Old 03-25-2008, 03:00 PM   #1
jon6682
Member#: 85954
2005 2.5RS
Crystal Gray Metallic
Default OK to use Bosch O2 sensor instead of Subaru sensor?
I am getting a check-engine-light related to my o2 sensor - bank 1. I'm not sure what the exact code was... I had the guy at Schucks auto supply get the code and he told me i needed to replace the o2 sensor. He also thought it would be fine to use the BOSCH universal 02 sensor he sold me for $70.
I called the subaru dealership and they said it would be $315 to replace with an OEM sensor.
Does anyone know if it is OK to use the BOSCH universal o2 sensor instead of going to the dealership for the OEM part?
Thanks!
jon6682 is offline   Reply With Quote
Old 03-25-2008, 03:34 PM   #2
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Yeah, It's the same thing. You just have to find the right wiring schematic and splice it in with the old sensor.
Not-EWRX is offline   Reply With Quote
Old 03-25-2008, 03:44 PM   #3
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Holy cow $315? Dealership "only" charged me like $120 for my sensor, it was for a 98 Legacy but this sounds like robbery for newer car owners!
jey is offline   Reply With Quote
Old 03-25-2008, 05:18 PM   #4
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Bought mine at SparkPlugs.com , NTK sensors are very good. Zero issues in the last 60K miles.
JamesWilson is offline   Reply With Quote
Old 03-25-2008, 06:45 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Thanks!
You need to know whether the problem is with Bank 1 Sensor 1 or with Bank 1 Sensor 2. I'm pretty sure a universal O2 sensor won't work as a replacement for Sensor 1.
Jon [in CT] is offline   Reply With Quote
Old 03-26-2008, 03:38 AM   #6
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
Is this for your 2005? Powertrain warranty?
On another note, the O2 sensor in my Subaru (and maybe yours) is actually an Air/Fuel Ratio meter - 4 wires, the generic Bosch did not work. Best to go with OEM on the O2 sensor unless someone out here has already tested one successfully.
birukun is offline   Reply With Quote
Old 04-07-2008, 07:55 PM   #7
jon6682
Member#: 85954
2005 2.5RS
Warranty will not cover this as it is deemed an electric problem and I have over 36K miles on the car.
I'm still hoping to use the BOSCH sensor but I'm not sure if it will work. This is for my 2005 Impreza RS...
Thanks!
Old 04-08-2008, 12:19 PM   #8
Greenbeast
Member#: 176457
Default O2 Sensor
I used a Bosch on my 95 BD 2.2NA with no problems. It was the pre-cat sensor and the older style (not a four-wire one).
Greenbeast is offline   Reply With Quote
Old 04-08-2008, 12:31 PM   #9
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
300 for just the sensor? Or is that the whole process of replacing it with labor (still high)
Doc Holiday is offline   Reply With Quote
Old 04-08-2008, 12:33 PM   #10
Greenbeast
Member#: 176457
Default O2 Sensor
Old 04-08-2008, 06:49 PM   #11
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Isn't the factory sensor made by Denso?
Acostafan is offline   Reply With Quote
Want to use a DC adapter instead of a battery pack... Cjchaps Off-Topic 11 04-09-2009 10:59 AM
Ok to remove rear O2 sensor? kumaWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 11-19-2007 02:42 PM
Is this o2 sensor ok to use? jeff1872t Southern California Impreza Club Forum -- SCIC 2 10-17-2007 04:08 AM
A/F gauge: Ok to install wideband o2 sensor in this location? Force Electrical & Lighting 19 01-19-2007 03:23 AM
aluminum crush washer ok to use instead of copper whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-16-2003 08:57 AM
