Old 03-25-2008, 09:50 AM   #1
ShutterBC
Member#: 70361
2005 LGT ltd wag 5MT
Question Starter noise -- ignore, or repair/replace?
I have my '98 OBS in the shop to get some seals replaced, and the mechanic noticed that my starter makes an awful whine when the engine spins up.
The sound is kind of like nails on a chalkboard when the engine starts. The sound goes away as soon as the engine is running for a second. I've never had a problem starting, so haven't done anything up until this point -- but by this description would any of you recommend replacing the starter motor?
ShutterBC is offline   Reply With Quote
Old 03-25-2008, 02:08 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
If the bendix of the starter isn't retracting as it should when you release the key this could cause excessive wear on the ring gear. I would replace it if it was mine.
Old 03-25-2008, 02:18 PM   #3
ShutterBC
Member#: 70361
Yeah, what I heard back is that the starter doesn't disengage properly, so it's on its way out. I was quoted $250 for the part (bleh) but at least it'll be over and done with.
I really want my car to make it to 200k miles and it's only at 135k now...
Thanks for the advice.
Old 03-25-2008, 02:26 PM   #4
smurfwrx
Member#: 151928
09 Triumph S3
I assume you've ruled out a screeching fan belt?
I wouldn't let it go. You know it's not normal so just repair/replace it would be my suggestion.
smurfwrx is offline   Reply With Quote
Old 03-25-2008, 04:20 PM   #5
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Mine does the same, very annoying and gets a lot of glances when it's fired up! *sigh* just have to spend the $$ and get a new one.
JamesWilson is offline   Reply With Quote
Old 03-25-2008, 04:34 PM   #6
ShutterBC
Member#: 70361
@smurfwrx: Right, the noise doesn't coincide with fan operation, and it's only during start, so chances are high that the starter is just being worn out. I'm getting it replaced, so we'll see quite soon how that changes things.
Old 03-25-2008, 04:42 PM   #7
Cougar4
Member#: 53443
Winestone
Before replacing the unit I would make sure that the ignition switch isn't hanging up and supplying voltage to the solenoid an causing the problem.
Old 03-27-2008, 02:33 PM   #8
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
Mine does the same thing. Its a 2000 with a litte over 180k.
cougar4, how would I check that?
moogoob is offline   Reply With Quote
Old 03-27-2008, 03:44 PM   #9
ShutterBC
Member#: 70361
My guess was that since it would sound different when I hold onto the ignition (no, I don't regularly do that) then chances were high that the problem was something else.
A new starter is in now, and it sounds much, much better. Funny how it makes it feel like a different car.
Old 03-28-2008, 08:37 PM   #10
Cougar4
Member#: 53443
Winestone
Check for voltage going to the small wire on the starter solenoid when you release the key. If there is a delay in the voltage drop then the ignition switch has a problem.
Old 03-28-2008, 08:49 PM   #11
Cougar4
Member#: 53443
Winestone
Check for voltage going to the small wire on the starter solenoid when you release the key. If there is a delay in the voltage drop then then ignition switch has a problem.
GC8 coupe roof replacement or repair? midlifecrisis Interior & Exterior Modification 8 02-27-2013 03:14 AM
HID replacement or repair? Skeeler Electrical & Lighting 4 11-04-2008 10:19 AM
tail lamp cracked in several places replace or repair and tint overlay? evol04gt Interior & Exterior Modification 2 06-23-2008 09:04 PM
Curb Scraped my Rotas, replace or repair? illy Bay Area Impreza Club Forum -- BAIC 2 10-21-2002 01:14 PM
Remove and Replace, or Repair? deepbeep General Forum Archive 6 09-19-2000 12:46 AM
