Vancouver Impreza Club
Old 03-25-2008, 02:32 PM   #1
shum_87
Member#: 129898
2001 Impreza
Default couple of maintenance questions
as my car has expired it's extended warranty earlier this year, I've been doing maintenance myself. the car's running near 165K, so I'm looking into certain things and I hope some of you can answer these questions:
1) I'm changing the fuel filter soon, but is there any sense in upgrading the fuel pump? or even changing the injectors?
2) transmission and differential oil change .. easy? hard? seems like a PITA to put in new oil. rear looks easy, but how to for the front?
3) I think I'll be needing a timing belt change soon .. possible as a DIY project? can someone help me with my 4EAT 2.5RS or is it prety straight forward?
4) prior crank pulley belts .. should I change them too? go with oem belts?
5) quick question: clutches .. is there a difference in means of application for MT and AT?
all these maintenance things (excluding clutch) I can send to DD for, but I'd rather do myself.
thanks for your inputs!
shum_87 is offline   Reply With Quote
Old 03-25-2008, 03:01 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Here's my personal opinion:
1) Definitely have the injectors cleaned. If the pump is still working then just leave it.
2) Both front and rear are easy. Make sure to get the proper tool for it though.
3) Get someone else to do this for you (aka the dealer). This is something you don't want to mess up.
4) If they are still stock then change them with OEM parts.
5) Well, AT doesn't have a clutch, it has a torque converter...
minifreak is offline   Reply With Quote
Old 03-25-2008, 03:30 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Everything but the timing belt I do myself and most people probably can with some common sense and a little mechanical/hands on experience...But first you need to figure out if you have a manual or an auto tranny.
1 no you don't need to change the FP
2 On the auto the trans the fluid and diff oil are different/separate
3 Dealer
4 OEM belts
5 More info needed.
wrxdrvr is offline   Reply With Quote
Old 03-25-2008, 05:09 PM   #4
Jockey_Girl
Member#: 130455
2000 Impreza 2.5RS
Chris did my timing belt for me
it was a first time for him on a subaru and it took us under 1.5hours, went pretty smoothly.
Don't know if he's willing to do another one lol, but he can probably give you some tips if you want to do it yourself
Jockey_Girl is offline   Reply With Quote
Old 03-25-2008, 06:50 PM   #5
Bondy007
Member#: 120301
2010 Honda Civic EXL
Polished Metal Metallic
I just did my timing belt and crank pulley belts recently but not DIY!
Bondy007 is offline   Reply With Quote
Old 03-25-2008, 07:27 PM   #6
ex_boyometric
Member#: 165210
2014 WRX STi Tsurugi
I recently changed my tranny and diff oil. My is a MT so tranny and front diff oil is the same. It was very easy but you just need the tools.
ex_boyometric is offline   Reply With Quote
Old 03-25-2008, 07:33 PM   #7
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Then maybe you shouldn't be advertising
Old 03-25-2008, 07:51 PM   #8
banman
Member#: 12408
2006 Legacy GT
Psshaw. If Yan and amarpauld and I can do it, anyone can.
banman is offline   Reply With Quote
Old 03-25-2008, 09:12 PM   #9
GlobalWaste
Member#: 74792
We got a good scare when those sprockets things spun though
GlobalWaste is offline   Reply With Quote
Old 03-25-2008, 09:30 PM   #10
Jockey_Girl
Member#: 130455
2000 Impreza 2.5RS
i'm sure he'll be nice and offer some help, he's just been kinda grumpy lately
Old 03-25-2008, 09:32 PM   #11
Jockey_Girl
Member#: 130455
2000 Impreza 2.5RS
an image of the three stooges just flashed across my mind...
Old 03-25-2008, 10:39 PM   #12
Yannerd
Member#: 111637
I think we were on NASIOC using the SEARCH button for a good hour before we realized everything's ok lah!
Looking at you just reminded me of rotten cheese!
Yannerd is offline   Reply With Quote
Old 03-25-2008, 11:00 PM   #13
Jockey_Girl
Member#: 130455
2000 Impreza 2.5RS
Old 03-26-2008, 02:54 AM   #14
shum_87
Member#: 129898
2001 Impreza
I think I'll stick with DD for the timing belt change. :P
has anyone changed their pcv valve? I've read up on two different threads about them and I'm very confused. one says it's next to the intake manifold, on the passenger side, while the other says I need to take apart the passenger side heads. someone snap a quick photo for me and show me the way, please??
Old 03-26-2008, 11:46 AM   #15
banman
Member#: 12408
2006 Legacy GT
^- I'm curious, too. I've been meaning to replace mine for awhile now. I think it's actually pretty easy to get to once you take off the intercooler.
Old 03-26-2008, 12:44 PM   #16
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
There is no intercooler on the 2.5RS. Or is there...
Old 03-26-2008, 01:12 PM   #17
banman
Member#: 12408
2006 Legacy GT
Just fo' decoration, yo!
Old 03-26-2008, 01:22 PM   #18
GlobalWaste
Member#: 74792
Just behind and to the left (passenger side) of the coil pack
pic courtesy of kastle @ scoobymods.com
Old 03-26-2008, 01:25 PM   #19
GlobalWaste
Member#: 74792
http://www.clubwrx.net/forums/showthread.php?t=98574
I used a long 19mm socket, I don't like wrenches
Old 03-26-2008, 01:35 PM   #20
banman
Member#: 12408
2006 Legacy GT
Any idea what symptoms would show up as a result of a sticky or bad PCV valve, besides oil in the intercooler? I'm probably long overdue to do this . . .
Old 03-26-2008, 01:43 PM   #21
milkface
Member#: 143742
2004 STi wagon
2008 WRB Forester XT
^ me 3.
Oil in intercooler just doesn't look right. But any other consequences with other parts in regards?
(basically repeating what banman said)
milkface is offline   Reply With Quote
Old 03-26-2008, 01:46 PM   #22
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
I had trouble with mine... as in it was confusing. I got the PCV part from Lordco, which appeared the same as the scoobymod instructions. However, once I got the intercooler off, NEITHER of the potential locations for the PCV valve was the same as the replacement valve (either end of the hose). I didn't end up changing it.
shawmacs is offline   Reply With Quote
Old 03-26-2008, 01:53 PM   #23
shawmacs
Member#: 111284
2005 WRX Wagon
Platinum Silver
Hmm, just read the clubwrx thread... someone said that in '04 they eliminated the PCV as a serviceable item... can anyone confirm this? They should update thier friggen maintenance schedules then!!
Old 03-27-2008, 12:21 PM   #24
shum_87
Member#: 129898
2001 Impreza
picked up an fuel filter + pcv valve yesterday. hopefully I'll get some time to install them this weekend.
when I went to DD, I noticed the STi blank key was selling for $60. SGp is no more than $20.
Injector cleaning - would the injector cleaning fluid (ie. the stuff you pour into your gas tank) suffice? or should i need I to take them out and have them professionally cleaned..?
Old 03-27-2008, 12:36 PM   #25
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would just put the cleaner into the fuel tank...
couple of maintenance questions sixthgear Vancouver Impreza Club Forum -- VIC 15 10-23-2007 06:13 PM
Couple of maintenance questions newsman Texas Impreza Club Forum -- TXIC 13 05-13-2005 04:51 PM
Couple of maintenance questions. Hagbard Service & Maintenance 16 01-23-2003 10:02 PM
couple of misc. questions imprezive General Forum Archive 5 08-07-2000 11:53 AM
Couple of wheel questions...what fits? offset? Overtime General Forum Archive 10 06-02-2000 11:02 AM
