Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Car Care & Detailing
Closed Thread
Old 03-24-2008, 04:26 PM   #1
RaceWeapons.com
Vendor Sales Rating: (0)
Member#: 169311
Default Spring CLEAN Items !
Let RaceWeapons help you get your car ready for summer with our spring items Red line oil, Timing Belts, Filters, ect if you have any questions PM US !
http://www.raceweapons.com/catalog/E...nce--89-1.html
RaceWeapons.com is offline
Old 03-24-2008, 04:27 PM   #2
RaceWeapons.com
Member#: 169311
Check out the Engine Maintenance Section !
Old 03-24-2008, 05:37 PM   #3
RaceWeapons.com
Member#: 169311
Old 03-24-2008, 06:52 PM   #4
RaceWeapons.com
Member#: 169311
Bump !
Old 03-24-2008, 08:48 PM   #5
RaceWeapons.com
Member#: 169311
the top 10 ways in which people kill their cars.
Are you killing your car?
The old mantra if you look after your car, your car will look after you certainly holds true. Car ownership is becomming more and more common.
Sadly though few drivers are sympathetic to, or fully understand the way their car works. A little knowledge will keep your relationship with your car running smoothly!
Without realizing it many drivers are actually damaging their car or at very least running up a hefty repair bill.
Here are the top 10 things that TorqueCars sees people doing every day completely oblivious to the consequences. Most of these points will at the very least hit us in our pockets in the near future.
10 things that will kill your car! How many are you guilty of?
1) Oil changes and servicing - Engine oil is the vital component in your car. Some people will wrongly assume that if the car takes 5 litres of oil and they have topped up this year by 5 litres that there is no point in changing the oil. Oil degrades and the reduction in oil is due to the thinner high quality oil getting burned or just seeping out of the engine. The sludge, grime and metal particles build up in the residue so topping up is not the same as changing the oil. The oil level is dangerously low in over 70% of cars - check your oil levels today.
2) Incorrect tyre pressures - cause additional heat to build up in the tyres due to the extra flexing. The car has to work harder reducing your fuel economy. With under inflated tyres the handling becomes unpredictable at best. Braking is also significantly reduced.
3) Not allowing turbo to cool down - How many people with turbo driven engine drive it hard and then fail to allow the turbo to cool down properly? The turbo is spinning at 200,000 rpm and gets very hot, the moment you turn off the engine you starve it of fresh oil. The oil in the turbo gets fried and essentially leaves your turbo spinning with no lubrication. Your turbo will need replacing if this is your driving style.
4) Driving off too quickly when cold - Until an engine is warm it will run rich. Your engine is most at risk from damage when cold, so putting undue stress on it by high revving will exponentially increase the damage done. The combustion process does not become efficient until the engine reaches it's operating temperature. An inefficient burn leaves acids and other toxins that eat into your engine. The oil also takes a short while to flow properly so ideally you would let the engine tick over for 3-10 seconds, then drive off at a steady pace. Do not use the top 2 thirds of the rev range until the engine reaches operating temperature.
5) Short journeys - Just as driving off too quickly damages an engine so will doing short journeys. The problem with a short journey is that the engine never reaches its operating temperature. So for the reasons detailed in the driving off too quickly do not drive short distances. (Use the under 1 mile - walk philosophy!) The engine oil needs to reach its maximum viscosity to properly lubricate the main moving components in the engine. While cold the catalyst is unable to operate at peak efficiency thus reducing the life of your expensive catalyst.
6) Revving to high - The red line indicates the maximum permissible engine speed. At this point the engine is under enormous stress and the components are moving at their fastest speed. Slight imbalances in the engine are emphasised at high rpm and if you prolong the high rpm for a period of time you will more than likely throw a connecting rod through the sump. The older an engine is the lower the red line should be. As an engine produces peak power across the middle third of its rev band there is little point exceeding this.
7) Hand on gear stick - So many people do this but it can actually cause premature gear wear. The stick is connected directly to the gearbox so the slightest pressure is transmitted to the gear selector. This is enough to cause wear and eventually your gearbox will start to grind and crunch as you change gear.
8) Riding the clutch - Again keeping a foot on the clutch is enough to prevent it from fully engaging. The clutch plate will tend towards slip and will prematurely wear. Keeping the clutch depressed in traffic or at traffic lights is also a bad idea. When the clutch is depressed your are forcing the clutch against the release bearing. Eventually the release bearing will just give up having done 60,000 miles worth of pressure in just 10,000.
9) Wrong gear selection - Nothing puts a strain on the engine like forcing it to pull the car in the wrong gear. Too high a gear strains the bottom end of the engine around the crank and con rods. Too low a gear will mean you are revving more than you need to so the top end of the engine around the valves, cams and lifters are working too hard.
10) Driving a dirty car - This one is a little contentious but corrosion takes effect more easily on a car which is covered with a layer of dirt. A thorough clean each month and a coat of good quality wax will do much to enhance the cars defence against corrosion.
So how many of these are your guilty of? Have we missed any out? Why not join us in the forum and chat with our friendly resident car enthusiasts.
Old 03-25-2008, 12:37 PM   #6
SubieRon
Member Sales Rating: (28)
Member#: 64485
2004 GGA
thanks for the tips...
SubieRon is offline
Old 03-25-2008, 01:04 PM   #7
RaceWeapons.com
Member#: 169311
Yeah no problem !
Old 03-25-2008, 06:14 PM   #8
RaceWeapons.com
Member#: 169311
Oh we also have 2008 cobb springs !!!!!
http://www.raceweapons.com/catalog/2...ings--193.html
Old 03-26-2008, 12:20 PM   #9
RaceWeapons.com
Member#: 169311
1, 2, 3, Bump !
Closed Thread
FS: Spring Cleaning - random stuff, includes non-car items vusalterego MWSOC Private Classifieds 8 03-19-2010 03:04 PM
Spring Cleaning!! Discontinued & Used Items Up For Sale! Audio Integrations Interior/Dressup/Audio & Security 16 07-14-2008 07:42 PM
Spring cleaning sale. 02 WRX spring, lips, wheels. TeamASR Tri-State Area Private Classifieds 8 04-28-2006 09:26 AM
Local Items For Sale...MISC. SPRING CLEANING ptsmalls Tri-State Area Forum 26 06-24-2004 11:49 AM
