AM   #5
QwikRex
Member#: 40284
2007 370z sport 6MT
Magnetic Black
Anyone?
Old 03-28-2008, 04:34 PM   #6
Asinine
Sufficiently Sharky
Member#: 55173
with paddles.
IIRC, a few places said that it was actually cheaper to buy the part with the elbow included than not included. But yeah, it's technically not a servicable part in the respect that there is no recommended schedule for replacing it. Check out the sticky thread on scheduled maint. at the top of the forum for more detaild info.
Asinine is offline   Reply With Quote
Old 09-14-2008, 02:17 PM   #7
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
I have a 05 wrx and it has the same PCV valve, I ordered the whole asembly for my car.
Rippen Griffen is offline   Reply With Quote
Old 09-15-2008, 11:39 AM   #8
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default pcv
i have an 07 n/a . anyway i change my pcv valve like every 10 k when i do my spark plugs. mine is in the rear of the engine. just follow your vaccum lines one of them will hold the pcv valve.
i go to subarupartsforyou.com way cheaper than the dealer and quick shipping here on the east coast
watchunglava is offline   Reply With Quote
Old 09-15-2008, 11:40 AM   #9
watchunglava
Member#: 168862
Default pic
u can see the valves nut in that picture
Old 09-30-2008, 04:25 PM   #10
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Where is the 04 valve located? Anyone has a pic? Thanks...
Gunner is offline   Reply With Quote
Old 10-11-2008, 11:35 PM   #11
2:43AM
Member#: 190273
05 WRX evoIII-16G
What does the pollution control valve actually do and why would one need to replace it? Isn't it just crankcase gases being let back into the intake?
Sure I've replaced them on my OLD cars, but I haven't replaced one since. Does a new one actually improve anything (like MPG), or is that just what "the man" says for you to do?
2:43AM is offline   Reply With Quote
Old 10-12-2008, 10:56 AM   #12
onesixnin
Member#: 50992
02 Bugeye
um..positive crankcase ventilation valves for the 04 are available from jamie at SGP. It's where I got mine. It came with the elbow/hoses. It was more of a pain than it needed to be. Get replacement hose clamps.
kaytanksbuy
onesixnin is offline   Reply With Quote
Thinking about trading in my 2004 wrx for a 2006 wrx 04WRBWRX Newbies & FAQs 11 04-17-2007 06:41 PM
Where is the PCV valve for 2004 WRX CoolRex Service & Maintenance 22 01-11-2007 09:08 PM
Question about PCV valve... SPECTRE2099 Newbies & FAQs 2 01-05-2007 02:38 AM
Question about Bi-Xenons for 05 WRX Knightmare69 Electrical & Lighting 10 11-17-2006 06:29 AM
question about pcv valve-Instead of replacing just soak in cleaner? garie Service & Maintenance 6 12-01-2005 09:32 PM
