Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 03-24-2008, 02:47 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default How To: 2008 WRX/STi Coilover Install
This is a how to install for 2008 Impreza Coilover install.
The factory suspension is very well designed, but as other previous models has room to improve on. And this is where the Cusco Zero2-E coilovers come in. They offer a great Daily Ride, and can be a powerfull tool at AutoX and Track Days.
Things needed:
Coilovers
Tools:
19MM Socket (6 point)
19MM Open end Wrench
12MM Open End Wrench
14MM Deep Socket
14Mm Open End Wrench
17MM 6 point Socket
17MM Open end wrench
Allen key to hold the sway bar end link from spinning.
Braker Bar
Torque Wrench.
And misc. extensions
1) Jack up the car, Put it on Jack Stands, and take off the tires.
2) Front Suspension is first. Take off the Brake line and the ABS wires off the Strut.
3) Take off the 2 lower bolts that hold the strut to the knuckle.
4)Take off the 3 top bolts that hold the top hats to the Chassis. Be careful, as the strut will be out after this. So make sure not to damage your outer axle boot.
New Vs Old
As you can tell the new coilovers are VERY low. We had to raise them about 1" to clear our race rims w/ tires. However with stock rims you might be able to get away with running the drop. But they are LOW!
5) Now go backwards. Put the top hat in so that the camber plate is sitting side to side. And tighten the top hat bolts.
6) Attach the Brake Line and the ABS wires to the strut.
RallySport Direct is offline   Reply With Quote
Old 03-24-2008, 02:48 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
7) Now insert the 2 lower Bolts to attach the strut to the knuckle. And Place the Camber bolt so that your tires to not rub on the strut. (Be careful, as this can ruin a brand new set of tires and coilovers very fast if not set up properly)
Rear
8) Rear is straight forward. Make sure that the rear sway bar is not attached to the suspension, as it will not allow the arm to drop far enough to get the stock strut and spring out.
9) Take out the middle bolt thats in the picture as that holds the strut to the lower arm. This thing is TIGHT! So a breaker bar and a 6 point socket are a MUST to not strip the nut!
10) Take out the trunk mat and the 2 plastic side pieces to expose the top of the rear suspension. The 2 plastic covers on the inside have tabs on the back of them that will need to be slid up to allow the Covers to come out.
11) Take off the 2 top hat bolts and the rear suspension will be ready to come out. At this point you will need to press the lower suspension arm down to give you enough clearance for the strut to come out.
OLD VS NEW
12) Now work backwards. Put the Top hat in place and tighten the 2 nuts. Then jack up the lower arm so that the new strut will go into the lower arm and insert the bolt. TQ spec for the lower arm is 100ftlbs according to a local tech. And now tighten the end links as well that you removed.
You are almost Done!
After you do all 4 corners make sure all the spring purges are tight, and that all the hardware(bolts) are tight to factory spec.
Lower the car and tripple check everything. Then slowly start doing figure 8's and listen for rubbing or clunking. If everything is ok, go and get a alignment ASAP!
Old 03-24-2008, 02:48 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
Enjoy!
Kirill
RallySportDirect.com
Old 03-24-2008, 05:39 PM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Are these 08 STi specific or are they from another model?
Old 03-24-2008, 05:42 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
They are 2008 Sti Specific.
But this install should be the same for other 08 Impreza models.
Old 03-24-2008, 06:05 PM   #6
MartinD
Member#: 57231
Price?
Looks great BTW.
MartinD is offline   Reply With Quote
Old 03-24-2008, 06:17 PM   #7
RallySport Direct
Member#: 33174
We are Open Late!
Originally Posted by MartinD View Post
Price?
Looks great BTW.
PM Sent
Old 03-25-2008, 12:17 PM   #8
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
I love my Cuscos! Makes a big difference on the 08s!
lateralus1082 is offline   Reply With Quote
Old 04-11-2008, 06:23 PM   #9
RallySport Direct
Member#: 33174
We are Open Late!
This man speaks the truth!
Old 04-11-2008, 08:05 PM   #10
08blackpearl
Member#: 166199
2013 BRZ LIMITED
Cost shipped to 58501, and do you have the Power bracers, sways, and strut bars in stock. Going to be a Cusco whore!
08blackpearl is offline   Reply With Quote
Old 04-14-2008, 11:45 AM   #11
RallySport Direct
Member#: 33174
We are Open Late!
PM Sent
Old 04-14-2008, 02:07 PM   #12
Nukabe
Vendor
Member#: 166475
Awesome write up guys!! Great!
Nukabe is offline   Reply With Quote
Old 09-27-2008, 06:33 PM   #13
mdeang
Member#: 190250
2008 Impreza
Dark Grey Metallic
thanks!
mdeang is offline   Reply With Quote
Old 10-06-2008, 01:31 AM   #14
rice or die
Member#: 191034
1992 legacy turbo
sweet!
rice or die is offline   Reply With Quote
Old 10-06-2008, 01:31 AM   #15
rice or die
Member#: 191034
1992 legacy turbo
oh and thanks!
Old 10-06-2008, 01:32 AM   #16
rice or die
Member#: 191034
1992 legacy turbo
awsome write up aswell
Old 04-18-2009, 12:22 AM   #17
fragroute
Member#: 177767
2008 WRX 5dr 5MT
Spark Silver Metallic
Default alignment numbers
what kind of alignment numbers have you used, especially camber? what was the net drop?
fragroute is offline   Reply With Quote
Old 04-20-2009, 12:03 PM   #18
RallySport Direct
Member#: 33174
We are Open Late!
It all depended on what the car was used for that weekend. We have ran the drop on average of 1.5" over stock.
On the street the camber was -2.5 Front, and -2.0 Rear
On the Track, front was -4.2, Rear was -2.0
Old 04-22-2009, 12:33 PM   #19
@NT
Member#: 207366
Thanks for the write up!
Do you have anything else done to the suspension? I dunno if the WRX is different, but there is a guy who has a 2008+ WRX with BC coilovers on his car and he can only get -1.5* of camber out of the front. How are you getting that much camber?
@NT is offline   Reply With Quote
Old 04-22-2009, 12:41 PM   #20
RallySport Direct
Member#: 33174
We are Open Late!
The car has extensive suspension work, as its set up for road racing.
However for the front camber, that was with Maxing out the front camber plates along with maxing out the front lower Camber bolts.
Old 04-23-2009, 02:14 AM   #21
@NT
Member#: 207366
Any roll center adjusters? SCC is doing a tech article on a 2008+ WRX and they replaced the roll center adjusters to get more camber. Is that really necessary?
Old 04-23-2009, 01:25 PM   #22
RallySport Direct
Member#: 33174
We are Open Late!
The Roll Center kit allows you to bring the lower control arms and the outer tie rods to a proper angle. If the vehicle is lowered to much the arms get flipped, causing what is know 'bump steer', and a couple other issues. But it is not REQUIRED.
Old 04-23-2009, 09:53 PM   #23
@NT
Member#: 207366
To my understanding, because of the strut design, the lower the car is, less negative is achievable.
ENTER Roll Centers.
Thanks for your help, I'm only concerned because I want to run an aggressive setup and I need camber. 1.5* won't cut it.
Old 04-24-2009, 06:44 AM   #24
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
With regard to alignment: do you give it extra caster (not camber) since you dropped the nose a bit more than the back (or so it seems)?
IIRC, more caster gives better straight line stability vice versa?
Thanks,
Walter
Beetspeed is offline   Reply With Quote
Old 04-24-2009, 01:21 PM   #25
RallySport Direct
Member#: 33174
We are Open Late!
ENTER Roll Centers.
Roll center kits will bring down the outer tie rods and front lower ball joint. So if you go so low that your arms are not facing up, they will help to bring them down to a more reasonable angle.
HOW TO: Prova Steering Wheel 2008+ WRX/STI RallySport Direct NASIOC Project Cars 66 10-28-2015 05:57 PM
How To: 2008 STi StopTech Big Brake Kit RallySport Direct Brakes, Steering & Suspension 48 08-05-2010 02:25 AM
How To: 2008 STi HKS axle back. RallySport Direct NASIOC Project Cars 15 02-18-2010 02:40 PM
How To: 2008 STi HKS Hipermax III Sport Coilover Install RallySport Direct NASIOC Project Cars 11 08-25-2009 11:39 AM
How To: 2008 STi Radiator Shroud RallySport Direct NASIOC Project Cars 9 06-23-2008 05:24 PM
