Old 03-24-2008, 03:01 PM   #1
recruitX
Member#: 151838
02 WRX
Default Tear in tie rod boot! What do I need to replace?
While doing an oil change last week, I observed that there was a tear in the boot that is on the tie rod near the steering rack (inner tie rod?)
Is it possible t o replace just the boot, or do I need to replace other parts as part of the assembly. What parts need to be taken apart and/or replaced?
The car is an 02 WRX.
recruitX is offline   Reply With Quote
Old 03-24-2008, 03:08 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
it is possible to replace just the boot. All you have to do is take the tie rod end off and slip on a new boot full of grease, then clamp it down. Takes 30 minutes or so.
Tony
Old 03-25-2008, 12:42 AM   #3
recruitX
Member#: 151838
02 WRX
Tony
Your thinking of the boot that goes on ball joint of the tie rod end. I tore the boot that looks like the axle boot.
Old 03-25-2008, 02:48 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
No, he's talking about the inner tie rod boot. Separate the inner and outer tie rods, pull the old boot off, put the new boot on, do up its buttons. Taste and enjoy.
Old 03-25-2008, 10:11 AM   #5
strohausii
Member#: 26770
'02 WRX
midnight black
Are you getting any feed back from the suspension (has the joint fouled)?
Just curious, I've never had a Ball Joint or Tie Rod die on me before...
strohausii is offline   Reply With Quote
Old 11-02-2009, 08:42 PM   #6
RallySuby
Member#: 64600
'01 2.5RS
black
re opening this thread. Same situation. Any specific grease to fill the boot with before installing?
RallySuby is offline   Reply With Quote
Old 11-07-2009, 02:43 PM   #7
rlucy18
Member#: 113465
2004 WRX STi
Slvr
I too am curious what grease to use in the steering rack boot. I am about to replace an inner tie rod and boot just got the new ones in the mail today Any advise or links would be much obliged.
rlucy18 is offline   Reply With Quote
Old 11-08-2009, 11:36 AM   #8
RallySuby
Member#: 64600
'01 2.5RS
black
...bump
Old 11-25-2009, 01:22 AM   #9
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
where did you order these from?
thanks
rex n effect is offline   Reply With Quote
Old 11-25-2009, 03:46 AM   #10
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
subarugenuineparts.com is a good place to go.
BeBop86 is offline   Reply With Quote
Old 12-04-2009, 02:25 PM   #11
C 007
Member#: 225990
Chapter/Region: HIIC
2016 WRX STI
WRB Pearl
I don't think there is grease that goes into the steering rack boot. The only grease I used was to slip the boot over the rod itself. The steering rack boot is just a dust shield. Doesn't keep grease in like the cv boot.
C 007 is offline   Reply With Quote
Old 12-10-2009, 01:07 AM   #12
rex n effect
Member#: 15289
02 wrx pollen silv
I verified the above post at the dealer, just to make sure. The inner tie rod ball joint comes lubricated and requires nothing additional. I also put a little bit of grease around where the boot is snug on the tie rod. It needs to allow the tie rod to turn during toe adjustment.
what do i need to replace when the airbags go off? dougfeature Service & Maintenance 11 10-26-2015 01:14 PM
'00 Impreza RS coupe throwing P1442, P0136, P0141... What do i need to replace? 97 Pimpreza Normally Aspirated Powertrain 3 02-07-2010 01:40 AM
Damaged Rear from Towing - What do I need to Replace? Fiftyfive Transmission (AT/MT) & Driveline 15 09-07-2009 10:31 PM
so what do i need to replace. maverick326 Newbies & FAQs 4 10-20-2007 08:45 PM
Just turned 50K on my RS, what do i need to replace? mmmprza Normally Aspirated Powertrain 6 03-18-2004 03:39 PM
