Old 03-25-2008, 12:05 AM   #1
hagood22
Member#: 153484
2002 impreza wrx
midnight black pearl
Default how to read the stock turbo gauge
im wondering how to read the gauge properly cause i think thats my biggest problem. Well when people say im running 15 or 20 lbs of boost well how can i tell what peak im hitting when my gauge is in i think mpa. likw what does .15 mpa convert?
hagood22 is offline   Reply With Quote
Old 03-25-2008, 12:07 AM   #2
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
.1 mpa is 14.7 +/- psi
.05 is 7 psi............
kevin2.5rs is offline   Reply With Quote
Old 03-25-2008, 12:08 AM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
1= 145 Psi
.05=7.25
.1=14.5
.15=21.75
Audiosavvy is offline   Reply With Quote
Old 03-25-2008, 12:08 AM   #4
obsti2
Member#: 174278
2004 WRX
JavaBlackPearl
obsti2 is offline   Reply With Quote
Old 03-25-2008, 12:08 AM   #5
GDB FAN
Member#: 105814
.1 Mpa = 1 BAR = 14.7 psi
EDIT:
Oooo you guys are ninjas!
GDB FAN is offline   Reply With Quote
Old 03-25-2008, 12:30 AM   #6
hagood22
Member#: 153484
2002 impreza wrx
Default okay
so, im around .12 to .13 peak so really it will be around 15 to 18 psi
Old 03-25-2008, 12:31 AM   #7
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Roughly, yes
How to read vacuum on Digital Gauge kfckrew Electrical & Lighting 5 05-13-2010 12:45 AM
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 07:38 PM
How to read the stock turbo boost gauge? mRgUnN Newbies & FAQs 13 05-31-2003 01:30 PM
What units does the stock turbo gauge use to measure boost? Sublime5260 Electrical & Lighting 1 02-11-2003 05:34 PM
How to open up stock turbo gauge... msun2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-14-2003 04:08 PM
