Alaskan Impreza Club
Old 03-24-2008, 06:38 PM   #1
atcsubaru
Member#: 116985
2004 Subaru WRX
Default Just got back and...
So i just got back from Kirkuk, Iraq, and my wife told me she had to jump my car a while back because the battery died. Well from how she told me she did it makes it sound like she messed up and now my battery won't charge even after letting it run for 15-20 minutes. So i guess i am asking if anyone might be able to tell me whats wrong just by my short story. As the battery doesn't seem like it isn't getting charged, I would think of the alternator.
Is there any way of testing this with out haveing to pull it out? And if it the problem how hard is it to change? The last one i changed was on a 66 Chevell and I imagine the chevy was way easier than this is going to be.
Thank you.
Todd
atcsubaru is offline   Reply With Quote
Old 03-24-2008, 06:50 PM   #2
White_Rice
Member#: 160049
easy as pie......10mm on the posts. and I think it might also be 10mm on the tie down.
White_Rice is offline   Reply With Quote
Old 03-24-2008, 07:05 PM   #3
ridestreet84
Member#: 132030
2007 obp STI
broken again
if you are on base i can bring a multi meter by and test it
ridestreet84 is offline   Reply With Quote
Old 03-24-2008, 07:14 PM   #4
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
start the car, ground the multimeter on the battery, and put the positive node on the multimeter on the bolt with the power cable coming off the top of the alternator. if it reads voltage the alternator is working. i've got an alternator sitting around if u need one.
t4nk is offline   Reply With Quote
Old 03-24-2008, 07:31 PM   #5
atcsubaru
Member#: 116985
2004 Subaru WRX
Yep I am on base, and some one must be bored at work cuz i think my wife talked to Phil. I am in silver run housing btw.
Old 03-24-2008, 07:37 PM   #6
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
yup talked to your wife a few mins ago.
Something to keep in mind is that if she put the boost cables on wrong, ie pos on neg it may have damaged a cell in the battery which is preventing it from holding a charge. I'd get that battery checked first before replacing the alternator.
Mavrik is offline   Reply With Quote
Old 03-24-2008, 07:38 PM   #7
ridestreet84
Member#: 132030
2007 obp STI
broken again
pm me your address in silver run and i can come by and check it out for you and try to get it running if you like
Old 03-24-2008, 07:51 PM   #8
atcsubaru
Member#: 116985
2004 Subaru WRX
sent om
Old 03-24-2008, 07:51 PM   #9
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
the car can run on a bad battery and good alternator, but if the alternator is bad and battery is then the car eventually kills the battery and wont start, i'd get a new battery and if the car drains it then its the alternator, i dout it's the alternator
Alaskan EJ20 is offline   Reply With Quote
Old 03-24-2008, 08:27 PM   #10
blu05wagon
Member#: 162489
2005 grocery getter
stage 1.0!!!
one thing that might have happened is that when she charged the battery or jumped it one of the cables might have been hooked up backwards and that could have done internal damage to the battery
anyways good luck to you
blu05wagon is offline   Reply With Quote
Old 03-24-2008, 10:00 PM   #11
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
Rofl.... Phil just said that earlier, someone wasn't reading the thread
Wes_FSTGDB is offline   Reply With Quote
Old 03-24-2008, 11:27 PM   #12
atcsubaru
Member#: 116985
2004 Subaru WRX
Henry just came by and helped me out, says its the batter. thank you very much for the help.
On a side note appearently need i am in desperate need of of some Engine management, was reading the enginuity, or the romraider site i think it is now, and need to know if there is anywhere around here to get one of those cables and if anyone with some knowledg of what that is all about will help me.
Old 03-24-2008, 11:53 PM   #13
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
I had to change the battery when i got back too.
LiLpNoY is offline   Reply With Quote
Old 03-25-2008, 02:30 AM   #14
ridestreet84
Member#: 132030
2007 obp STI
broken again
glad i could help you out
Old 03-25-2008, 03:14 AM   #15
blu05wagon
Member#: 162489
2005 grocery getter
stage 1.0!!!
woops i did read that i was just reading it wrong lol maybe i got somethin backwards
Old 03-25-2008, 05:15 AM   #16
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
t4nk is the man you need to get with regarding enginuity
-Wes
Old 03-25-2008, 11:21 AM   #17
White_Rice
Member#: 160049
Just Got Back and Upgraded the Wheels jksuby Alaskan Impreza Club Forum -- AKIC 3 07-21-2009 04:14 AM
So I just got back from the VW dealership, and have to go back tomorrow... Layman Off-Topic 41 03-23-2006 05:23 PM
Just got back from hockey and.... Jimmy S. Off-Topic 25 01-07-2005 10:20 AM
I just got back from Motorhead, Dio and IRON MAIDEN!!! wrxman555 Off-Topic 13 08-11-2003 12:23 PM
just got back from burger king and....... newbie sewbie General Community 34 02-08-2002 01:33 PM
