Old 03-25-2008, 10:28 AM   #1
ScoobKing
Member#: 151420
93 Version 4-3 7/8
Quartz metallic grey son!
Default Oil in intake hose.
So last night while my timing belt was getting done(on my 1.8l) I decided to take a look at my throttle body to make sure it was clean. I noticed that the intake hose had oil in it. I figured it was from the PCV or the hoses coming from the valve covers. Is there anything that can be done about this?
ScoobKing is offline   Reply With Quote
Old 03-26-2008, 03:35 PM   #2
Haelan
Member#: 151045
2013 Subaru STI
CBP
If it's just blowby you can get a catchcan and filter out that gunk from being recirculated through your intake. Otherwise its normal and not much can be done to reduce it.
If you have a puddle of oil in your throttle body or intercooler...you may have a more serious issue ie. turbo going out, etc.
Haelan is offline   Reply With Quote
Old 03-26-2008, 06:44 PM   #3
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
The guy has a 1.8 N/A motor.
Sorry Scoobking, not sure about your situation. As mentioned, if it was just a film of oil it could be from the filter. I get OEM replacements and sometimes they are more soaked than others...
surowrxa is offline   Reply With Quote
Old 03-26-2008, 07:17 PM   #4
Haelan
Member#: 151045
2013 Subaru STI
CBP
Thanks for pointing that out
Old 03-26-2008, 07:36 PM   #5
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
I'm interested to know what's going on too, and I found this...
http://forums.nasioc.com/forums/showthread.php?t=704816
The problem was an unattached PCV. Hope this helps.
Old 03-27-2008, 09:17 AM   #6
ScoobKing
Member#: 151420
93 Version 4-3 7/8
Now that I think about it, I did find one of the hoses unattached. I just hooked it back up and put a spring clamp on it. I'll check in a few weeks if that fixed the problem. Thanks for the help. =)
Oil in rubber hose between intercooler and turbo b0red@werk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-30-2008 06:32 PM
oil in intake kcohen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 10-04-2004 03:45 PM
Poor Idle, CEL on, oil in intake plenum maxheadroom Normally Aspirated Powertrain 2 02-15-2003 12:52 AM
Film of Oil in IC hose, is that cool? PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-11-2002 09:49 AM
Lotsa oil in intake! Leonardo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-09-2002 03:18 PM
